Serious Stray Light Issue - William Optics UltraCat 56
rqfugateJeff Reitzel
26 replies742 views
rqfugate avatar
I’m posting this to see if anyone else has experienced or can verify this problem in their UC 56 telescope.
I received the telescope February 2, 2026 from Agena Astro. The quality control certificate that was enclosed was dated December 5, 2025. The telescope serial number is 250130.
I want to use this telescope with an ASI6200 MM camera and LRGB SHO filter set at a remote site. I also want to use a rotator. I live in Phoenix so the initial testing was done in a Bortle 9 sky but I was interested mainly in what the stars looked like in the corners and edges.
I early test exposures I noticed stray light in the form of concentric arcs. I eventually identified the source of the stray light as bright stars positioned 3-4 degrees off the long end of the full frame sensor, approximately 7 to 8 degrees off the optical axis of the telescope. For really bright stars I could see the arcs in short exposure plate solving images.
I removed the filters and rotator and replaced them with M54 extension tubes to maintain 55 mm of back focus. The stray light was still there but there was only one ring. I tried two other cameras, a Nikon Z6 mirrorless and a Nikon D850 DSLR, and the stray light arc was exactly the same size and shape. My thought was the stray light was being generated in the telescope optics.
I put a flat panel in front to the telescope, and removed everything from the back of the telescope except the WO provided M54 adapter that screws into the back of the telescope. When I looked into the back of the telescope, I was shocked to see a bright ring well past the exit pupil of the optics - first attached photo.
On close examination of the last element of the telescope optics, I was able to confirm the bright ring was being created by a reflection from the inside wall of the aluminum lens mounting ring. This rear ring is anodized but it has not been blackened or flocked with black anti reflection material. Since the light is at a grazing angle, the surface is highly reflective. I hope this is a one-off quality control failure and not the intended design since it would be a major problem for anyone using a full frame sensor.
I informed WO early on about the stray light and they responded with an assessment that it could be a light leak. I followed up with the photos in this post and my experiments with 3 cameras but have not heard back.
Agena Astro has issued an RMA and I have shipped the telescope back to them for a refund. I very much like the optical quality of the images from this telescope but lack of stray light control is a deal breaker. I am reluctant to try another copy unless I can verify others are not seeing this problem. By the way the M48 adapter still passes the stray light so it is possible in some framings this would be a problem for APS-C sized sensors.
Has anyone with an UltraCat 56 (or any UltraCat) had this problem or can verify the stray light is properly controlled in their copy?
Bob Fugate
Stray light ring observed looking into the telescope - flat panel illumination.
Close up of stray light ring.
Photo showing the rear lens mounting ring.
Typical stray light effect on full frame camera - no filters installed.
📷 Z60_7446.jpgZ60_7446.jpg📷 Z60_7460.jpgZ60_7460.jpg📷 UC56 stray light annotated photos.005.jpegUC56 stray light annotated photos.005.jpeg
Charles Hagen avatar
Good instincts with performing this test - I have had similar issues in the past with my Nitecrawler WR25. It’s a very frustrating design oversight that seems to make it’s way into all sorts of gear. I often find myself thinking “they should have known better”… but I digress. My solution ended up being pretty simple and I think may be applicable here if you have the space for it and would prefer not to RMA. I ended up 3D printing a couple knife edge baffles that were able to sit between the gap of two adapters just after the nitecrawler drawtube. They don’t need to cut very far into the light cone to be effective, just enough to cover the affected area so that reflections off it cannot reach the sensor. Here’s a diagram of a cross section demonstrating what that might look like:
image.pngNote that the baffle does not actually take up any backfocus because it is sandwiched between two existing adapters/spacers in the stack.
Here was the original problem:
image.pngAnd a before and after of the arc reflection (with and without the baffle)
Well Written Helpful Engaging
rqfugate avatar
Charles, thanks for the reply. I was thinking along the lines of a baffle when I put the M48 adapter in the telescope. The fact that the internal optical assembly moves up to 30 mm complicates the issue, but I thought I may be able to find some solution that would go just in front of the M54 adapter to block the stray light for a given focus position.
However, in the end I felt frustrated that I was paying a premium price for a telescope that had either not been thoroughly inspected or even worse had a design flaw that had not been discovered through proper stray light analysis or testing.
So I sent it back. I am really curious to find out if all their UltraCats are built this way.
