Any suggestions: trouble achieving sharp focus with Edge HD
Alexander BouwmanJohn Tuckerandrea tasselliMichael Gorman
48 replies831 views
Alexander Bouwman avatar
Recently I bought a second hand Edge HD 8. The tube was bought 4 years ago and in very good shape. Collimation is - as far I can see - all right. My main problem is: I can’t find good focus. Recently I captured the moon and Jupiter . Although PixInsight helps a lot, I think the telescope can do much better. I also have a 80 mm refractor and no problem there, as you can see in my gallery.
I also switched mount. De Edge HD is standard mounted on a NexStar Evolution. Last night I used my HEQ5 Pro voor the Edge, but no big difference. I use a ASI ZWO678MC camera.
Has anyone got some advice? I started AS one year ago, so I’m relatively new.
For reference I have attached some pictures of the moon, Jupiter and a star out of focus (where you can see the collimation).
📷 20260304 Maan v1.png20260304 Maan v1.png📷 20260308 Jupiter v1.jpg20260308 Jupiter v1.jpg📷 IMG_2517.jpegIMG_2517.jpeg
If you can reach focus on a star and move beyond it then you should be able to get a decent focus. Please share a pic of your set-up for planetary imaging.
Gamaholjad avatar
I found this really usefull, you need a bathinov and tri mask. Your not a millions miles off collimation, I found ocal3 fairly successful. https://youtu.be/jF6cVNhFFps?si=L4YNcgoirllfsLAg. Enjoy your edge iv had mine for 6 years.
Also if you live in UK Celestron uk will collimation and clean for a fee. Good luck
Supportive
andrea tasselli · Mar 9, 2026 at 10:04 AM
Hi Andrea, focussing on a star is also a problem, although the Bahtinov was ok (I think). Stars keep blurry and in the ASIAIR starsize was not below 8.
This is the setup I used yesterday. Do you mean a photo like this? The image of Jupiter was taken with this setup (120s video, stacked with AutoStakkert).
The ZWO ASI 678Pro is connected to the Edge with the standard 1,25” nosepiece, no extra spacers were needed. I also use a rotator.For one video al also used a 2x Barlow, same problem with the focus.
Thank you for your respons.
Gamaholjad · Mar 9, 2026 at 10:28 AM
I found this really usefull, you need a bathing and tri mask. Your not a millions miles off collimation, I found ocal3 fairly successful. https://youtu.be/jF6cVNhFFps?si=L4YNcgoirllfsLAg. Enjoy your edge iv had mine for 6 years.
Thnx, I will take a look and keep trying. I live in the Netherlands and can try to contact the store where it was originally bought. It is Ganymedes, one of the better shops in the Netherlands.
Are you taking the scope from inside your home to the back-garden by any chance and if so how much are you waiting for cool down.
ArchStarGazer avatar
Did you check whether backfocus distance (133,35 mm without reducer) is met by your setup?
Well written
That has nothing to do with reaching focus.
ArchStarGazer · Mar 9, 2026 at 10:55 AM
Thank you. I think this is ok, because I can go in and out of focus with plenty of ‘space’ left in the focusser.
Respectful
John Tucker avatar
Good summary of how to test and align the optics of an SCT here. In your case the adjustment process will be slightly different because it’s an Edge. But I’ve done this entire procedure except for the “spinning on a jig” part, and I’m a complete idiot. So it should be easy.
https://www.wilmslowastro.com/tips/c14_optics_alignment.html
John Tucker · Mar 9, 2026 at 11:32 AM
Thanks, I will take a look! Seems like a serious procedure, will see if I feel comfortable enough to do this. Maybe as a last resort, if the problem stays.
andrea tasselli · Mar 9, 2026 at 10:48 AM
Yes, I take I from inside my home to the garden. But I always wait for at least one hour. Yesterday even longer: the Edge was outside around noon and the imaging was ten hours later. I also use a dewheater or a dew shield. Yesterday I used the dewheater and connected is two hours before shooting.
