First impressions of the Twister FG-80 friction mount
11 replies522 views
Jon Woodhead avatar
note: the title should say ‘Twinstar,’ lol…can’t seem to edit that out😀
It seems that every other day brings a new mount on to the market these days but, beyond the sales pitch, there are often no real-world data on which to make purchasing decisions. With that in mind, I thought that it might be useful to document my first few weeks with a recently purchased Twinstar FG-80 friction mount.
Unlike many of the other recent announcements, the FG-80 is a friction-drive rather than a harmonic-drive and is also aimed at the high-capacity rather than low-capacity end of the market with a max stated 80kg payload. In this respect, it appears to be a direct competitor to the JWT Trident, with very similar pricing, just over EUR4000, depending on options. Guiding performance is quoted as ‘+/- 0.5 arcsec for unlimited time’.
Despite receiving the mount earlier in the year, I have due to weather and other limitations only had it out under clear skies for less than a week in total…so these are very much initial impressions. The FG 80 is an impressive beast and appears both well designed and well engineered. It is super quiet (if you have light-sleeping neighbours). One of the main attractions of the FG-80 for me, apart from the payload capacity, was the ‘integrated electronics’ incorporated into the mount saddle. On each side of the saddle there are 8 x 12V DC outlets (max 4A per port) and 7 x USB-3 outlets.
This makes for very minimalist cable runs - I just have one 20A power supply to the entire mount, then everything is powered from that via the integrated hub on the saddle. Similarly, I have a mini-PC mounted on top of the scope and can communicate with everything via the integrated hub. For my set-up this results in just 2 cables between the mount saddle and the base but this could reduce to one if you had your PC mounted on the base.
I purchased the FG80 with the intention of using it with my C11edge SCT on there operating at native focal length but, assuming the initial setup at 2800mm would be challenging, I first put a RASA8 on there. This uses an external guide scope and ASI Air for control. The FG-80 utilizes EQMOD ASCOM drivers and so it is simply a matter of selecting ‘EQMOD with SkySafari’ in the ASI Air and everything communicates straightaway. I was literally up and running with initial polar alignment completed within 30 minutes🙂
The ASI Air of course only incorporates a very stripped-down version of PHD2 and so there are very few options for honing the guiding behaviour but I have to say that, with minimal mods (mostly just increasing the RA aggression), the mount guiding with this relatively light rig (~10kg ) looked pretty good, hovering around 0.4 arc seconds total RMS (ignore the dither settings as this was not set correctly for this experiment). RA error somewhat larger than Dec but all well within the image scale of the RASA setup (1.2-1.9 arc seconds per pixel, depending on the camera used).
Buoyed by this initial success I am now, cloud permitting, playing around with the heavier C11 edge on the mount - this using an OAG for guiding and PHD2 running with NINA. There was, as I anticipated, some initial angst in setting this rig up but I have to say this was entirely due to operator error (as a lifelong Mac user I would rather poke my eyes out with blunt sticks than deal with COM port issues on a PC - what century are we living in again?🙂).
Once resolved though, I again found the mount to be very well behaved. This is a heavier payload (~ 20kg) albeit still nowhere near the stated load capacity of the mount. Total RMS for this scope is hovering around 0.35 arc seconds. The main issue again is the somewhat higher RA variation compared to Dec but both seem pretty good to me – at least for my Bortle 5 skies on the edge of a major city and are actually better than I have seen with any of my other mounts.
I am still playing with guiding parameters (again blunt sticks come to mind..) but the performance so far has been very encouraging. So far I really like the FG-80. The only negative I can think of thus far is that I do miss having a hand controller but, to be honest, I’m not even really sure why – I barely use the ones that I do have on other mounts. It’s probably just reassuring in case you want to take over the mount in a hurry…
Anyway, that’s just an initial look but I hope this helps anyone looking into the friction drive market segment…bit by bit just a little more information out there.
cheers, Jon
Well written Engaging
John Stone avatar
Why not run the PhD2 Logviewer Frequency analysis on the RA data and post a pic of what it shows?
This look like seeing limited performance for sure.
Concise
Jon Woodhead avatar
Hi John,
here it is
cheers, J
Lorenzo Siciliano avatar
Interesting mount. How much it weighs?
Ciao
Lorenzo
Jon Woodhead avatar
full details on their website (I have no association btw…just a purchaser):
Twinstar
Michael Sullivan avatar
Have you tried with green swamp server?
My mount should be shipping next week. I was going to setup with GSS, NINA and Stellarium. Are you using a USB cable? What baud rate did you put in eqmod?
I was told USB to serial was 9600 and USB was 115200. I'm told to use 9600 with the FG80. Glad to see other users out there. Enjoy ,Mike
Supportive
Jon Woodhead avatar
Hi Mike,
After initially setting up using an ASIAir (which worked flawlessly), my first attempts to use NINA were with the GreenSwamp Server driver as I had read that it was a more modern implementation of EQMOD functionality (I have no previous experience of either). Unfortunately, I just couldn’t get it to work (almost certainly my lack of knowledge) but, as soon as I swapped across to EQMOD, everything came together pretty easily.
I have a single USB cable from the mount to my mini-PC which sits on top of the scope and a single USB cable from the main camera to the mini-PC. Everything else runs through the saddle hub. I could reduce this to just one cable to the mount but always prefer a direct connection between the main camera and the PC to avoid any comm issues. The baud rate is 9600 ..
I’m certainly enjoying the mount….really great performance and the integrated power/UBS hub is sensational and way better than anything else I have seen on the market. As I said above the only thing that I miss is a hand controller…just for rapidly driving around (if you need to centre an object etc…). I know that you can do all this stuff through NINA but it is far more cumbersome IMHO than the responsiveness of a hand controller.
Hope you enjoy the mount. Let me know if you need any other info.
cheers, Jon
Well written Helpful Respectful Concise Engaging
Matus Smutny avatar
Hi Jon,
Thanks for the impressions, I will be upgrading my old EQ6-R with FG-80 hopefully by the end of this year.
Matus
Well written Respectful
Juan Ramón Arques avatar
Hello. This mount has PPEC training?
Rostokko avatar
Juan Ramón Arques · Apr 5, 2026, 10:50 AM
…I thought one of the points of a friction mounts is that they are meant to have negligible periodic error.
Well written
Someone notice some kind of sound like a squeak in this mount, when moves by cursors?
Jon Woodhead avatar
The mount is run through EQMOD - I don’t know if that has periodic error correction possibilities but that is not required for friction mounts which have very low backlash and near zero periodic error because they don’t use traditional toothed gears (it’s a different story for harmonic drives which have low backlash but significant periodic error).
I have not noticed any squeaks - this is a very quiet mount (again, I guess, because of the lack of gears or belts?).
Well written Helpful Concise Engaging
