Want to image NASA's Orion Spacecraft During Artemis II?
5 replies308 views
Shawn Gano avatar
Artemis II could launch as early as 1-April; sending humans back around the moon for the first time since Apollo. During this mission the Orion spacecraft will perform an extra orbit around earth to allow time for systems checkouts as well as a docking maneuverability test. This extra orbit provides a unique chance to capture it with a telescope and camera before it gets too small as it heads to the moon.
I have written a python script that can use trajectory data along with a given location on earth and a telescope / camera setup to calculate times that imaging may be possible. By possible I mean: (1) large enough in the sky, (2) above the local horizon, (3) the spacecraft lit by the sun, and (4) it is night at that location on Earth.
I typically try to avoid getting satellite trails in my photos; but this time I am trying to do it on purpose!
There are plenty of ways this may not work out (weather, errors in calculations, different trajectories, etc.); but capturing an image of this historic mission sounds like a lot of fun and worth the effort to me!
The more people from more places on Earth that attempt this the better our chances of getting photos. This is because the launch periods span multiple days and over two hour long windows, which could result in drastic shifts on where and when it is possible to image (besides pesky weather conditions).
If you are interested in joining me, I have recorded a video with a little more background as well as how to use the script. The script also outputs files that can be imported in to Stellarium to help make planning easier.
Here is a link to the video: https://www.youtube.com/watch?v=GqiRlgBeyWY
Here is a link to my website where I have posted the script source code: https://www.gano.name/shawn/artemis2/
If there are questions I will try to get to them as best as I can. Though I tend to be quite busy, so it may take me a while to reply.
- Shawn
Well Written Helpful Respectful Engaging Supportive
I’m more interested in capturing during trans-lunar coast. Will your script work for that as well?
Shawn Gano avatar
Tony Gondola · Mar 23, 2026, 02:56 AM
Yes it can help with that. The output to Stellarium doesn’t remove any of the times so it should work for any point in the mission. I would suggest changing the size constraint to be something even smaller to help find good opportunities during transit - though it will get very small quickly so as early in the coast as possible will be the most feasible (but I have no idea when it would be too far to detect as I am not sure how much light it will reflect). I will be excited to see your results! Also note the trajectory data file should be updated about once a day; so just be sure to grab the latest version to have the most accurate pointing estimates.
Great, look forward to giving it a try.
Tim McCollum avatar
I’ve been able to image JWST using 10 minute exposures to see the streak of light reflected from the Sun shield but it is the size of a tennis court but 4 times further away I think.
Looking forward to trying Atremis out.
Shawn Gano avatar
Tim McCollum · Mar 24, 2026, 06:13 PM
That sounds promising then for trying when it is even closer to the moon (in the script you can adjust that with the minimum pixel size- or just ignore that constraint). The weather is not looking good for me; I hope yours is better!
Another useful ChatGPT use: Compute RA and DEC offset for a comet image
With the short window we have for Comet C/2025 A6 Lemmon right now, I don’t have time to fiddle with trying to frame the comet in such a way that the comet nucleus is on the corner and the tail runs diagonally across the frame so I can get as much co...
Computing RA/DEC offsets relevant to tracking spacecraft trajectory data.
Nov 9, 2025
Review of the QHY5III678M for ground-based satellite imaging
This is a review that shows the performance of the QHY5III678M planetary camera for ground-based imaging of satellites, I will showcase the specifications of the camera and example images I have taken with it of several satellites. I also want to kin...
Satellite imaging camera review directly applicable to imaging Orion spacecraft.
Jan 12, 2026
