Dear Astrobinners,
I would appreciate your wise counsel one again. I have recently purchased a TS Hypergraph 8 f3.2 Newtonian. I knew that collimation would be a challenge, but have successfully collimated my RC8 before now. So, how difficult could it be?
After eight hours during the day and a similar amount at night trying to achieve collimation with my 1.25inch TS concenter, TS Cheshire and cheap laser, I am beginning to reconsider my evaluation.
Perhaps my 1.25inch TS concenter is too small (sent in error to me my TS rather than the 2inch version) as the largest ring on the concenter is smaller than the secondary I am trying to align under the focusser.
Perhaps my TS 1.25inch Chesire is too small - very hard to get an image of the secondary.
And the less said about my laser the better. The spot disappears once it gets within the centre ring mark on the primary and the return hole is so large I can't determine the précise alignment to within at least an eight turn of a 1ry mirror screw.
Even the very best of my efforts to get thing concentric have resulted in failure when it comes to imaging across a full frame sensor. I can get half the field in good focus, but the other half is way out. CCDinspector says my collimation is good to within 6pix, which I suspect may not be good enough. It gives a tilt of a few degrees, but quite significant curvature. I don't think that the is due to the incorrect back-focal spacing, I am within 0.2mm of the manufacturers recommended distance.
Of course, I should have learned from my experience with the RC9 - collimation was achieved because of the right tool - the Takahashi collimator - and the good instruction manual with it.
So my question are
1) What equipment do more experienced owners of these fast systems use to collimate? The Farpoint Super Collimation kit looks good, but expensive. [Not compared to the telescope of course]
2) Is there a good guide - with clear diagrams - out there on the internet?
I would like to ensure my collimation is spot on first, before I go chasing other possible sources.
With thanks in advance for any help..
So my question are
