Advice needed on hard printing of a specific image
11 replies269 views
kvastronomer avatar
I’m looking for an advice to order a print of an image that you can hang on a wall.
I wanted to print few images from time to time as a gift but did not feel like printing a version of traditional DSO object would be a unique enough. There are millions better renditions of the same object you can find online. This time I have something unique, one of.
Given this specific image what type of print would you order and where from?
Resolution is 12632x11005 pixels.
What max size would look good? And what medium would you recommend?
I have a PNG file which is around 150MB. Do I need to save it somehow specially or differently before submitting for a print?
Any advice appreciated.
Thanks
📷 Abstract Expressionism: The Sublime Violence of LightAbstract Expressionism: The Sublime Violence of Light
https://app.astrobin.com/i/76hrz3/
danieldh206 avatar
For printing you need the ICC profile of the printer and to calibrate your monitor to AdobeRGB. This is when you find out how good the monitor actually is. Printers have a wider gamut than SRGB and if you don't reprocess the image for printing it will not print what you see on the screen. Any good printing company should accept 16bit file formats. If you print on metal you will need to learn about CMYK printing.
Well Written Helpful Concise
kvastronomer avatar
Do I have a chance of doing monitor calibration if it is a regular $100 monitor?
A2 should be plenty and then some. Aluminium printing would look rather good as a finish but you'd still need light to make it work as intended. Print a small sample and see how it compares against your screen rendition. You need to learn about the CYMK process no more than you'd need of the ins and outs of the combustion process of benzene to drive a car.
Rainer Ehlert avatar
kvastronomer · Feb 19, 2026, 02:59 PM
IMHO yes you can calibrate a $100.00 monitor but the question is here if it supports the colour gamut of AdobeRGB.
A simple calibrator cost maybe the same as your $ 100.00 monitor.
Just an example of a cheap but good calibrator
https://calibrite.com/product/display-123/
Mark Fox avatar
The best rule for printing is to not go lower that 300 pixels/inch, so in your case with a 12k resolution you could print up to 40 inches on the wide dimension… but you may want to pixel peep to see if you are happy to that size. But having said that, modern printing methods can achieve better resolution and you may start seeing little noisy details (if any - I haven’t pixel peeped your image even though I gave it a “like” the other day) if you try for the 40” size.
I’ve printed a few items on metal, and it would be interesting to see the difference between direct metal printing versus white flood layer (printing a white base onto the metal before applying the image). The white flood layer will show the work in any light (it’s like printing on high quality paper), but the direct to metal printing needs reflectance to see the image - and when there is reflectance, the effect is really nice. I have a M31 on metal on display in a room with a lot of natural light and love it during daylight hours, but in the evening it goes really dull, and the neighboring Pacman (printed on white flood layer on the metal) starts to steal the show.
Another note - I just printed a Rosette onto white-flooded metal. I was disappointed in the light blue oxygen highlights - they became very blanched and lost a lot of saturation, I believe because the company auto-scaled the luminance. If possible, see if the printer will give you a proof prior to printing. For a lot of these online portals where you can order metal prints, it’s a pretty automated process and you may not have the proof option. But a phone call to express your concerns - if they are a real printhouse - will help them get the project the way you want it. I just feel that many astrophotos might be subject to autoscaling the output since any top ends in the histograms are little pinpoints and probably really don’t register a lot of weight in their software and your histogram goes heavily light - especially your gorgeous starless nebulosity - the printer will really have to focus on keeping faithful to the histogram.
Worst case - maybe they can print the job on high quality paper, maybe half-sized to your intended finish size before you commit to a larger investment in full-size metal.
EDIT: Okay, I’ve now pixel peeped your image. When I zoom in to your AB image, to 0.13x zoom, that presents 100 dpi on my screen. Zooming to 0.39x, that shows me the detail at a virtual 300dpi, and I feel your image holds up nicely. It seems the dusty fingers still have some sharpness at that level (which would be equivalent to someone getting within 12” of your print, if done at 20” wide, 18” away if done at 30” wide).
Whatever you decide, I think the image will be a conversation piece…. just don’t get into the ‘green’ discussion ;-)
Mark
Well Written Helpful Engaging
Mark Fox avatar
I should also have weighed in on color gamut. RGB gamuts display a much broader range of color versus CMYK gamut. CMYK is the use of Cyan, Magenta, Yellow and Black ink to create colors subtractively (reflectance) as opposed to the light-additive RGB gamuts. I’ve seen the recommendation online to convert your image to CMYK and sending that to the print house, which i usually do (but in hindsight, that may have been the issue with my Rosette image - I sent it as sRGB).Photoshop and Affinity Photo easily will convert the color mode, and you could then submit a 16-bit CMYK TIF.
