Guide scope and camera recommendations for smaller Svbony refractors
3 replies•56 views
Rocksen avatar
Owners of Svbony refractors, specifically smaller scopes like the SV550 80mm, what guide scope and guide cameras do you pair with your scopes or would recommend for someone starting DSO imaging? Also, is it worth purchasing the more expensive guiding gear? EDIT- Thank You everyone for Your thoughts I now have a good idea on what to do next 🙂
Aloke Palsikar avatar
There is no direct connection between Main Telescope brand and Guide scope/camera. Both are independent optical trains.
Since you have a SV 500 80mm which is f/6, you can go for a small compact Guide scope system and camera. SVBony themselves have a 50mm Guide scope which should be good enough for your rig. There are other makes like Omegon etc which you can choose from depending on your budget. A small Guide camera like ASI Air 120 MM or a slightly higher priced ASI Air 220 MM can also work
Nowadays quite a lot of Astrophotographers use Off Axis Guiders (OAG) to eliminate the Guide scope all together. Also a range of Duo Cameras like ASI Air 2600 MC Duo also eliminates the Guiding optical train completely . But these are more expensive
Recommend you choose a guide scope which pairs with your main scope mounting arrangements and ensure that the total weight of the Setup is within the limits of your Mount.
Several videos are there on YouTube to go through the guiding gear and process
All the best !!
SonnyE avatar
Rocksen · Feb 23, 2026, 04:43 AM
For probably 10 years I used my Orion Star Shooter 50mm guide scope with my Orion Star Shoot camera. Worked perfectly for me but the camera finally gave out. I replaced it with the ASI290MM Mini because I wanted the added Pixels the 290 offered.
A little while later I decided to upgrade my guide scope to an Svbony 106 60mm for a “bigger eye” for my guider. Very pleased with the 106-guide scope. And its focuser is really easy to find very sharp focus with. Which I appreciate.
When starting out I did give it the good old college try to get an OAG to work for my 80mm telescope. Tried two different OAG’s. Couldn’t do it. I talked to support for the second OAG (high end at the time) and was told OAG’s were best for the bigger SCG and reflectors. Which was accepted practice then. As soon as I got the guide scope it was instant guiding success.
I still like individual components so I can pick and choose my equipment. I think these “Duo” cameras are still a little green and unproven. I’m not one to trust a new product until it’s been around and the problems are well documented. If someone likes the Duo concept, go for it. But if either camera develops undesirable traits or faults you’re out of the game. If you have other cameras such as I do, and you don’t have a separate guiding system, you have no guiding if you want to change for your duo to something different. My case I have an ASI2600MC Pro, and an ASI1600MM Pro cameras. I also have and Atik Infinity I never use anymore but can play with any with my guiding system being individual like it is.
I’m also not sold on the micro 30mm guiders either. My preference is to give PHD2 plenty of stars to choose from. Where I am PHD2 multi-star guiding grabs 9 stars consistently.
LOL! A Friend of mine back when starting out told me when I got my 80mm telescope that it would make a good guide scope when I got a bigger telescope. I did consider that but gave the 80mm to the grandkids to do visual with.
So with a guide scope system you can move it from telescope to telescope as you progress.
Well Written Helpful Respectful Engaging
ProksimaCentauri avatar
I have a William Optics ZenithStar 81 WIFD scope (it has similar specifications to your SV550) and use it with a William Optics Uniguide 50mm scope and a ZWO ASI120MM MINI camera.
I control the system with an ASIair MINI computer.
I'm happy with this combination.
If you want your system to be as simple and wireless as possible, I recommend a smart camera – one that includes an image sensor, a guide sensor, and an ASIair computer.
I recommend the ZWO ASI585MC AIR camera as a starter.
If you're looking for a more advanced solution, the ZWO ASI2600MC Air is a better choice.
Remember that smart cameras and ASIair computers only work with ZWO accessories and cameras.
But they can be used with SRLs (Canon, Nikon, Sony, Fujifilm) and mounts from various manufacturers.
Below are some interesting videos on this topic.
https://www.youtube.com/watch?v=H39cOTWVaCw&embeds_referring_euri=https%3A%2F%2Fwww.bing.com%2F&embeds_referring_origin=https%3A%2F%2Fwww.bing.com
https://www.youtube.com/watch?v=acLhjlrSIgE
https://www.youtube.com/watch?v=5GJAQKdwHEc
C.S.,
Joseph
Well Written Helpful Concise Engaging Supportive
Recommended star guide camera for 50mm guide scope?
what is a good star guide camera that fits the Orion 50mm guide scope? if there is not one what is good star guide scope, thanks all
Guide scope and camera recommendations for smaller refractors directly address equipment pairing question.
Dec 2, 2025
