Photon_Collector avatar
Budget is ~$10k, looking to set up a remote (bortle 1) relatively fast imaging system with medium/long focal length for up close nebula shots and galaxy hunting.
I’m thinking one of the following:
  • Celestron C14 Edge HD (slowest, highest focal length)
  • Planewave CDK 12.5 (slower, high focal length)
  • Askar SCA 310 (Fast, medium focal length)
There are clear benefits/drawbacks to all of these, just curious what any users think.
Well Written Concise Engaging
To my mind this is really and apples or oranges choice. Of the two long FL instruments and since you’re going remote (deep sky imaging only) I would go with the CDK. It’s going to give you better overall optical performance.
The Askar isn’t anywhere in the focal length class of the other two.
Sergey Rakov avatar
I think relevance of long fl is waining with the demise of large-pixel CCD sensors. Check local seeing against pixel scale of desirable system first. Oversampling factor of 3+ wont result in better images, however slow light gathering power will be clear loss. I’ve chosen parabolic mirror with newtonian-type reducer in prime focus, without secondary. Works extremely well. Also, things like Delta Rho from Planewave or OS Veloce are worth considering IMO.
Sergey Rakov · Mar 3, 2026, 04:45 PM
That’s interesting and I’ve often though about trying it but I worry about three things:
A large central obstruction
Odd diffraction patterns from cabling
Heat from the camera disturbing the wavefront
How have you mitigated those effects?
I would also wonder how you deal with focus and filter changes?
John Tucker avatar
It’s quite possible that I’m just displaying my ignorance here, but I’m not sure I understand the appeal of ultra long focal length telescopes.
With a 14” Celestron Edge OTA (focal length 3920 mm) and a typical 3.5um pixel camera, you’re going to have 0.2 arcsec per pixel at F11. You’ll be lucky if seeing is 0.8 arcsec. So on a typical day it seems like you’d get pretty much the same results with an Edge 9.25 (focal length 2350, 0.33 arcsec/pixel) after cropping.
The 14 inch Edge costs about $3K more, and given that it weighs 45 lbs vs 23 for the 9.25, you’ll probably end up spending an extra $3K or more for a suitable mount, and maybe higher monthly fees at the hosting site. If you end up unhappy or leave the hobby, the 9.25 will be a lot easier to sell.
Well Written Helpful Respectful Concise Engaging
Sergey Rakov avatar
📷 IMG_4540.jpegIMG_4540.jpegI will try to address your concerns
Central obstruction from camera and corrector is actually less then secondary, required for 17” f3,5 will produce. The larger issue is with filter wheel. I previously used ZWO mini and consequently imx533 small sensor camera - since I mostly were interested in galaxies it was viable compromise. Later I’ve obtained custom double-carousel wheel for six 36mm filters (actually there is 8 slots, but 2 need to be empty) and managed to install larger imx571 sensor without expanding CO at all. Theoretically, even 6×50mm wheel of this type won’t present significant CO for mirrors close to 20”.
Cables are routed along the spider and don’t cause any additional diffraction spikes. Somewhat offset CO also doesn’t seem to affect spots in meaningful way.
Focuser is 3” custom, works by moving corrector assembly. EAF is used as drive part.
As to thermal interference (besides camera I have heated baffle for corrector lens) - I had my doubts, but in practice turning heated/cooling on never produced adverse effects on FWHM. Possibly with comparatively short (1,2m) FL it’s not an issue. With RASA it seems fine as well
Craig Towell avatar
John Tucker · Mar 3, 2026 at 05:48 PM
Well personally I wouldn’t use a long FC cat like that, I’d employ binning to bring it up to a more sensible imaging scale and speed the system up dramatically.
A C14 imaging at bin3×3 will be 900% faster than a C925 unbinned with the same camera (on extended sources)
Of course your overall image size will be severely reduced, but if your targets are small PNs and galaxies that shouldn’t be an issue
Craig Towell avatar
Photon_Collector · Mar 3, 2026 at 03:54 PM
If I was in your shoes I’d get the CDK, pair it with a full frame camera like a 6200 and run it binned. X2 in good seeing for luminance and x3 or even x4 in poor seeing or for colour.
You’d have decent aperture and a lot of speed with the binning, and great focal length for those tiny targets. The CDK should cover full frame nicely.
The C14 would be nice but I think the CDK would be easier to use, and the askar just doesn’t have the FL for those targets.
Well Written Helpful Concise Engaging Supportive
Sergey Rakov · Mar 3, 2026, 05:56 PM
Thanks for giving the close look, always interesting to see what can be done that’s a little different.
Rick Krejci avatar
Craig Towell · Mar 3, 2026, 06:38 PM
With modern CMOS cameras with low read noise, I wouldn’t bin at all unless you just want smaller file sizes assuming you’re sky background is well above the read noise floor. Binning at image time is identical to resampling in post unlike the CCDs of old.
