Optolong Oiii filter defective?
3 replies64 views
DavesView avatar
I suspect my Optolong Oiii 3nm filter has uneven coatings (or whatever the reason) causing a dark region in the image. I replaced it with an Antlia Oiii and the flats are perfect. Does that prove my theory, or is there something else I need to do? My intention is to have Optolong replace it. Anyone else having, or have had issues with this same filter? Here is a typical flat:
📷 SH2-261_CAL_FILES_FLAT_ZWO ASI6200MM Pro_2026-01-20_19-59-33__O_-9.40_0.76s_0008.jpgSH2-261_CAL_FILES_FLAT_ZWO ASI6200MM Pro_2026-01-20_19-59-33__O_-9.40_0.76s_0008.jpg
The first thing I would suspect would be the filter wheel not centering or some other obstruction causing that sharp cutoff on the left side.
Well written Concise
DavesView avatar
Tony Gondola · Feb 21, 2026, 05:01 PM
Replaced the filter and fixed the problem. Checked the filter installation prior to replacing, made sure it was threaded all the way in, etc. Don’t believe the filter wheel was the issue. Also, it was the only filter out of seven that did this. The right side of the image is the problem.
Good news then as it’s fixed. I guess it will remain a mystery as to the actual cause.
Defective filter, or something else??
Hoping to get some help from the group on an issue I had last night while imaging the California Nebula. I installed a brand new Antlia 3nm 2" Ha filter in my filter wheel and quickly discovered there was something wrong with the images. Perhaps...
Filter defect diagnosis relevant to narrowband filter problems encountered.
Oct 23, 2024
No signal in my new filters
Hello, I have recently bought a new set of filters. Antlia V-Series LRGB and 7nm HSO. I recently installed everything and had "first light" last night from my DIY remote observatory. When I remoted in to the PC and started imaging I noticed...
Filter coating defect suspected; similar Antlia filter issue reported.
Aug 17, 2025
Dark spots on flats with optolong para
Hi all, I recently picked up the optolong para 2 inch filter (10nm NBF). I run it on a Askar 65phq (F6.4) and ASI2600mc camera. The flats appear very abnormal in that there is a large dark area on one side. Curiously, my target seems to have less sta...
Dark spots on flats with optolong para filter - similar coating/flat quality issue.
Nov 3, 2025
