I need some general advice concerning plate solving in PI. I have the gdr3sp-1.0.0-s-01 and gdr3sp_1.0.0-s-02 files downloaded. I’m getting astrometric fails at the end of stacking. Also get fails when I run solver or spcc. The image(s) solve fine if I export them and solve directly in ASTP so I don’t think it’s an image issue. What am I missing?
Well written Respectful
Assuming you configured the astrometry server correctly (is it?) check you got the FL or image scale correctly and the right seed (as well as the catalog selected, not auto) in the solver as shown below:
Aleksey Shipilëv avatar
What Andrea said above, plus:
“gdr3sp”-s — note “sp” — are spectrophotometric catalogs, these are used by SPCC. You need plain “gdr3” catalogs for plate solving. Make sure Process → Astrometry → Gaia → Settings (wrench key) have them hooked up.
andrea tasselli · Mar 15, 2026, 06:40 PM
It wasn’t, see below…
Aleksey Shipilëv · Mar 15, 2026, 06:49 PM
That was it, working great now, thanks!
*So you didn't configure the astrometry solver correctly as you had the wrong files.
Luis Bracero avatar
Gaia catalog path not configured
In PixInsight you must manually point to the catalog.
Have him check:
Process → ImageSolver → Wrench Icon → Star Catalog
Check this out too.
andrea tasselli · Mar 15, 2026, 07:49 PM
Yes
nico1038 avatar
Luis Bracero · Mar 15, 2026, 08:10 PM
Have him check:
Check this out too.
Hi Luis,
You're probably trying to help, but this answer sounds like it was generated by AI and is full of inaccuracies that will only add to the confusion!
1) ImageSolver isn't a process, it's a script.
2) The wrench icon you're referring to isn't in ImageSolver, but in the Gaia process.
3) There is no setting called Star Catalog
Nico
Plate Solving
Any way to get help for advanced plate fails without having to make a forum post?
Directly addresses plate solving failures, likely same advanced issue.
Nov 1, 2025
PI plate solving fails?
Since yesterday, I can’t get advanced astrometric annotations for my images. The images are plate-solved correctly by Astrometry.net, but then the PixInsight solving fails. Is anyone else seeing this? Thanks, Francesco
Directly addresses PixInsight plate solving failures and astrometric solution issues.
Feb 22, 2025
Stellavita Plate solving and annotation.
There is not annotation when I plate solve a sub. Is it not a feature in the SV or am I missing something ? For info, I use the iOS version.
Discusses plate solving failures; directly relevant to annotation issue.
Jul 27, 2025
Why astrometry failed but Platesolver 3.0 succeeded on same image
I have uploaded an image. This could not be platesolved with astrometry in astrobin. However, I have solved the same image with Platesolver 3.0 within a few seconds. Has everyone an idea, why this happens?
Discusses plate solving failures in PI; directly relevant to troubleshooting astrometry issues.
Mar 25, 2026
Photometric calibration on siril
So for some reason when I try and plate solve my images on siril it wont execute the photo metric calibration and color calibrate it, please hel me
Plate solving failures in PI — discusses plate solving issues and troubleshooting approaches.
Oct 15, 2024