I’d rather re-sample in post and choose the resampling amount that gives you star and object detail which may not be what binning gives you. Depending on seeing, that may be 0.8x, 0.5× 0.4x…whatever you think looks best. And you may have better seeing than expected, but binning is irreversible. Deconvolution like BlurX also works better with oversampled raws and then downsampling as well.
Well Written Helpful Insightful Respectful Engaging
Craig Towell avatar
Rick Krejci · Mar 3, 2026 at 08:34 PM
Yeah that is kind of what I meant but I wasn’t clear… with cmos I would also just capture in bin1×1 and then resample in post
Dan Watt avatar
I am a bit biased as I build them but a clean and simple newt with premium mirrors and a conventional diagonal and focuser would do the job well with minimum fuss.
12.5” f4 with a Paracorr brings it do f4.6 with a focal length of 1460mm. With the 3.76 micron pixels the popular cameras use this will put you at .53 arcsecond per pixel. You’ll be seeing limited in most locations and even if you’re got it parked at a spot on the pacific coast, you’ll still be seeing limited most nights.
It could also support a full frame camera if you go with a 3” Big Paracorr and 3” focuser.
SonnyE avatar
I don’t see any cloud proofing.
Does your idea include cloud proofing? (Other than the clouds can freely drift through the cage….)
alpheratz06 avatar
A bit above stated budget, though…
Tobiasz avatar
Out of three I would go with the CDK.
The FoV might be on the smaller side with that focal length of the EdgeHD 14, but it depends on the size of your objects you want to image. On top of that I would expect the CDK to be the more convenient scope (open tube, less dew, wind and ventilation concerns). The Edge has still more aperture, though.
(Target is the Owl Nebula)
The Askar looks like a nice scope with a way bigger FoV which should be nice for wider fields. But for smaller targets you will be cropping a lot.
For me a No-No is the backfocus of the scope itself. Depending on your setup you can’t even install a mono system with an OAG. (38-66mm)
Edit: I checked the optical efficiency of the CDK vs the SCA310 and the CDK12.5 collects 1.44x more photons than the SCA310.
I assumed/looked up the following parameters:
SCA310:
Mirrors with 95% reflectivity
Corrector with 3 lenses with 99.5% transmission each
62% obstruction
Source: https://www.teleskop-express.de/en/askar-sharpstar-173/flatfield-cassegrain-telescopes-319/sharpstar-sca310-310-mm-f-3-8-aspherical-cassegrain-astrograph-19390
CDK12.5:
Mirrors with 96% reflectivity
42% obstruction
Source: https://www.planewave.eu/produkte/teleskope/cdk125-astrograph-f/8-mit-quarzglas-optik
📷 grafik.pnggrafik.pngSource: https://lambermont.dyndns.org/astro/code/compare-telescopes.html
Well Written Helpful Engaging Supportive
Bill McLaughlin avatar
Disagree because there are two things that make modern image enhancement more effective. One is contrast and the other is sampling. Better sampling (up to a point) makes techniques like BlurX work better and more accurately and longer focal length means better sampling, all things being equal.
It should also be said the most important point in choosing your system is and always will be (for high res images) the seeing at the site in question. The system needs to match the seeing and the best scope ever in darkest sky ever with only average seeing will be a waste for high res. I would not even consider putting a long focal length system at a site that does not have occasional seeing in the one arcsec range and is regularly under 1.5.
So if the observatory operator has a seeing monitor (and any good operator will), then ask for those records or contact another long time and experienced long focal length imager at the site and use that information to inform your choices.
Well Written Helpful Insightful Concise Engaging
John Hayes avatar
I’ve owned and interferometrically tested both C14 Edge systems and a 20” CDK system so I can say a little about both of them for imaging.
1) Edge 14
PROS: These systems can be diffraction limited. The overall system wavefront is smooth and the field is very well corrected. Good optical alignment is very easy to achieve and if you don’t mess with it, the system will hold alignment fairly well. These are the least expensive telescopes for the aperture so they can represent excellent value. The plate scale is actually very good for galaxy imaging and there are a wide range of accessories available for these scopes. Vignetting is “reasonable”—even up to a 36 mm x 36 mm sensor. Since the secondary is supported by the corrector plate, there are no diffraction spikes.
CONS: The optical quality appears to be quite variable. You may get a good one and you may not. You’ll only know when you set it up to try it. The hardware is inexpensive black oxide screws made of soft metal so screws may be easy to strip. The mechanics are marginal. Focusing with the primary mirror introduces image shift so you may need an external focuser. The factory dovetail is way too flimsy for serious imaging so it should be replaced with something more solid.
2) Planewave CDK Scopes
PROS: These systems have a diffraction limited design over a very wide field and can produce excellent imaging. They are easy to optically align and they have excellent mechanics with high quality hardware. Factory support used to be outstanding; however, things have recently changed to a support ticket system. Hopefully, the factory is keeping up and support quality is unchanged.