BTW are you the Charles Hagen of NightPhotons? If so, I want to thank you for your continuum subtraction work - it is the only thing I use. Also I use Lumidex to keep track of my exposure library. I had developed a set of requirements for what I wanted in a data base and was actually starting to develop the code to implement it when I came across Lumidex. It is exactly what I needed and is a brilliantly executed. I realize it was created by Alex Helms but discovered it on your website - some time after I had been using the continuum subtraction routine. Thank you for making these important contributions to the community.
Astro Jeep avatar
I have an Ultra-Cat 108, and I have no light leaks at all. It is the best telescope I have ever owned, other than my Stellarvue SV70T. I am sure it is a one-off issue, and if they exchange it for you, my guess is that the next one will be perfect. It sucks that this happened to you.
Well Written Respectful Concise Supportive
rqfugate avatar
I really do like the optical quality of the images it produced. Thanks for the info on your 108. Do you know if that last lens mount is blackened on your telescope? It is something one wouldn’t pay attention to if there isn’t a problem, so no worries if you don’t know.
Astro Jeep avatar
rqfugate · Mar 2, 2026 at 01:48 AM
I have no idea if it is blackened or not. I will get back with you tomorrow and let you know.
alpheratz06 avatar
It's amazing that this simple defect go through final inspection without being identified.
I don't like either the attitude of the manufacturer which starts by a story about misuse.
Jeff Reitzel avatar
Hi. I did not see where your system came into focus in your initial description. I own both Cat 91 and Ultra Cat 56 scopes. I have not yet seen this issue with either using APS-C or Full Frame sensors. I did notice both of mine came into focus at the nearly all in position. I thought they should be more toward center of focus travel. I found a support article discussing this while researching the issue. It specifically references light leaks and where the focuser should be operated at on their Petzval WIFD designs. I wonder if this is to prevent the issue you are having. Article is at: https://support.williamoptics.com/guides/back-spacing-range-on-petzval-systems
Here is an image to show where WO wants the scopes to focus.
Jeff
Well Written Helpful Respectful Concise Engaging Supportive
rqfugate avatar
I just received this response from William Optics:
Dear Bob,
Thank you very much for your thorough testing and for sharing the additional photos.
We truly appreciate the time and care you’ve taken to investigate this issue.
The lens mount finish on WO telescopes is designed to be glossy (not matte), and this does not affect imaging quality under normal conditions.
However, the light ring you described — caused by reflection from the inner wall of the end lens retainer — may be an isolated case.
We recommend that you contact Agena Astro to request an exchange.
Best regards,
WO
Karen
So, the design includes a glossy lens retainer ring. I don’t think my telescope was an isolated case - the laws of optical physics are in effect at all times and all places. And I guess ‘under normal conditions’ means don’t look at any part of the sky near a bright star.
This telescope may still be useful for sensors smaller than full frame - seems what most people are using. But for full frame use, the built-in stray light is a deal breaker for me. I have requested a refund.
And a note to Astro Jeep: you will probably find an anodized retainer ring. But one thing that may be different for the 108 is the distance from the last lens element to the focal plane. If the lens assembly is further up the tube it may not be a problem for full frame.
Hope this is useful to others considering this telescope.
Well Written Helpful Concise Engaging
SonnyE avatar
rqfugate · Mar 2, 2026, 03:46 PM
Dear Bob,
Best regards,
WO
Karen
I would tend to agree with you, especially in light of Charles’ post where he clearly shows the ring before and after his baffle addition. (Great fix!)
As an avid DIY’r I’d probably seen if I could black it out myself. But for a high-end model Petzval I’d expect it to be correct out of the box.
Shame on Karen! But then, she is a Karen…. Now that WO is informed, they should be doing quality control on the remaining stock. They have a reputation to defend.
Concise Engaging
rqfugate avatar
Jeff Reitzel · Mar 2, 2026, 03:34 PM
Jeff
Yes, sorry I didn’t include that information. The system focuses for 55 mm of back spacing when the scale is at 8 mm, which is close to what they show in the above diagram. I tried a shorter back focus using my Z6 which moved the internal WO optics forward in the OTA to 26 mm on the scale but that didn’t change the stray light arcs. The distance from the rear element of the telescope is still approximately the same. Thanks for your suggestion.
Jeff, when you get a chance could you look into the back of your UC56 telescope while illuminated with a flat panel and see if that ring is there? And with a full frame sensor, put a bright star off the long end of the frame about 4 degrees and see if you see the arc on the image? I was seeing arcs in integrated stacks of about 10 min total exposure for 5th magnitude stars 4 degrees off the edge of the frame.
