Recommendation for a CMOS mono camera to fit a C8 EdgeHD
20 replies282 views
Rodolphe Goldsztejn avatar
Hi
I’ve been using for years a very reliable, rock-solid Moravian G2-8300 MKII with its internal filter wheel, connected to the C8EdgeHD through a Moonlite CHL 2.5 focuser. The sensor is a KAF8300, by and large deprecated in today’s CMOS world. However, given the average sky quality and seeing (2”-3”) at my site, its 5.4µm pixel size fits very well with the OTA focal length (2032 mm).
I also run a CMOS camera (IMX571, mono) on a couple of refractors with great success and much reduced noise compared to the KAF8300.
I’m now considering upgrading the G2-8300 camera to something more recent.
Any recommendations for a mono CMOS camera that would fit this setup?
Thanks in advance,
Rodolphe
Well written Respectful
ASI294MM or equivalent from the other vendors. Otherwise the IMX571 sensor is still the best in the game but you'd be wasting signal at FFL.
John Tucker avatar
Seems like one of the Omegon cooled cameras with the 432 sensor 9 um pixels) would give you the right pixel scale and a lot more speed than a camera with <5 um pixels…
Concise
There are no good reason to buy a 12bit camera, me thinks. You can easily bin 2x and still get a better RON than that camera and full 14 bit (or 16 bit with an IMX571).
Tobiasz avatar
John Tucker · Mar 15, 2026, 11:10 PM
The IMX432 sensor is pretty good. I have used the color and mono version in the past. But beware: the sensor has higher than usual dark current and ampglow which slows down signal buildup.
Still, most of the stuff can be fixed with proper darks and dark flats. I do not recommend shooting bias frames, because of the amp glow.
If you're picky with the cleanliness of your detector then you are better of with the IMX492. It has a bit bigger FoV and less ampglow. You can bin/resample to regain the SNR.
The only IMX432 I currently have is used for lucky guiding with high framerates in MetaGuide. (Apollo M-Max)
Well written Helpful Respectful Engaging
Thanks all for your insights. I know have several options to consider.
I’ll also have a look at what other C8 users use for shooting, it could provide additional hints.
Thanks
Rodolphe
Respectful
John Tucker avatar
andrea tasselli · Mar 16, 2026, 09:41 AM
“RON”?
I don’t know a lot about cameras. The ratio of the square of the pixel sizes for the 432 vs the 571 is 5.9. If I’m doing the math correctly, that’s equivalent to dropping from F/10 to F/4 ????
I see a lot of conflicting opinions on the internet as to whether 2x binning increases the signal/noise ratio by a factor of 4 or a factor of 2.
I live in a place with a lot of light pollution and where it’s almost always cloudy, especially on new moons! So I’m a bit of a speed freak…
Tobiasz avatar
John Tucker · Mar 16, 2026, 11:47 AM
“RON”?
I don’t know a lot about cameras. The ratio of the square of the sensor sizes for the 432 vs the 571 is 5.9. If I’m doing the math correctly, that’s equivalent to dropping from F/10 to F/4 ????
Sensor size has nothing to do with light gathering power of the detector. Pixel size, quantum efficiency and system noise are relevant.
CCD Binning increases SNR by a factor of 4, because CCD sensors do the binning before sensor readout, which then applies readout noise “RON”. So RON is only applied once to the binned “superpixel” consisting of 4 signal values from the single pixels.
CMOS pixels are binned after the readout, which means that every pixel has read noise already applied. Signal increases times 4 (because of four pixels) while noise increases by the square root of the signal, which is 2. You only increase the SNR by a factor of 2.
Well written Helpful Insightful Concise Engaging
John Tucker avatar
Sorry, meant “pixel size”, not sensor size. Edited post to correct.
John Tucker avatar
Tobiasz · Mar 16, 2026, 12:21 PM
“RON”?
Sorry, meant pixel size, not sensor size. The argument I’ve seen on the internet is whether read noise or sky noise (?) dominates in practice. Again, I don’t understand cameras well but the conclusion that the sky noise people reach is that for longer acquisitions you get more than a 2x improvement. I am not qualified to judge.
Tobiasz avatar
John Tucker · Mar 16, 2026, 12:24 PM
All other factors ignored: Yes, the bigger pixels of the IMX432 build up signal 5x times faster than the 3.76micron pixels of the IMX571.
Edit: If you ignore the resolution and just want to know how deep you can go with your telescope under your local conditions & stacking you can calculate it with the tool from Frank who developed MetaGuide.
https://smallstarspot.com/shiny/StackSNR/
There you can compare your f/10 edge with the noisier IMX432 with the big pixels against the IMX571 with the clean but small 3.76 pixels. I did a comparison and despite the high dark current of the IMX432 it will go about 1 magnitude deeper than the IMX571 with the same integration time. (SNR of 3)
John Tucker avatar
Tobiasz · Mar 16, 2026, 12:28 PM
Jan Erik Vallestad avatar
Rodolphe Goldsztejn · Mar 16, 2026, 11:36 AM
That’s a pretty sound approach. Otherwise all you’re getting is opinions. Some things may make a little sense on paper, like the large pixel size of the IMX432. I considered it myself at one point but was warned off by PlayerOne. They sell a cooled version I think, but warned that the noise levels were way beyond better sensors like the IMX533/571.