CONS: The optical quality appears to be quite variable. I’ve seen a number of Planewave telescopes that have had to be replaced because of poor optical quality. Even the good optics that I’ve seen tend to suffer from excessive mid-spatial frequency wavefront errors that can affect overall image quality. This is a complicated way of saying that the optical figure is not very smooth. To be fair, I have not tested very many PW telescopes; however, the mid-spatial frequency wavefront errors are typically produced by the way that PW makes their optics. Because their fabrication methods don’t allow figure control all the way to the edge of the glass, the primary mirrors are equipped with an aperture mask. Sometimes that mask does not completely hide the errors at the edge of the mirror and that results in problems with excessive SA, which appears to be a recurring problem. The good news is that PW has been VERY good about fixing problems with the optics when they occur. Beyond that, price is the only other “downside.” PW telescopes are more expensive than Celestron telescopes but they also have higher mechanical quality with fused silica optics and a carbon fiber truss.
If you get good optics, either of these telescopes can produce outstanding results. I ran an Edge 14 in NM for about 5 years and a number of images from that scope are still on display in my image gallery if you want to check it out. I also have test reports for my CDK20 in my AB gallery and if you search Cloudy Nights, I posted two detailed test reports for interferometrically testing two Edge 14 telescopes. As I recall, one of them achieved a Stehl of 0.92 so it was quite good.
Sergey Rakov avatar
Bill McLaughlin · Mar 7, 2026, 03:11 PM
“Up to a point”, yes. With modern 3,76nm pixels, C14 telescope, for example, will produce resolution of 0,2” per pixel. Considering typical average seeing of somewhat above 1”, even at most desirable imaging locations, it is way too much oversampling. To my experience 3x oversampling factor is already excessive, BlurX will get no extra data, just some fantasy filaments perhaps.
JohnAdastra avatar
Photon_Collector · Mar 3, 2026, 03:54 PM
C14 - Closed system, easy to collimate, remains dust free inside for decades. Check out presentation by Bob Majewski on TAIC for optics analysis.
CDK 12.5. Open system, cools faster, can collect dust or spider webs depending on location. Collimation of these scopes is an art that needs to be learned.
SCA 310 - I think you meant Sharpstar, not Askar. I think these optics as advertised are too good to be true. Collimation is the hardest, and sometimes doesn’t work at all. I’d go with a RASA or a Celestron SCT with Hyperstar accessory. Hyperstar can be added or removed, so two scopes in one. F2 systems also require patience and time to collimate well.
Bortle 1 will give nice results only if the local seeing is good, like approaching 1 arcsec. Otherwise long focal lengths will not be utilized to their fullest.
Good luck!
John Hayes avatar
JohnAdastra · Mar 8, 2026 at 07:46 AM
C14 requires tempest fans to control baffle plumes and internal temperature gradients. It will stay cleaner on the inside than other telescopes; but not for decades. I saw both dust and a film form on the primaries of my C14 Edge systems after less than a year. Yes, they stay a bit cleaner but they are also more complicated to clean when they get dirty because you have to remove the corrector plate to access the internal optics. Over time, the internal field lenses do stay a lot cleaner than in a CDK.
The CDK design uses a spherical secondary just like the Celestron HD design so the alignment is no more difficult on one compared to the other. All you have to do is to minimize on-axis coma to achieve perfect alignment and that’s not hard to do. The magnification of the secondary is a bit different between the two systems so the sensitivity of the systems to misalignment is slightly different but not by enough to matter much. SkyWave makes it almost trivial to perfectly align any CDK or SCT system.
Well Written Helpful Respectful Engaging
JohnAdastra avatar
John Hayes · Mar 8, 2026, 04:36 PM
Thanks John. Wish we could have you nearby when we collimate our RC. There appears to be a range of opinions and equipment for making things right :).
Telescope Build for Deep Space photography
i’m looking for advice on the best deep space Astro photography telescope build with a $4K budget.
Similar deep space imaging goals; higher budget shows comparable equipment tier.
Jan 30, 2026
Photography of nebulae
Will it be possible to shoot reflective/emission nebulae with a Sony Cyber-Shot DSC-HX200V camera and a telescope with an aperture of 114 mm and a focal length of 450 mm? I'm beginner.
Addresses aperture and focal length for nebula photography specifically.
Apr 19, 2024
New to or Considering Astrophotography/astronomy?
I had posted this with a new image I’d uploaded as a change from the “typical” review of my processing steps/acquisition. A friend/commentor suggested I post in a forum, so this is the result. This is VERY subjective and based entirely on my experien...
Relevant for someone considering equipment setup for astrophotography imaging system.
Jul 31, 2025
One year with a CEM 70
One year with the CEM70 exceptional results. Tested at 550 mm and 1624 mm. Smooth as butter. Honestly, coming back into astrophotography after a break felt like stepping out of the Stone Age and seeing a TV for the first time. When I went looking for...
Relevant for mount performance data at comparable focal lengths author is considering.
Dec 7, 2025