Thanks,
Bob
Supportive
GregsAstrobin avatar
Bob,
The sort of thing you found by looking into the back of your scope with the objective illuminated by a flat panel is not uncommon. I have been on the warpath to figure out why I get odd colored arcs in my calibrated frames on several image trains. I started looking at my image trains in this manner and found they all have issues to a varying degree.
One of the more interesting cases was my Edge HD1100 with dedicated 0.7X focal reducer. There was a rainbow-colored reflection off of the back end of the focal reducer. Inspection showed this to be a reflection on the very shiny anodized inner surface of the focal reducer just behind the backmost optical element. The colors change wildly as you move around looking at the reflection. I put a quarter inch strip of flocking around the shiny inside edge of the focal reducer and it was gone. I have attached the before photo. In addition, in this shot you can see that the inside of the baffle tube is also not black, but a dull gray. The inside of the baffle tube is machined with threads, but that was not totally effective. I was able to put some flocking inside the rear part of the baffle tube up to the corrective optics. It helped, but it is not fully effective. I have attached an after photo as well.
📷 EdgeHD 1100 with 0.7x FR.jpgEdgeHD 1100 with 0.7x FR.jpg📷 EdgeHD 1100 with 0.7x FR and Some Flocking.jpgEdgeHD 1100 with 0.7x FR and Some Flocking.jpgI had similar issues with my WO Megrez 90. The tube has knife edge baffles, but the inside of the very front of the optical tube behind the objective and before the first baffle, while painted flat black, reflected a dull gray that can be seen by the sensor. I flocked that and the reflection was dramatically reduced. Unfortunately, I did not take any photos.
Many telescope and accessory manufacturers either paint the inside of optics flat black or machine threads the length of the optics, all thinking that this will eliminate light reflection down the light path. My examination of many items, from extension tubes to focal reducer/field flatteners to focusers to telescopes themselves, reveals that this is far from the truth. Sometimes threads are especially reflective at the glancing angle involved. Knife edge baffles work well if placed well, be even they can have a reflection on the inner flat circumference that is however thick that the baffle is if it is at all reflective.
I think every astro imager should take a look at their optics in this manner to see what can be addressed. Flock accordingly if possible. Unfortunately, Protostar, which was a source for some excellent flocking products, is no longer in that business as of December. I have not researched what other products are out there that can replace theirs. I know that there are some paints out there that are significantly black and non-reflective, but I have not researched that.
Unfortunately, the weather has not been my friend this winter, so I have no results to see how these improvements have affected my image calibration quality, but I have developed a method to evaluate flat performance from the flat itself. Here is what I do with an OSC camera using PixInsight:
1. Generate a calibrated master flat made up of flat subs calibrated using an uncalibrated master flat dark (takes out bias and hot pixels).
2. Debayer the calibrated master flat.
3. Apply GraXpert to the debayered calibrated master flat. It can be done with Correction set to Subtraction or Division to get two different GraXpert extractions. This removes the smooth contour of the master flat and leaves any more detailed variations from what should be nice, smooth contours.
4. Apply the ScreenTransferFunction (STF) with unlinked channels on each of the resulting GraXpert extractions.
If the flat were perfect, the result would be a perfectly flat result, except for dust motes, and possibly with a color cast of a single hue. I see something very different on all my scopes. I am attaching JPEGs with the results of this process on flat panel flats of my Megrez 90 with Televue TFR-2008 before and after flocking. I have included the subtraction version. As you can see there are more than just dust motes left in the results. The image with flocking is stretched much harder by the STF, so It can be seen that the flocking has greatly reduced the bright ring in the center. It’s not perfect, but then again, viewing up the tube with a flat panel shows it to be still not perfect, but vastly improved.
📷 Panel Flat Subtraction.jpgPanel Flat Subtraction.jpg📷 Flat with Flocking Subtraction.jpgFlat with Flocking Subtraction.jpgI would be interested to see what others find out about their imaging trains using these methods.
Greg
Well Written Helpful Respectful Engaging
Jeff Reitzel avatar
rqfugate · Mar 2, 2026, 07:17 PM
Thanks,
Bob
Hi Bob,
I am travelling and it will be a while before I get back to the scope. Here are screen shots of the last data I was taking with my UC56 in February. This was with the Player One Zeus Full Frame Camera and 50mm Astronomik 6nm filters. These are the raw stacks of Ha data and Oiii data acquired as well as completely unedited 10min subs with each filter. Hope it helps. I’ll make a note to check per your request when I get back. These have the magnitude 1.65 star Beta Tauri well off center and no reflections at all.
