Stacked sensors
8 replies195 views
I wonder if the new stacked image sensors that are coming out will make it possible to image and guide with the same chip. No more OAG’s or separate guide scopes. A full frame sensor can achieve a readout rate of 20 fps with this technology so it seems possible. With the right software it would be transparent to the user. The total integration time could be summed in camera while a short duration guide frame is taken every few seconds. The guide exposures could then be rolled back into the internal summing that makes up the total sub so that the total sub length really hasn’t changed. Am I missing something or is this the future?
Well Written Respectful Concise Engaging
Spacey avatar
if you mean read data while still exposing then it will require additional and substantial read and memory logic on the CMOS sensor which reduces performance. this is a good topic for a discussion with AI to give you some insights on the evolution of Sony’s CMOS technology
Robin Bosshard avatar
Wouldn’t we hit the DUO dilemma again? With NB filters the short guiding frames will struggle to get a good SNR (if you still manage to get’em to be short)…
Spacey · Mar 24, 2026, 12:41 AM
No, you need to read up on what a stacked sensor does. The main advantage is it gives very fast readout speeds with even a full frame sensor giving 20 fps. In DSLR, where the technology is currently deployed it allows much faster autofocus and does away with rolling shutter effects. The rest is just imagining what this technology might make possible on the astro camera side.
Robin Bosshard · Mar 24, 2026, 01:04 AM
yes, you certainly would but if you can fold the data from the guide frames into the total for the sub it really wouldn’t matter. In other words, the guide frames could be as long as you need them to be without impacting intergration time.
Alex Nicholas avatar
It’s been tried in a sense in the past by Starlight Xpress, using interlaced pixel row readout (yes, I’m aware this is not the exact same thing - but, you know, elephant that is a perfect sphere in a vacuum etc.)
At the end of the day - if you’re imaging and guiding with the same camera, regardless of the technology used to achieve it, your issue is going to be guiding through filters…
I’ve done it with 3nm filters and an F/10 SCT with an SBIG ST-10XME in 2010~2011 or there abouts… You CAN… but you don’t want to if there is a better way… Spoiler Alert! There is.
My primary question is this. What problem would this solve that isn’t better solved by an OAG, or OnAG?
None.
Change for the sake of change is wasteful, and sure, somewhere in between the lines, innovation exists… But honestly, Guiding through your filters is sub-par, so any form of dual sensor/stacked sensor/interlaced readout guiding is going to be sub-par.
Well Written Helpful Insightful Respectful Engaging
Spacey avatar
Tony Gondola · Mar 24, 2026, 02:49 AM
I’m going to tell you that you need to read up on what a stacked sensor is, and what it is not.
Alex Nicholas · Mar 24, 2026, 03:33 AM
None.
The major advantage to my mind is the ability to use the entire sensor for guiding. That would resolve the filter issue to some degree simply because more/brighter stars would be available.
SonnyE avatar
Curious subject. It sounds like a step (or a leap) forward. But I would expect to see some catch 22’s to it.
I may be in the dark ages with my guide scope and separate guide camera, but I do have the independence of changing individual components, like when my old guide camera failed, to a “New and Improved” specimen (ASI290MM Mini). And with PHD2 and the multi star guiding, 9 guiding stars for stability (in my case) seems to work amazingly well.
I, too, think I can see the advantages of guiding with the same picture as the File Images are being taken. But I’d lose my independent component flexibility. That was one drawback to the Duo camera concept for me.
Anyway, I appreciate the steps forward. But I’m all warm and cozy where I am.
So for those points, I’m out. 😉
Review of the QHY5III678M for ground-based satellite imaging
This is a review that shows the performance of the QHY5III678M planetary camera for ground-based imaging of satellites, I will showcase the specifications of the camera and example images I have taken with it of several satellites. I also want to kin...
Reviews camera sensor technology relevant to imaging and guiding applications.
Jan 12, 2026
