How to change the background of a Ha solar image to black?
15 replies158 views
Luke Pearson avatar
Just got my solar scope today and have been playing around with it and have taken some good photos given the weather. How do I change the background to black? I can’t adjust the curves In gimp without dramatically darkening the solar disk. And I also want to preserve my prominences. I used IMPPG to edit before gimp so maybe I went wrong there?
Any help would be greatly appreciated.
PS: The strange artefacts to the left are caused by clouds during imaging.
Respectful
Rick Veregin avatar
Hi Luke
I’m assuming the raw image had a black background and a bright sun, then yes, the processing was odd in imppg. It is easiest to do what you want to do in imppg, use GIMP just to do any final small tweaking. In imppg you need to apply a special tone curves adjustment and it can be finicky. Also need to be careful in imppg, as messing up the tone curve causes imppg to crash.
I assume you are processing a 16 bit uncompressed file, not a jpg—very hard to do with an 8 bit compressed file.
Here is a tutorial on using imppg. At the end it shows an example of a tone curve. https://greatattractor.github.io/imppg/tutorial/tutorial_en.html#introduction
The immpg tone curve below shows one solution, the peak at the left is the prominces, so put the first point at the start of the prominences at zero, the gap from the left is the background—you need a gap or your background will not be black. The curve goes up to enhance the prominences, then comes down to invert the surface, the brighter the solar surface, the darker and vice versa. You can also adjust gamma. Note the tone curve may need to be sharper at the left if your prominences are weak, and sometimes you need a dip in the curve between the prominence peak on the left and the solar surface peak which runs center to right.
Hope this helps,
Rick
Luke Pearson avatar
Rick Veregin · Mar 20, 2026, 03:52 PM
Hi Luke
Hope this helps,
Rick
Thanks for your help Rick. I have gone back through and made a more pleasing photo with this inversing method. My curve however looks more bumpy. I think the background issue is mostly because of the light scattering on the camera side of things because there was a thin layer of cloud out when I took the image. I am very pleased with it as my first solar image, and I am expecting better conditions tomorrow so I should be able to improve on this.
Respectful Supportive
Rainer Ehlert avatar
Hi Luke,
Not easy but the most important hing is that you need to work on the adjustment of the Ha filter.
Put the sun in the center of your FOV and try to get a centered Hot Spot. If that is not possible then search a position inside the FOV and see if you get the hotspot centered.
Also work more on getting into the correct bandwidth.
Rick Veregin avatar
Luke Pearson · Mar 20, 2026, 04:38 PM
Hi Luke
Hope this helps,
Rick
Glad I could be of help. Yes, as I said, you may need to do even more complex tone curves, depending on your data.
Luke’s comments are right on, the hot spot should be centered on the centre of the Sun. And solar is very unforgiving, even light haze scatters a lot of light, wiping out the prominences. Assuming you have live view when you are recording the images you should be able to see the prominences, do a strong stretch on your live view, let the disk go totally overexposed. This can help when you are trying to tune the wavelength.
Rick
Well Written Helpful Respectful Concise Engaging Supportive
Luke Pearson avatar
Thanks for your help everyone. My telescope is double stacked so I will play around with the tuning more tomorrow, hopefully when the weather is clear.
Luke Pearson avatar
Rick Veregin · Mar 20, 2026, 08:05 PM
Hi Luke
Hope this helps,
Rick
Rick
Thanks. I will do. I have heard however that tuning is quite tricky because if you tune for prominences you loose details on the surface and vise versa. Is this true?
Luke Pearson avatar
Rainer Ehlert · Mar 20, 2026, 07:00 PM
Hi Luke,
Thank you. I will work on that. I am also going to make the disc mosaic with my barlow for proper sampling. I didn’t do that for this one. That should help fine tune.
Respectful
Rick Veregin avatar
Luke Pearson · Mar 20, 2026, 08:40 PM
Hi Luke
Here is a tutorial on using imppg. At the end it shows an example of a tone curve. greatattractor.github.io/.../tutorial_en.html...
Hope this helps,
Rick
Rick
Show more
I have a double stack Lunt, not sure how yours compares. So I have a tuner at the back, which is pressure tuned, and then the double stack is in front of the objective is tilt tuned. So without the front unit on, I tune the back pressure tuner to make it as dark as possible on the histogram, you are rejecting the most off-band sunlight. Then I put on the front tuner and tune for the brightest image, this means the front tuner is matched with the back. Finally, I fine tune the front tilt so the brighest part is centered on the Sun, if it is not centered one side will be brighter than the other.