Jeff
rqfugate avatar
GregsAstrobin · Mar 3, 2026, 12:29 AM
Bob,
Greg
Greg,
Thanks for the detailed information - quite an informative treatise! I’ve been lucky as the UltraCat 56 is the first telescope I’ve had that shows any stray light problem. I will use the technique you describe to look at my master flats. I did look into the back of my Takahashi FSQ 106 but didn’t see any bright stray light visually. I have used it since 2020 and have been lucky so far.
Thanks for your input, much appreciated.
Bob
rqfugate avatar
Jeff Reitzel · Mar 3, 2026, 12:13 PM
Thanks,
Bob
Hi Bob,
Jeff
Jeff,
Thank you for following up and I’m still eager to hear more about any stray light you can see wen you look into the back of your U56. Nice images! I never saw any stray light reflections from stars within the field, always outside the frame a few degrees from the edges of the frame. Here is one example of the Pelican nebula in SHO.
📷 Seagull_SHO_arcs from theataCannisMajor.jpgSeagull_SHO_arcs from theataCannisMajor.jpg
and the framing that goes with it:
📷 SeagullNebulaFraming.jpgSeagullNebulaFraming.jpgI believe the star just off the lower right corner of the frame is the source of the stray light since the arcs seem to emanate from it. There are multiple arcs for each filter caused by internal reflections - I noticed the rear element of the UC56 optics is nearly flat - enhancing reflections.
Here is different example. Barnard’s Loop region, M78 and LDN1622, Ha image with Betelgeuse off the top edge of the full frame camera:
📷 M78_region_Ha)stray_light_Betelgeuse.jpgM78_region_Ha)stray_light_Betelgeuse.jpgand here was the framing for this image:
📷 260209-M78_LDN1622_Betelgeuse_Frqming.png260209-M78_LDN1622_Betelgeuse_Frqming.pngI have uses a RedCat 51 with the same full frame sensor (ASI6200MM), filters, and rotator at Starfront since Dec 2024 and have never seen anything like these arcs with that setup making hundreds of images (maybe thousands by now). I also have used a Takahashi FSQ 106 EDX4 with full frame cameras since 2020 and no stray light of any kind observed with it. But right out of the box the UltarCat 56 has lots of stray light - so dissapointing.
Looking forward to more info from you on your UC56. Thanks,
Bob
Joshua Carter avatar
As I’ve mentioned to you on the Starfront Discord server, I plan on ordering a copy here in Japan. Once I receive mine, I can do a similar test and update my findings here.
rqfugate avatar
Joshua Carter · Mar 8, 2026, 07:07 AM
Joshua, did you ever get your UltraCat 56? I’m still trying to find just one person who has one with a blackened rear lens mount retainer ring. If they exist in the wild, I might try to buy a second copy. Thanks, Bob
rqfugate · Mar 25, 2026 at 04:48 AM
I actually ended up getting g the Ultra-Cat 76 due to stock issues.
Jeff Reitzel avatar
Thanks,
Bob
Hi Bob,
I did get back and looked at my UC56. My copy appears exactly as yours does with the shiny black finish. I cannot duplicate the arc reflections your are getting. I have tried several times with stars of varying brightness up to and including Sirius. I tried from at the edge of FOV to a few degrees out of FOV like you described. Is there any chance what you are seeing is from a problem with a filter or filter mask? Have you seen the same thing in stacks with different filters?
Good luck,
Jeff
rqfugate avatar
Jeff Reitzel · Mar 25, 2026, 11:03 AM
Thanks,
Bob
Hi Bob,
Good luck,
Jeff
Jeff, thank you for looking at your UC56. You are the first to confirm the shiny black finish. I do have confirmation that the UC76 is blackened, so it is curious why the UC56 is not. I did several experiments with different cameras, including full frame DSLRs and it was there in all cases. I did return the one I had so can’t do any further experimenting. Thanks again for your response. Bob
rqfugate avatar
Thanks,
Bob
Hi Bob,
Good luck,
Jeff
Jeff, one more question. Did you have an opportunity to look into the back of your UC 56 when it was uniformly illuminated (e.g. with a flat panel) to see if that bright ring was visible as it is in this photo? It is very bright and immediately obvious. I believe this ring of light was the source of my stray light issue. If it is not visible in your telescope, and since you don’t see any stray light in your images, it would make me question my understanding of what is going on.
