Windy Tree Astro avatar
Hello!
Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently.
It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the focus point will seemingly be about 36000 however if I run autofocus a second time it shifts to 36700. Sometimes I can’t even get a correct curve (Starting in focus). This reads to me like the mirror may be getting stuck when moving in or out?
  • I have verified the EAF is functioning correctly. I can see it moving the focuser, and ensure all connections are tight
  • Mirror locks are not tightened to allow use of the EAF
  • Removing the EAF and turning the brass focuser knob seemed to be “ok” however it did seem slightly more stiff in one direction (Likely because the scope was pointed up and I was pushing against gravity in one direction?)
  • I will often get a failure during autofocus even if I have a good curve in that the HFR is worse than previous. This is seemingly because if it moves past the found focus point…getting back to that focus point seems to have “moved”
  • Backlash comp is set to OUT only at 150 steps. I have been using 150 for a step size as well.
I am imaging in cold Canadian winter sometimes down to -20C however the problem persists when the temps are closer to -5 to -10C as well. I have a dew heater wrapped around my EAF even though it seems to be running fine.
Any ideas there or things I could try? I’ve seen potentially lubricating the internals, but I’d rather avoid taking the scope apart if possible.
Well written Helpful Respectful Concise Engaging
Rodolphe Goldsztejn avatar
I lately ran into a very similar issue, not on a C8 but on a refractor.
The focus point started shifting slowly but progressively until it reached the focus limit point defined in the driver.
A visual check confirmed that the focuser seemed to be working well.
But after (intense) analysis, I found out that one of the screws of the electronic focuser bushing (Pegasus Astro) was only loosely fixed to the OTA focuser shaft. I retightened both screws of the bushing and… the problem disappeared.
Maybe this can help in your case.
Rodolphe
Thanks for the reply!
I did take it all the way off the scope so I could manually check the scope focuser. I can confirm all fittings are tight as they can be. Which is why my current theory is the scope focuser is sticking somewhere, but I’m not certain.
Well written Respectful Concise
Well I think the hypothesis was correct. There seemed to be sticktion with the baffle tube. Since I only image between F10 and F7 and usually stick there I don’t think the lube was spread enough. I read online somewhere to rack the focuser/mirror all the way in and out several times to spread the lube on the internal baffle tube. After doing this my autofocus runs seem to be running successful now.
