Lukas Bauer Ā· Mar 5, 2026, 08:44 AM
Hi everyone!
I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very saturated (half the pixels were just violet and a the other half were just green). I stopped capturing and went on to take the flats and flat darks. I have always used the sky to take my flat frames and everything went smoothly (with my old DSLR). The flats are also great to shoot with the new Camera.
But when it got to taking the flat darks things got strange. I put on the telescope cover and covered the whole telescope with the camera and everything with a blanket. That way I should eliminate any possible light rays getting into the image train. But the darks don't look like the usual darks. Instead, there is a very noticable gradient, as you can see in the attached picture.
Afterwards I also tried taking bias frames like usual (same setup with blanket). As you can see in the second picture the bias frame also doesn't look like a bias frame should look like.
For both the dark and bias frames I reduced the gain and offset of the camera to 0 (when shooting lights I use gain: 125 and offset: 25).
Does anyone have a idea what could cause the very strang looking dark frames and bias frames? Has anyone else had this issue before and how did you fix it?
Thank you very much in advance!
Lukas
Lukas, I think your main problem was a light leak when taking your darks.
I know that when you were shooting with a DSLR you needed to take darks during the session because of the lack of temp. control. Now that you have a cooled camera, you donāt need to do that anymore. The best approach is to pull the camera from your rig, cap it to totally eliminate any possible light leaks and methodically build a library of dark frames. Pick a temp that youāll always use, -10 is a common setting. Take twenty frames for every exposure time you are likely to use and stick em in a folder. Going forward there will be no need to take darks at the scope at all. Just pull as needed from the library.
On flats, these are going to be stacked in your processing program to make a master so as long as they donāt vary by much more than 15%, youāll be fine. Sky flats are a good idea and super easy. If you use NINA you can use the flat wizard whish will compensate if the sky brightness changes to much. You can even automate the taking of sky flats as part of your imaging sequence. I always have the camera cooled to my standard shooting temp when taking flats but Iām not sure thatās necessary.
True bias frames are done with the shortest possible exposure with the camera capped. The camera doesnāt need to be cooled. You can do them when you make your dark library.
Thereās a lot of confusing talk on this thread about dark, dark flats, flat darks with tarter sauce. A lot of it comes from the needs of different processing programs and sky conditions.
I would suggest starting with the basic calibration frames your program needs to start with and press on with imaging.