I can list what I do. Important notice; I do not use the reducer as it was not compatible with my APS-C cameras, fine for smaller sensors though. Anyway:
Planetary - I use my IMX678 cameras as they give me ideal sampling without the need of barlows.
DSO - I use my IMX571 cameras, though IMX533 would be the same bar the FOV. Sometimes I bin in post, so in practice some of my images are bin2 which is manageable. I do not have a observatory grade mount that can guide at 0.38” consistently enough.
“Lucky imaging” - I’ve used my IMX571 with some luck on windy nights, I did a brief test with my IMX678 - My long term plan is to utilize my Celestron .7x reducer with my new cooled IMX585 camera for this.
Thanks Jan Erik,
I appreciate your comments and use cases: They resonate well with my experience on the C8 (with or without the .7x reducer). This telescope, if well collimated, is a joy to use.
I went to https://astronomy.tools/calculators/ccd_suitability to simulate the various combinations. It looks like the IMX571 would work well in most circumstances related to my real-life site conditions. It leads to oversampling in all but exceptional seeing conditions. But the KAF8300 as well!
The only main advantage of the IMX571, in my case, would be the increased QE/sensitivity. Is it worth the effort? I’m not convinced.
Fir the time being, I think I’ll stay with the G2-8300 as long as it keeps working: I’ve had it for almost 10 years and I’m still happy with it 🙂
On a side note, if you invest on the 0.7x reducer, watch out for the reduced back focus distance - I explored many options to accomodate the OAG and the CCD camera (55 mm BF) to make sure the sensor sits sharply at the 105 mm BF distance - I finally opted for the Moonlite CHL 2.5 focuser, which works perfectly for both my imaging setups (with and without the reducer).
All the best, Rodolphe
Helpful Respectful Concise Engaging
Tobiasz avatar
Rodolphe Goldsztejn · Mar 16, 2026, 03:37 PM
The IMX571 has higher QE yes, but the KAF8300 has bigger pixels (5.4micron). Attached to the same telescope the IMX571 provides higher resolution, but the KAF8300 detects 1.6x more photons in the same time. On the other hand the KAF8300 is much noisier and longer exposures are required to offset this.
If you resample the 571 to the same imaging scale, then the QE and cleanliness wins as expected.
Is this visible in LRGB exposures? I don't know. Narrowband? Definetly, the Touptek version of the 571 can go down to 0.9 electrons read noise in HCG mode which blows the 8300 out of the water with its 8-10 electrons read noise.
Is it worth it? Depends on what you want to image and your sky conditions.
Thanks Jan Erik,
No worries! I think that’s a very solid decision, as long as it’s working well and you’re happy, I wouldn’t switch in your shoes either.
As far as the reducer go I do own it, but it was unusable with APS-C cameras, it worked fine with my IMX533 camera a few years back. Here’s a thread about it that I now realise I never updated - Will do so now! As you can see there the reflections caused by the reducer were quite horrendous.
Clear skies!
Well written Respectful Concise Engaging Supportive
Tobiasz · Mar 16, 2026 at 04:23 PM
Hi Tobiasz
Thanks for commenting.
I confirm that noise is very visible in LRGB exposures with the 8300. I also own a 571 camera, the difference is quite visible.
However, tools such as BXT and NXT help reduce their impact by a vast amount, in my experience. I have lately reprocessed old images using them, and they became quite pleasant and even easier to process.
Like you wrote it, the environmental conditions are the most important factor ultimately, and we have no control over them, unfortunately.
Clear skies,
Rodolphe
Hi Tobiasz
Clear skies,
Rodolphe
Hi Tobiasz
Clear skies,
Rodolphe
Mark Fox avatar
Rodolphe, keep in mind the versatility of the smaller pixel-size cameras. For example, the 571 sensor with 3.76um pixels, you can shoot in 2×2 bin with the C8 in average conditions (roughly well-sampled but reduced read noise), but then you can also use it 1×1 on a scope with a shorter FL.
Mark
Hi Mark,
Good point, indeed.
I do own a 571 (Moravian C3-26000, mono), which I could move around; it is connected to a 130 mm refractor and perfectly tuned to it. But it’s such a pain to disconnect/reconnect, re-adjust the back-focus and reconfigure the software that I’m reluectant to do it - I’m getting lazy!
Initially, I was hesitating between either keeping the current 8300 or purchasing another CMOS camera with similar or better capabilities. There seems to be a consensus on the 571, based on the above discussion.
Being happy with my current results, I think I’ll carry on with the 8300 for the time being. And reconsider later if an opportunity shows up.
Thanks all for your inputs.
Rodolphe
Respectful
