Dew shield modification: painted and insulated, but concerned about reflections
4 replies77 views
AmyWarble avatar
Some time back, a user here (I can’t recall his name, sorry) posted his physics lecture on dew shields and how to best utilize them. The recommendation was that flocking is bad, you should paint the inside of your dew shield and wrap it in insulation.
Well last fall and early winter, I suffered repeated dew problems despite turning my dew heaters way up. I decided to go out on a limb and trust the lecturer. I didn’t understand the math, but I understood the reasoning and have deep respect for those who spend their lives studying the sciences. Again, sorry, I can’t remember the name.
I’ve finally done this with my Askar 120APO. The dew shield unscrews from the telescope body. I removed the flocking and the glue under it. I painted it with Rustoleum 2x Ultra-Matte black spray paint and wrapped it with some insulation from Amazon: Reflectix Reflective Radiant Barrier Insulation Roll.
But now, it feels like I’ve traded one issue for another. I’m concerned about reflections off the dew shield. It looks reflective when you look through it. How do I evaluate whether my dew shield is reflective enough to cause an issue? And did I use the right paint? It doesn’t seem right? I didn’t expect it to be reflective. I thought matte meant “not reflective”.
I don’t know anything about paint.
Well written Respectful
I don’t know if the paint as you did it will be a problem or not but I can tell you that a lot of surfaces can become very reflective as the angle of incidence increases.
Brian Puhl avatar
If you had dew on a refractor, then you didn’t place your dew heaters properly, or it just plainly wasn’t working at all. I live in the armpit of America, it’s 99% humidity here daily. No issues, although I am doubled up with 2 bands on lower power.
I think you got yourself in a pickle over thinking this.
Quinn Groessl avatar
I flocked the inside of my 3D printed dew shield for my C8. Works pretty well. I no matter my dew straps setting I always seem to get some on my C8 if I go without it, and without the flocking there were a lot of reflections.
David Jones avatar
The generally recommended paint in astro forums is Musou Black with a best practice to apply it with an airbrush. When I was doing some filter comparisons (imaging a bright star), I picked up on an internal reflection of an adapter in my imaging train. I bought the paint and an airbrush off Amazon, diluted the paint 2 parts to one part distilled water, did some quick learning on the brush painting some cardboard and gave it a go. I only gave it the one coat (multiple is recommended) and had a significant reduction in the reflection I was seeing. I rushed to do this as my weather conditions haven’t been great. The paint is water based acrylic so clean up is easy. I neglected to photograph the before and after of the adapter, but the change is phenomenal. See this thread - https://app.astrobin.com/forum/topic/200149/william-optics-ultra-cat-108/seeking-internal-flat-black-coating-recommendations-for-ultracat-108-adapter?page=1&post=213642
Best practice for preventing moisture damage
Hi I’m interested to know how you protect your cameras, eyepieces and scopes from getting moisture on them or getting inside them. Primarily i’m concerned about this happening when the equipment is brought back into a warm house, but what is the risk...
Addresses dew shield design and physics for moisture prevention.
24 days ago