This tuning method is easy and it always works, anything else I tried was just back and forth and never sure I got it right.
So I can’t answer your question directly, as this method is really an overall surface tuning, which is where most of the signal comes from. Though I do get a good result for the surface and prominences with my all in one tuning.
My suspicion is this advice for tuning to surface or proms is for visual viewing. Because yes the prominences will not be as bright when tuned for the surface, which matters visually. But since we can collect lots of images we can get good S/N in the proms, even if not perfectly tuned to them.
Rick
Well Written Helpful Respectful Engaging Supportive
Luke Pearson · Mar 20, 2026, 08:42 PM
Hi Luke,
Hi Luke,
Please describe your Ha filters. I have a double stacked Coronado SM60 (the Original ones) and I have a method for tuning them.
If you have pressure tuned Ha filters I am sorry I can not help you.
Rainer
Well Written Respectful Concise Supportive
Tuning on a disc and tuning on a partial solar image is a different thing.
If you have a partial Sun image then tuning is a bit easier…
Before venturing into assembling Sun mosaic I would recommend tune the filters on the complete sun disc. This will help you gain more experience in tuning the filters.
Rainer
Luke Pearson avatar
Rainer Ehlert · Mar 21, 2026, 01:56 AM
Hi Luke,
Hi Luke,
Rainer
Hi Rainer. It is one of the solar scopes with front mounted etalons. The first is the “aperture” where you just rotate it around, the second is just below that with a little thumb turner. Its a solarmax III with a feather touch focuser.
Luke Pearson · Mar 21, 2026, 02:16 AM
solarmax III
If I recognize well the scope you have an etalon inside the scope and a front etalon. Correct?
The front etalon as far as I know has also a tilt mechanism which is a tiby golden wheel with which you chage the inclination of the front etalon. correct?
If that is the case, leave the roch view tuner in the middle position and rotate the tiny golden wheel in such way that the fron etalon has 0 zero tilt or inclination.
Now move the lever in the telescope body and see what happens. If they behave like mine the the hotspot should move.
Then you can start tilting the front etalon and forget for a while rotating the rich view adjuster.
The tuning of a double stacked Ha filter is a Trial & Error process and looking what happens when you move what is the key for tuning and learning wht does each of the movements.
I once had a rich view tuned Ha for test here and honestly in my case rotating the front ring did not do anything in my case. Just my experience with a Rich View tune system.
Rainer
PS Are you a member of SolarChat Forum? There are many solar imagers with more experience than me.
Luke Pearson avatar
Hi guys, I managed to get some better data today and played around with the tuning. I know what you mean now, it is quite fiddly to get right. I tried as best as I could to manage the tsunami of overexposure and balance it with the contrast features on the surface. I took many images and this was my favourite. I also experimented with adding a black background however it usually just took the prominences away.
Luke Pearson avatar
Rainer Ehlert · Mar 21, 2026, 02:47 AM
solarmax III
Rainer
Hi, thanks for your help. I will check out that forum now. This is my telescope. I spent a while tuning it and noticing the contrast differences and how it varied depending on the suns placement on the sensor too. Learnt a lot but still have much to improve!
📷 WhatsApp Image 2026-03-21 at 15.43.08.jpegWhatsApp Image 2026-03-21 at 15.43.08.jpeg
Respectful
Luke Pearson · Mar 21, 2026, 03:42 PM
Hi Luke,
If you really want to analize your images do not colorize them. Coloring does kill details.
Today I started again as my southern hemisphere is blocked. Below my image from today.
You can also take this image as a reference for tuning your filters.
How to get better background extraction in editing!
Hey everyone! I’m still really new with editing and wanted to ask a question on how to get a truer black background, It might be the light pollution from my Bortle 8 skies, But I just wanted to see if anyone could help me out! I’m going to attach a p...
Directly addresses changing background to black, same core problem as post.
21 days ago
Esprit 120 Slippage / Sesto Senso 2
Hey Guys, some time ago I was quite astonished to hear that there are tak toa users that support their focusers with rubber bands to get rid of slippage. First time hearing that people support their premium scopes with rubber bands I thought, that ca...
Irrelevant - discusses telescope focuser issues, not image processing.
Jan 19, 2026