John Tucker avatar
Alexander Bouwman · Mar 9, 2026, 11:57 AM
I guess my other suggestion would be to check your collimation a little more rigorously. Does the donut stay symmetrical when as you get closer to focus? When out of focus do the non-centered donuts all “lean” toward the center of the field of view, or do they aim toward some other spot?
I don’t know how true this is of the Edge, but for the lower end SCTs there is usually a preferred arrangement of the secondary mirror and of the corrector plate relative to the tube axis. (Actually it’s a preferred relative rotational arrangment of the primary and secondary mirrors).
If you simply remove the retaining ring that holds the secondary in place and examine the corrector and secondary mirror, you should find some sort of mark on each. Note the current rotational arrangement and then try aligning the marks on the secondary and corrector plate with any mark you see on the tube. If there is no mark on the tube, try aligning the marks with the focuser knob.
Anytime you partially or fully disassemble an SCT, take pictures with your phone and make marks with a pencil or sharpie that ensure you can put it back together exactly as you found it, including the rotational angle of the parts in the tube.
Well written Supportive
Scott Badger avatar
Maybe just poor seeing? Looks like it from the ‘donut’ image. The shorter focal length refractor wouldn’t be affected as much.
Scott
Well written Respectful Concise
Paul Larkin avatar
Hi, Alexander.
John mentions checking that the corrector is correctly positioned. For ages, I was able to get great doughnuts collimating my Edge HD8 but still had misshapen stars.
When I removed the ring around the edge of the corrector, I noticed that there were indeed markings, and they were not lined up. No idea why. Anyway, I realigned the corrector, collimated again and now have nice round stars.
Yours is a focus issue rather than misshapen stars and may have a completely different cause (or causes) but I suspect it’s worth checking.
Cheers.
Paul
Paul Larkin · Mar 9, 2026 at 01:28 PM
Hi, Alexander.
Cheers.
Paul
Thanks, seems like a simple check. Will definitely do this one!
John Tucker · Mar 9, 2026 at 12:11 PM
Thanks, will try this one. And I will take pictures before changing anything, good one!
Respectful Supportive
Scott Badger · Mar 9, 2026 at 12:38 PM
Scott
Hi Scott, that’s also a possibility. The pictures I took of Jupiter with my 480mm refractor were much better in terms of focus and sharpness. Seeing conditions are indeed not optimal where I live (Netherlands, near German border).
Will do some checks as suggested by others and see what I can do.
Cheers!
Alexander Bouwman:
It could be either the dew strip (which should never be brought to the maximum) as well as thermal currents inside the tube. Or you have really bad seeing, whether local or atmospheric I can't speculate. I can't believe that the sort of mis-collimation you might have and that isn't a lot judging by the Fresnel ring would cause such a issue wit focusing.
John Tucker avatar
Alexander Bouwman · Mar 9, 2026, 01:42 PM
The secondary is inside a cell that fits in a hole in the middle of the corrector. It is possible to rotate the secondary cell within that hole while holding the corrector position constant.
So there are two issues:
  • Is the rotational position of the corrector relative to the tube (and thus the primary mirror) correct?
  • Is the rotational position of the secondary mirror relative to the tube (and thus the primary mirror) correct?
These can be adjusted independently. My understanding is that of the two, the rotational orientation of the secondary mirror is much more important.
Be very careful to mark the secondary, corrector, and tube so that you can put it back together the way you found it in case you can’t find the markings I described.
It is also possible to test for this by trial and error if you can’t find the markings. Rotate the secondary 30 degrees or so and put the OTA back together. Recollimate. See if things improve or get worse. Rinse and repeat. Its tedious but possible.
While you have the corrector assembly removed from the tube, you might put a laser in visual back and lay a meter stick across the open end of the tube to assess whether the baffle tube is aligned with the axis of the optical tube. There are some other tests you can do while the corrector is removed that are described in the link I posted above. They are relatively easy to do and don’t involve the more difficult and complex operation of removing the primary mirror.
