Bright band at bottom of images with Canon 6D
12 replies204 views
Cameron Stout avatar
  • Rosette Nebula
  • Camera: Canon EOS 6D
  • Scope: Askar FRA300.
  • Guide Camera ASI120mm
  • Guide Scope SVBONY SV165
  • Dithered 30 pixels every 5 frames
  • Captured using ASIAir.
  • 73 thirty second exposures at ISO 1600.
  • Stacked and processed the fits files from the ASIAir in PixInsight.
  • My location is a bortle 6/7 neighborhood.
I am trying to figure out what is causing this bright band at the bottom of my image. I can’t seem to process it out, except if I crop it, but I’d rather not have to crop out that much of my image every time I use this camera and scope set up.
This also happens if I use a camera lens with this camera, and it does not happen if I use my ASI585MC with my FRA300, so I know it is specific to the 6D camera. The camera lens I used was an 85mm lens set at f2.3.
The image I attached has been calibrated with darks, flats, and dark flats, but this band shows up even if I don’t use calibration frames.
Have any of you experienced this before? If so how did you deal with it?
If I am missing any information please let me know. Thank you for reading and clear skies!
📷 rosette with light band under 5mb.jpgrosette with light band under 5mb.jpg
Well written Respectful
Probably a stacking artifact, not uncommon at all. You are moving the frame around with drizzling and doing it by 30 pixels is a lot. A much smaller movement, 5 to 10 pixels, would suffice.
Well written Helpful Respectful Concise Supportive
Tony Gondola · Mar 8, 2026, 05:19 PM
This happens even if I do not dither. When I used my 85mm lens I didn’t guide or dither and the band was still there.
Also, it happens regardless of how many sub exposures I take. I only did a short session this time, but if I have 3-4 hours worth of data the artifact is still just as bright.
Miesilmannimea avatar
The issue is well known – it is the shadow of the mirror mechanism, or even the mirror itself, cast onto the converter. The shadow is very subtle – it is not visible in normal photography, but in astrophotography, where you are pulling out a weak signal, it is already visible. Check the mirror mechanism – does the mirror definitely rise all the way to the top, or could it go a fraction of a millimeter higher?
If the high of this strip is perfectly repeatable, a flat will fix it :)
Miesilmannimea · Mar 8, 2026, 05:53 PM
Here are some pictures of the mirror box and sensor. The mirror snaps up to those small foam pads and I don’t really see how it could go any higher.
Also I do use flats. I use 50. The band doesn’t calibrate out. Unless my flat taking method has a flaw. I put clean white cloth tight over the objective, and I put my ipad on top of that and use the auto exposure feature in the ASIAir. That method works with my ASI585MC, so not sure why it would not also work with my Canon 6D.
Canon eos 6D sensor - Imgur.jpgCanon eos 6D sensor - Imgur(3).jpgCanon eos 6D sensor - Imgur(2).jpgCanon eos 6D sensor - Imgur(1).jpg
It is as Tony said. If there is no or little signal this sort of things happen. Especially if you use scripts.
Well that eliminates that. It was just the first thing I think of coming from the Astro camera world. As your flats didn’t fix it, it might be the only option is to crop it out. You’ve got a huge FOV so IMO you really aren’t loosing much.
I guess in the end it isn’t that big of a deal. If I crop it all away and maintain the same aspect ratio I only lose about 12% of the image. Still, it’s a shame and I’d rather keep those pixels 😔
SonnyE avatar
Cameron Stout · Mar 8, 2026, 06:47 PM
Why? Why not crop it away?
What do you think you’ll be missing?
This kind of stuff is why I encourage using astro cameras for astro images. The right tool for the job, IMHO.
A 30 pixel dither seems large to me, also. My typical is 10.
bigCatAstro avatar
SonnyE · Mar 10, 2026, 06:49 PM
I agree, I would crop the image and go from there. If you have a camera repair store where you’re located, you might want to have them take a look at the camera and make sure all the mechanisms and the mirror are aligned.
On the longer term, I would also recommend moving over to a dedicated astro camera.
Well written Respectful Concise Supportive
Getting a cooled astronomy camera is in the works! Just need to save up a bit more before I pull the trigger. In the meantime I’m really enjoying using my 6D, and I really appreciate the wide FOV. I’m looking forward to getting a cooled astro cam but there’s no way I’ll be able to afford a full frame.
Seizal Bong avatar
That's a great shot of the Iris Nebula! The colors and the dust details are really coming along. If you're still fine-tuning the processing, one thing that helps me when I'm stuck on the color balance is to grab the HEX codes from a similar "Reference" image on AstroBin that I really like. I've been using this tool lately to pull the exact palette from my favorite AP shots: https://thetoolapp.com/color-palate-extractor-online/. It's a quick way to see if your blues or magentas are hitting the right saturation levels compared to the "pros."
Keep at it, the depth you've captured in the dark nebula parts is already looking solid!
Scott Stirling avatar
Cameron Stout · Mar 8, 2026 at 06:47 PM
After meridian flip you’ll also get that shadow of low signal on the opposite edge of your images because the shadow does not flip with the target. This is why I and others with 6Ds opt to remove the mirror. I’ve done it based on a video I googled: https://www.markshelley.co.uk/Astronomy/Projects/Mirrorless/canon550mirrorless.html
My results were imperfect at first because I broke the mirror on one side and got tiny shards on the sensor. But with manual cleaning it’s been fine and no more mirror shadow. Also have to block the viewfinder, and of course disable LiveView when shooting with a 6D. I still have my modified (for Ha as well) 6D but my Canon Ra is built from the factory even better, mirrorless and Ha sensitive and no viewfinder glow.
NOTE: this issue with 6D mirror shadow is specific to fast scopes and astrographs at f/5 or faster with light cones that the 6D mirror clips on the edge opposite from the mirror, which recesses flat against the roof of the camera chamber.
Well written Helpful Respectful Engaging Supportive
Help - Vertical bands - Flats is the culprit - Can someone help me understand what's happening ?
Hi, Recently I am noticing some weird band like structures in my images. My setup - QHY600PH-M + Takahashi Epsilon 180ED + Astronomik Filters. I Captured RGB images in QHY 2CMS-1 Readout mode at 56 gain for broadband images. (mistake) After noticing ...
Vertical bands in images; flats troubleshooting relevant to bright band issue.
Nov 23, 2025
Odd Horizontal Thick Line Artifacts
Hello. I’ve reached a point of frustration and I’m unsure how to proceed. I have some image stacks that show up with these odd looking horizontal “lines. I cannot figure out what is causing it. I pre-processed in WBPP using lights, darks, bias, flats...
Horizontal line artifacts similar to bright band problem described.
Mar 13, 2026
Dark vertical streaks in stacked image
I've been struggling with trying to understand the source of these streaks I see in some recent stacked images. I'm hoping someone here can offer an idea as to what the source is. I'm hoping it's not the camera itself. My set up is a ...
Stacked image artifacts; streaks may relate to bright band cause.
Aug 21, 2025