You should seek to use the proper CMYK color profile, too. Sorry, I don’t know where you reside, but in the US, printers like to see a “U.S. SWOP” color profile. In Europe a FOGRA-39 is the best choice. These options can be found in the color management areas of the software.
Well Written Helpful Engaging Supportive
kvastronomer avatar
Thanks Everyone!
As I understand now, based on your comments, I can easily go with A2 size and most recommended printing on metal. I appreciate info on white flood layer printing, never heard of it before.
Mark mentioned asking a printing company for a proof prior to printing. What is this?
I'm intrigued by metal printing on white flood layer option, thinking to order a small-sized test print at first.
What good printing company would you recommend in USA?
Respectful
Mark Fox avatar
A proof is provided by the printer as “proof” that the output meets the customer’s requirements.
I had my metal prints done online by Mpix, but I wasn’t picky about the output. They actually turned out exactly as I expected, without any formal proof. However, the ideal situation for a printer recommendation is to find someone local for you who will do metal prints. Being local, you should be able to get a proof or easily get some kind of small sized output for review before you ‘go big’. That will definitely assure you that you are getting what you expect.
I was thinking through the white flood vs direct to metal aspect of the project. Your beautiful image might benefit well from the direct to metal output. You have a lot of lighter nebulosity throughout. Direct to metal will really cause those highlights to pop (highlights = less ink used = most transparent area = more light reflectance). You’ll probably get some good glow out of the blue midtones, but not like the orange and yellow areas. The darker areas really won’t change much with varying light, since there’s a lot of ink (and less transparency) to reflect light off the metal in those shadows. I envision that turning on a light in the room will make it look like a light has been turned on behind the artwork. But when the lights are off, you will lose a lot of tonal range and the contrast will be much lower.
Whatever you decide to do, either way I believe the image will be gorgeous and a real conversation starter.
Mark
Well Written Helpful Respectful Engaging Supportive
Richard Seely avatar
That’s a really great image - very abstract and vivid colors!
I’ve used Fracture for glass prints; their prices are quite competitive - especially when they have a sale. The resulting prints are extremely vivid, although the dot-pitch of their print process is visible if I get too close to the print (15 inches).
More recently, I have used BayPhoto for quite a few of my print projects and have mostly been very happy with the result (apart from wishing that I’d chosen a semi-gloss finish, rather than high-gloss). I have had them print a variety of smaller metal prints - and a monster 96in x 48in metal print of the Milky Way over the Atacama desert, which is the centerpiece of my living room. As I mentioned earlier, I’d strongly suggest that you consider choosing a lower-gloss finish, as the glare/reflections on high-gloss prints can be quite distracting at times. For an image as colorful as yours, I’d also suggest having a look at their acrylic prints as an alternative to metal prints. From what I understand, BayPhoto is considered fairly high end, and they offer drop-ship services for many other companies.
I’m planning to send my next print project to Bradley Print and Photo - they have a somewhat different process for creating metal prints - and have a wider color gamut as a result. I’ve visited their gallery, and I was very impressed by the prints they had on display. I just need to find some more wall-space in my house!
kvastronomer avatar
Richard Seely · Feb 26, 2026, 08:50 AM
Thanks for this info. I’m still considering my options based on feedback provided. You monster print is beautiful.
dummieastro avatar
Bay Photo or Bradley. Second the lower gloss. I have been very satisfied with Bay Photo for smaller prints.
CS, Bob
Printers for prints.
Hi there, I hope you are well. I have some questions about printing astro images. Do consumer laser or ink jet printers do a good job on these images? Could you recommend any brands and models? I realize that what's good is subjective but in this...
Relevant for printing astrophotography images as wall-hanging gifts.
Mar 9, 2025
Print on Demand - Wall Prints?
As some of you know, I have made my books available on Amazon through print-on-demand, which allows authors to publish and sell physical books without upfront costs, as copies are only printed when a customer places an order. I am not involved in pro...
Print-on-demand services relevant to ordering wall prints as gifts.
Dec 9, 2025
sky March 19, 2023
Hello. I need your help! My husband's father passed away on March 19, 2023, and I would like to print the sky from that day on a large canvas for him in Alois’ honor. Now I've come across this great network! Does anyone here have a photo of the sky f...
Similar project printing a specific image on canvas as a personalized gift.
Oct 15, 2025
