Unusual R-C Light Leak - HELP!
11 replies223 views
Gary Seven avatar
I have an unusual light leak problem with an iOptron (GSO clone) 10" truss tube R-C. There is a severe lightening in one of the corners.
- It is only visible in Red and Luminance. Absent in any other filter position.
- It is absent with the same camera and filter wheel on my Takahashi Epsilon.
Has anyone seen this before? Ideas?
I would be more concerned about the stray light from an off-side star if I were you. When I get a bright corner (or side) is usually some stray light from the neighbours' security light (thanks so much!).
SonnyE avatar
Not having a truss type RC, I have seen where many use a shroud on theirs, which could help control stray light.
Much like my dew shields do for my refractors.
If you could do a live view you might be able to move a shade around to find where the light is coming from.
Like Andrea sez, maybe a neighbor or even some more distant light source is buggering you up?
Brian Puhl avatar
Red light in the corner, probably coming from a red light on your mount, or something bright and red near the scope. Seen it before.
andrea tasselli · Mar 13, 2026, 04:13 PM
And it should be noted that if there’s a security camera nearby it’s illuminating the area in the near Ir 24/7
Gary Seven avatar
andrea tasselli · Mar 13, 2026 at 04:13 PM
Definitely stray light source - but my neighbor is also an imager - he is exonerated ;-)
I’ll start taping all of those LED’s in the dome.
Gary Seven avatar
SonnyE · Mar 13, 2026 at 05:15 PM
Ordered!
Over on the CN Cass & Casses forum, users are installing flocking paper in their baffle tubes and praise it highly. I own such a scope and ordered the paper, but have yet to install. I will try it in the R-C first.
Well written Concise
Gary Seven avatar
Brian Puhl · Mar 13, 2026 at 06:31 PM
I just processed my M97 data - the project was 90 minutes shy of my desired exposure time in H-a and Oiii, but I wanted to see if the problem was present in that data.
And it is in both H-a and Red. Minimal to nothing in Blue, Green, and Oiii. Hopefully MSG and DBE can tame it.
I think the camera and filters are cleared. I spent all fall and winter with the f/3.3 Takahashi in the dome, zero problems. The issue is the baffling of this scope.
SonnyE avatar
Gary Seven · Mar 13, 2026, 08:50 PM
I friend of mine has/had a truss type RC and his problems were quite baffling… His seemed to take as much maintenance as a B-1b bomber.
But when it worked, Ooh La La, what a great picture!
Hope it works out for you!
Supportive
Gary Seven avatar
SonnyE · Mar 13, 2026 at 10:01 PM
I suspected that scope would be a project from the start …
Did a test last night after locating every source of light - any color - in the dome and applying black electrical tape to them.
No change, perhaps even a bit worse. That shroud can’t get here fast enough. Also will look at flocking the inside of the baffle tube.
Well written Concise Engaging
Tareq Abdulla avatar
I also have RC10 truss type GSO rebranded [TS Optics], i bought it with a shroud, but i ordered a baffle 3D printed that came with one teeth for mounting as broken, so i won’t use it unless i buy another one, i didn’t bother for replacement and it wasn’t expensive to ask for refund, all that just to make sure i have less light leak problem if possible, i hope to find a good material baffle, and also i need to replace the focuser and get a mount for it then i will see if i can see any issue in my data results.
Gary Seven avatar
Yesterday I installed adhesive flock paper in the baffle tube. The dimensions are 60mm diameter by 180mm length.The material was cut into three strips with slight overlap, and pressure was applied with a wooden dowel rod. The baffle interior has concentric ridges (micro knife edges) down its length. That reduces the surface area for the adhesive so periodic checks will have to be made.
I will not be able to closely examine the subs until Wednesday. However, watching images during capture does show improvement- but probably not a fix. No ill effects were noted.
The shroud I ordered should also arrive on Wednesday.
