Interactive Sky avatar
Hi everyone,
I have a question about combining datasets from different equipment.
Let’s say I have images of the same target taken with different telescopes and cameras, meaning the data has different focal lengths, pixel size, and resolutions.
I know that AstroPixelProcessor can stack such data together.
But I’m not sure if PixInsight can do the same.
Is it possible in PixInsight to directly stack exposures from different scopes/cameras into one integrated image?
I’m curious what the best workflow is in PixInsight for this situation.
Respectful
Tony Gondola · Mar 14, 2026, 02:40 AM
Found this in the PI forum:
https://pixinsight.com/forum/index.php?threads/wbpp-stack-different-resolutions.24695/
Thank you, Tony.
I am just interested in whether this could work for big collab projects.
Still looks like APP outperforms PI in this case.
Respectful
I have no idea but there are people here who do that sort of thing.
Tony Gondola · Mar 14, 2026, 03:21 AM
Hopefully someone who did this kind of thing will share their expirience 😁.
Respectful
sebaromano avatar
My 2 cents.
I did this multiple times in Pixinsight even with different camera sensor pixel size.
Let’s say you have rig A and rig B (different cameras same target). Stack separatly the 2 group of images coming from the 2 rigs. Then align the 2 master lights with DynamicAlignment (NOT StarAlignment). Then you are ready to stack the 2 master.
I tried with stacking alltogether the single frames in PI but I gave up after looking at multi forums. It seems not possible or not easy.
But you can do that in APP (I tried and it works). I still prefer the solution I have mentioned above as I can see the effect and contribution of each master to the final master. Sometime I found adding one master to the other being more detrimental then anything else.
Hi, sebaromano.
I never heard of such a method.
Will definitely try.
Thank you.
Respectful Supportive
Tareq Abdulla avatar
I used APP before for only stcking different exposure times which i find easier than PI, but i didn’t try for combining different setup, in any case i will use any software that can allow me to that, i have both so it won’t be an issue for me.
Stacking multi-telescope imaging data with different focal lengths and sensors
Hi everyone! 👋 I have a question for the DSC team (and anyone working on collaborative imaging projects). If you’re willing to share, I’d love to learn a bit about how you approach stacking data from different telescopes and setups. For example, comb...
Directly addresses stacking data from different telescopes and cameras in PixInsight.
Mar 17, 2026
PixInsite Confession
Some of you my know that I’ve been very much a Siril user and a big believer in free software. With the addition of the great tools in SASpro and scripting in Siril I felt like I had everything I might possibly need to create good images and as long ...
Author switched from Siril to PixInsight; discusses PixInsight capabilities and workflows.
Mar 13, 2026
Hi everyone!
Hi to everyone. Visual astronomy since 1991 and astrophotography since 2023.
Image processing technique for astrophotography data analysis and stacking.
Nov 6, 2025