📷 Z60_7446.jpgZ60_7446.jpgThanks,
Bob
Jeff Reitzel avatar
rqfugate · Apr 3, 2026, 09:27 PM
Hi Bob,
I actually did not look for that ring but I am confident it would be there with a brightly lit flat panel shining through. I have seen something similar to that on other focusers I have that include some very high quality brands. I feel like it is simply the small clearance around the drawtube that has to exist for it to move. It is especially prominent with the Crayford type focusers I have owned. They seem to have the largest space/clearance around their drawtubes. In either case, that light is around the outside of the drawtube and should not have a path to your camera sensor. The only exception I have ever heard about is specifically with Moonlight Crayford focusers like I have on my EdgeHD 11. Their design and very short draw tubes can allow external light in from the back/camera end if you are imaging in an area where lights can hit the back of the scope. Many people put a boot around them or make an internal baffle like Charles mentioned if they find themselves in that situation.
Jeff
rqfugate avatar
Jeff Reitzel · Apr 4, 2026, 12:02 PM
Hi Bob,
Jeff
Hi, Jeff,
Sorry about the confusion. That ring of light is not from around the focuser. It is a reflection off the inside wall of the lens retainer ring holding the last lens in place. Here are a couple of photos.
📷 Z60_7471.jpgZ60_7471.jpg📷 UC56 stray light annotated photos.005.jpegUC56 stray light annotated photos.005.jpeg📷 Z60_7460.jpgZ60_7460.jpg📷 Z60_7471-2.jpgZ60_7471-2.jpgThis last photo even shows machining marks sort of making the inside wall into a diffraction grating. In my view this should be matte black.
Bob
Well Written Helpful Insightful Respectful Concise Engaging
Dave avatar
UC56 ARC.jpgI received a UC56 this past week. Initially I was impressed with the flatness and size of the field using a 6200MC. Unfortunately, my first processed image has the same arcs reported by others. In the attachment, Dchubba is about 4 degrees to the west, and created the arc you can see at the top of the image.
Very unfortunate as I had high hopes for this scope based on the specifications. Now I'm just disappointed, as this scope was supposed to go to a remote site. I'll see what William Optics has to say, but I fear this scope is getting returned.
Well Written Concise Engaging
rqfugate avatar
David Privette · Apr 15, 2026, 06:38 PM
David,
On April 8, William Optics wrote to me and said:
“While this issue does not occur across all camera systems, we have successfully implemented corrective measures.
We invite any affected customers to contact our support team for a comprehensive solution.”
So, yes, it would be good to contact them.
Bob
Well Written Helpful Respectful Concise Supportive
Reflection QHY16200A
Hi, I would like to know if anyone else has reflections in the photo of stars close to the sensor or is it my problem? Thanks.
Stray light reflections in sensor could cause star artifacts near optical surfaces.
Sep 24, 2024
Astro Panel X 2026??
this showed up in my news feed. Anyone have experience with it?
Author asking about telescope experience; stray light issue relevant to equipment evaluation.
Jul 7, 2025
ZWO EOS adapter light leak
So I have discovered that I have a light leak in my imaging train using my Rokinon 135 lens. I am using a ZWO 6200 attached to the 5 position filter wheel ( tilt plate removed) the ZWO EOS adapter, and that is connected to the Rokinon 135. Through tr...
Light leak troubleshooting with different imaging equipment setup.
Jul 28, 2024
Seeking internal flat black coating recommendations for UltraCat 108 adapter
I recently had an adapter made for an UltraCat 108. Looking for recommendation on an internal flat black coating. My thoughts are Cerakote. Anybody know of a better solution? It’s the piece just in front of the rotator. 📷 STX_Replacement_Adapt_1.jpg📷...
Stray light issues in telescopes relevant to internal coating solutions.
Oct 28, 2025
Dark Filter for Making Darks, Making Flats Remotely
Hello! I am considering putting a telescope in a remote hosting site. I am thinking about many details, including how to make darks and flats. I could get a Moravian camera that has a mechanical shutter, but it has the same sensor as the ASI6200 whic...
Stray light issues relevant to remote telescope setup and imaging quality.
Apr 6, 2024
