I’ve been doing dual side-by-side setup for a while now and it’s not at all a hassle and it does give me double the integration time. But….I have a few rules
Scopes with different apertures are fine if you are collecting color data on the shorter focal length and luminance with the larger aperture/longer focal length. Really doesn’t work well if you try to image the same filter with different aperture scopes. Narrowband for example , you really need more similar scopes since you can’t do a luminance. And exception is object with dim and diffuse Oiii compared to Ha/Sii can be split between the wider and the narrower respectively. But objects like the Veil you really don’t gain much with dual dissimilar scopes.
I have 2 high quality 130mm aperture scopes with slightly different f ratios/focal lengths (TOA-130 f7.7, AP 130 EDFS f6.5) and they work quite well together even with the same filter. They gather similar FWHM images and having one slightly wider makes it less critical to have perfect alignment. You can look at some of my latest images takes with this combo. I can gather a great amount of data in a single night. They both ride on my Mach 2 no problem.
I’ve also combined the TOA-130 luminance with the WO Ultracat 108 color and it’s worked very well. My seeing isn’t great, so the 108 on average doesn’t trail significantly enough for FWHM when used as the color channel.
I do have 2 identical full frame chroma filter setups so I wouldn’t say it saves money in general. But it’s still cheaper and more manageable than having a massive 180mm fast refractor.
Now once you start into reflectors with spikes, it gets far more complicated. It’s probably better to stick with one fast system there.
Nina does a great job managing the synchronized dithering between 2 side-by-side systems. Been doing it a while now and it works great. And PI handles combining with aplomb, although I will say if your scopes have different distortion characteristics, you need to align more carefully in PI
Bottom line is that it’s not as difficult as many make it seem. You just have to understand the limitations and manage them.