If upon removing the retaining ring you find that the corrector plate is stuck and difficult to remove, you can warm the points of contact with the optical tube with a blow dryer.
John Tucker avatar
Oh, 2 more things. Don’t lose track of which side of the corrector points “in”. It’s not obvious simply by looking at it.
And if you decide to clean the secondary or the corrector while you have them off, be sure you don’t clean off the marks that show you how to place it back in the tube. I’ve done that! 🤣
John Tucker · Mar 9, 2026 at 02:45 PM
Hi John, thank you so much for this comprehensive answer. I will read it closely and see what I can do - and what feels comfortable. Reading other reactions, it can also be a combination of factors: slight misalignment, poor seeing and internal thermal issues. Let’s find out.
Clear skies!
John Tucker · Mar 9, 2026 at 03:03 PM
That’s a good one. Although: over-enthusiastic cleaning is not one of my strong points 😎. But I will keep this in mind!
John Tucker avatar
Alexander Bouwman · Mar 9, 2026, 03:43 PM
Clear skies!
One thing that might be helpful for assessing this is to get an average star size measurement (FWHM) before you touch anything to get a quantitative picture of where you are. This can be used as a baseline for before/after comparisons if you change anything. If you aren’t using acquisition software that does this, you can always run a sub or two through Deep Sky Stacker. It will generate an average FWHM for each sub and add it to the table.
You’re going from an 80mm aperture to an 200mm one. There’s a world of difference as far as seeing is concerned. Assuming the 8” is well collimated and of good optical quality (not a given) it will give sharp images under good seeing but really bad seeing, which will hardly effect the little 80mm will have a huge impact on the larger aperture. When focusing you’ll seem to mush through the zone of best focus and the image never snaps the way it does in the small refractor.
Before going off the deep end I would make sure you have a night of good seeing with the scope fully cooled down and well collimated before doing anything else. There are many weather sources that will predict this and you can tell yourself by just observing how steady the stars are with the naked eye.
Bottom line, you can get away with a lot with small refractors, part of reason they are so popular. Larger apertures are simply more demanding. There’s also the possibility that the OTA is just a “mush dog”. Commercial SCT’s can vary widely in optical quality. You mentioned you bought this used. I hope it’s not the case but most people who have a good one, tend hang on to it.
Well written Helpful Respectful Engaging
Thoughts on my collimation of 9.25 sct
Focus sharpness issues relevant to achieving crisp results with SCT.
Sep 23, 2025
Help with RH200 halos/reflections
Hi, I recently bought an RH200 MKII. The telescope looks like new and, after some minor tweaking (I still need to fine-tune the collimation), it delivers a very nice, flat field across my full-frame ASI2400. So far, so good. However, I’m seeing some ...
Optical issues with reflector telescopes; collimation and focus problems relevant.
Dec 18, 2025
Rare pattern stars on samyang 135
Hello. I purchased from second hand this lens a few weeks ago but I have not been able to test it until these days. I'm noticing some very strange patterns in the stars, like a rhombus or teardrop shape. I have previously the same lens but I have...
Second-hand Edge HD focus issues; you have second-hand lens with star distortion.
Dec 2, 2024
Shifting primary mirror
Hi All I hope that you have some experience that can help me here. When I image low on the horizon, my stars are not good📷 image.png Near Zenith - same star. 📷 image.png Yesterday I realised that my Primary mirror shifted - and that most likely was t...
Primary mirror problems could explain focus issues on Edge HD.
Mar 6, 2026
Hocus Focus in NINA with an RC
I used to use a refractor and not having a problem with my AF. I have since bought a RC and had way more problems. The problem seems to be that when the RC defocus enough (donuts appear), HF thinks that the HFR is smaller and starts chasing "fal...
Troubleshooting sharp focus achievement with EdgeHD 8 telescope.
Sep 1, 2024
