UV/IR Cut vs Luminance
7 replies155 views
Eric Gagne avatar
I’m sure this is discussed at lengths here and in the internet but still I failed to find an answer.
So are the 2 doing the same thing ?  Are they interchangeable?  I own 2 mono camera,  Touptek ATR585M with a 8 position filter wheel that have LRGBSHO filters and an empty spot.  The other is a miniCAM8 also with LRGBSHO filters and a dark filter.
I used to shoot narrowband and mostly did emission nebulae but I want to start doing galaxies, dark nebulae, IFN and that kinda stuff and I don’t know if I need to change anything in my setup.
Should I get a UV/IR cut filter for the Touptek, only use LRGB filters or do that and also shoot with no filters, not even UV/IR cut ?
And what about the miniCAM8 ?  I don’t even know if they make a UV/IR cut filter for them but again, is using only the luminance filter good or should I remove the dark filter and do some subs without any filters?
Brian Puhl avatar
The general answer is yes, they are the same. However, there is subtle differences, the answer you will find in their bandpass charts.
For ease, I just chose Optolong:
Here is their UV/IR chart:
And here is their chart for their LRGB filters, Luminance is the white band:
Very close, but appears to be a bit more subtle falloff prior to the 700nm (IR) range. The reality is, you’d probably never notice the difference, unless you’re bombarded by security cameras with IR blasters, though I believe most of them are well out of this range.
Some companies like Baader sell the filter as a UV/IR (Luminance) filter, and don’t seem to differentiate the two.
Anyways, I hope this gives you a little bit to go on. And in answer to your last question, no, you do NOT want to image without any filters. The entire light spectrum hitting your sensor cannot be focused properly and you will have a much softer image.
Well Written Helpful Respectful Engaging Supportive
Eric Gagne avatar
Thank you Brian.
These are the specs so I guess I’m good to go then though the Touptek look a little better.
Wim van Berlo avatar
A wise man on another astronomy forum once said, “it’s not about what a filter passes through, but what it blocks.” At the time he was referring to nb filters, but I find that it holds for filters in general. Every filter has an optical density (OD) out of its passband, the higher this number, the better its out of band rejection. Besides that, one also has to consider the filter’s AR quality; you would want to avoid filters that create star halos.
Just my € 0.02
Cs,
Wim
Well Written Helpful Insightful Respectful Engaging
alpheratz06 avatar
To put new words on the same answer, I think all (or nearly ?) LRGBSHO filters are UV and IR proof. The only question that arise is about the optical port of the cameras, some of which are rejecting UV/IR and some other don’t. OSC ports generally filter.
*Not sure what an "OSC port" is  but me guessing it means the OSC camera sensor window then the answer is a resounding not really.
alpheratz06 avatar
andrea tasselli · Feb 28, 2026, 04:20 PM
Pse explain. No need to be rude, please.
The (recent) OSC cams I play along with have UV/IR rejection filter as optical port.
2 filtered, 2 unfiltered for DSO imaging, 4 planetary cams all unfiltered. So better than 50% you are going to land on the unfiltered side. Even restricting to DSO cameras (cooled)  you get even chances to land an unfiltered or a filtered one. "Generally"  means the standard expectation is that you will receive a filtered camera which as to better than 50-50 chances.
QHYCCD Minicam8 Mono SPCC Filter Setup
Hi Everyone, I know that Minicam8 mono users here are using some sort of color calibration in PI. I have been comfortably shooting OSC for years. I am new to mono and was hoping that I might get some help from some folks using this camera with settin...
Author owns Minicam8 mono camera; discusses color calibration setup relevant to their gear.
Sep 8, 2025
TouTek filter wheel registered as a camera..?
Hey, I just got my new ATR585M + AFW-M by ToupTek and the camera works absolutely fine. My only issue is the filter wheel, I could originally not find it in NINA under filter wheels but then I saw it was registered as a camera.. I already tried updat...
Author owns ATR585M with filter wheel; directly addresses their specific equipment setup.
Mar 16, 2026
Help finding source of light reflections
Any idea? It happens on long subs (>2min) and using all filters except Luminance, for some reason. It’s a Carbonstar RC6 with a ToupTek camera, filter wheel, OAG, and a manual rotator. Thanks in advance for your help.
UV/IR Cut vs Luminance discusses filter behavior differences relevant to troubleshooting.
Apr 19, 2025
Would you replace the Built in UV/IR cut on a 2600MC with AR glass?
Hello All, I am looking to replace the built in UV/IR cut window on a 2600MC-Pro with AR window and using a better UV/IR cut filter with better cutoffs in the UV and IR (Baader cmos optimized UV/IR cut filter) so i get less UV and IR and better glass...
Directly addresses UV/IR cut filters and their optical properties and effects.
Sep 18, 2025
How to shoot HII Region in mono in light polluted zone
I live in a bortle 6 zone and my neighbors have lots of light in their backyards which turns my bortle 6 into a 7 easily. I only have view on HII regions this time of year and I shoot with a miniCAM8M. The L filter that comes with it is just Luminanc...
Author transitioning to narrowband imaging; discusses HII region shooting with mono cameras.
25 days ago
