Recommendations for Windows tablet with good battery life for astronomy rig control.
12 replies200 views
Astro Jeep avatar
Currently, I drive to remote sites and run one setup with a Mele computer controlling the rig. I use an iPad Mini via Windows App to control everything. I am assembling a second rig so I can run two setups simultaneously, but I really do not want to purchase another iPad Mini for it. I know nothing about Windows tablets, but I would assume that they are cheaper, and since this will be its only job, it makes sense to me to just get a Windows tablet.
So my question is: does anyone have a recommendation for a good Windows tablet with battery life similar to the iPad Mini?
Thank you!
Darryl
Well written Respectful
Brian Puhl avatar
Why not just run multiple sessions on your iPad? I run multiple scopes and every one of them I can connect and tab between via RDP app. Honestly zero reason to get another tablet.
Helpful Concise Engaging
Astro Jeep avatar
Brian Puhl · Mar 2, 2026 at 01:40 AM
I was thinking that, and I haven’t put much research into whether it’s possible. I spent about half an hour looking into it a few days ago, but I didn’t find anything definitive. Now that I know that it works, that is what I will do. Thank you for saving me money!
Darryl
Respectful Supportive
Brian Puhl avatar
Astro Jeep · Mar 2, 2026, 01:44 AM
Darryl
Depending on how you're running things, you will probably need a travel router, establish a local network, but beyond that it’s pretty simple.
Astro Jeep avatar
Brian Puhl · Mar 2, 2026 at 01:47 AM
Darryl
I run a Starlink Mini out of my Jeep, and it makes a strong network that the Mele has no problem staying connected to. I can even run an Ethernet cable into it from the scope if I absolutely need to. Again, I appreciate the help!
Well written Respectful Concise
Eric Gagne avatar
If you use Nina you could also give Touch ‘N Stars a try. It doesn’t completely replace Nina, you’ll still need the windows app for certain things but once your session is started it is much better suited to the iPad screen than windows app.
https://touch-n-stars.eu/
Windows by its own nature is very battery intensive. Unless you pay a fortune for an industrial grade tablet, I doubt you’ll find anything that can run as long as an iPad or Android tablet.
alpheratz06 avatar
Keep in mind that it is rather simple and inexpensive to put an external battery supply to a tablet to extend its autonomy…
AstroGadac avatar
Astro Jeep · Mar 2, 2026, 01:50 AM
Darryl
Then you won’t have trouble connecting to both Mele PC from your Ipad mini using the Windows RDP app.
In the RDP app you can set up on the main screen different hosts that you connect to with the hostname of the computer (say Mele1 and Mele2). If your Ipad is also connected to this network it should connect without issue.
Refer to part 2 of this link: https://www.avica.com/blog/microsoft-remote-desktop-on-ipad/#h2_0
You may want to disable any passwords to connect in remote desktop though, it makes it easier to switch between computers.
SonnyE avatar
When I was going remote with my Asus laptop, I just used a power inverter in my truck with an extension cord.
Just a 350 watt inverter, plugged into the cigar lighter socket. That way I can run a regular 120 volt AC laptop at remote locations. I use to carry an AGM sealed battery to run my mount. Just left it in the truck and ran wire to my mount.
Just my way to skin a cat. 😉
My laptops battery acts as a buffer in case of any in case of’s.
Astro Jeep avatar
Eric Gagne · Mar 2, 2026 at 02:25 AM
Thank you, I do use NINA. I will look into Touch-N-Stars. I am also pretty sure you are right about the battery life on a Windows tablet. I use Windows to run my CAD program, and that laptop drains the battery fast even when nothing is running.
Astro Jeep avatar
AstroGadac · Mar 2, 2026 at 09:54 AM
Darryl
I have been running one setup this way and haven’t had any issues. I wasn’t sure whether I could run two instances on one tablet via Windows App/RDP, but now that I know I can, I will do it on my iPad. I will read the link you provided and get it set up. Thank you!
Astro Jeep avatar
SonnyE · Mar 2, 2026 at 05:28 PM
I use two EcoFlow batteries, charging them on the go with an 800W DC-DC converter. One runs my refrigerator and Starlink mini along with all the electronics in the Jeep, and the second EcoFlow has been running my astro rig outside. The Ecoflows also provide a buffer and can reverse jump-start my Jeep if necessary.
Well written Helpful Respectful Concise Engaging
SonnyE avatar
Astro Jeep · Mar 2, 2026, 06:01 PM
That was a bonus to my 57 pound AGM sealed battery, it could jump start my truck. LOL!
And at 57 pounds, that puppy stayed in the truck bed. 🦣 Oh my aching back. 🤪
What is a Good Way to Power it from backyard?
Main question is what type of Cables and all do i actually need and could i power via Main or Battery if it's only in my backyard
Addresses battery-powered device control for astronomy setups in backyards.
Jun 17, 2025
AP Control Options from a MAc user's perspective
Brett Joslin To be honest I was feeling discouraged and sort of dead in the water, now you have me thinking. My MacBook is a 2010 (10.13.6) and obsolete for the most part. I'm running an old version of The SkyX which I like and is the only softwa...
Relevant for tablet-based remote control of astronomy rigs at remote observing sites.
Apr 6, 2025
AM3 mount for Solar Eclipse question
Hello, i purchased an AM3 two months ago and I was wondering if it’s recommended i use that tracking mount for the upcoming eclipse. I am using a Canon Mirrorless camera with a zoom lens, but I am not sure if it’s recommended to use this combo with t...
ASIAIR control methods relevant to eclipse imaging with mirrorless camera setup.
Mar 13, 2024
Questions For Anyone Running Two Rigs
I am going to be running two rigs using ASIAIRs, one will be my ASIAIR+ and the other will be a ASI2600 AIR. My question is this, can I run them both off of one iPad running the ASIAIR App? I know there is a switch device under the Wi-Fi menu will th...
Discusses tablet control of astronomy rigs; relevant to iPad/ASIAIR setup question.
Feb 6, 2025
Suggestions for a good battery to power my setup while travelling
Hello everyone. I am looking for a good battery to power my setup for at least one night of imaging, preferably two nights on one charge. I have seen some sponsored youtube reviews of a few batteries, but I am looking for an unbiased recommendation f...
Discusses battery-powered control system for remote astronomy imaging setup.
Jul 21, 2025
