Fuzzy halos around bright stars with directional orientation
11 replies209 views
Mike Bagley avatar
I’ve noticed that I typically end up with fuzzy halos around bright stars, for instance in the bright stars of Orion’s Belt:
📷 Orion's BeltOrion's Belt
https://app.astrobin.com/i/182vjp/
They seem to have an orientation to them- near the center of frame, the bright star’s halo is symmetrical, while to the right and left, the halos appear shifted away from center. This image was taken from a pretty light-polluted area using an Askar 71F and an SV220 7nm dual band filter. I processed it using a bunch of the scripts and tools in Siril. Has anyone else encountered this and/or have a suggestion for getting a crisper look?
Well Written Respectful Concise Engaging
Dunk avatar
looks like maybe a backspacing issue:
John Hayes avatar
Mike Bagley · Feb 17, 2026 at 08:05 PM
I doubt that this is due to a spacing issue. This looks to me like a potential problem with either longitudinal color or spherochromatism in your telescope. Longitudinal color is the variation in focal length with color and spherachromatism is the variation in spherical aberration with color. The problem is almost certainly being caused by your dual band transmission filter. It is allowing good focus in one color (red), while the other color (blue) is out of focus. The off-center nature of the halos is merely due to the angle of the beams about the optical axis. I suspect that if you used two separate filters and focused precisely for each filter, the problem will either go away or become so minor that it doesn’t matter.
Well Written Helpful Insightful Respectful Concise Engaging
Dave Erickson avatar
John Hayes · Feb 17, 2026, 09:19 PM
I doubt that this is due to a spacing issue. This looks to me like a potential problem with either longitudinal color or spherochromatism in your telescope. Longitudinal color is the variation in focal length with color and spherachromatism is the variation in spherical aberration with color. The problem is almost certainly being caused by your dual band transmission filter. It is allowing good focus in one color (red), while the other color (blue) is out of focus. I suspect that if you used two separate filters and focused precisely for each filter, the problem will either go away or become so minor that it doesn’t matter.
I might add that it could also be a leak in the filters IR blocking band
John Hayes avatar
Dave Erickson · Feb 17, 2026 at 09:22 PM
Dave,
That’s a good thought and something I considered as well but then the halos would happen in the red channel. Since they are happening in the blue, it made me wonder if it could be a leak at the other end of the spectrum, which might occur where the objective is not well corrected.
John Hayes · Feb 17, 2026, 10:49 PM
Dave,
Agreed, I share that thought, as a possibility as well. Although not specifically stated seems he is using an IMX571-C sensor based on his other posted images. As you recall the typical Bayer array has IR leaks in both the blue and green channels. The 2x green sampling might be responsible for the halo. Dave
The SV220 has an OD of 5 so no chance of an IR or UV leak. Lens ghosting or filters reflections can however produce something like that.
Ricardo Serpell avatar
Looks like an internal reflection, possibly involving the filter. Easy to verify, just remove it and shoot the same field.
Ricardo.
Well Written Helpful Concise
andrea tasselli · Feb 18, 2026, 09:20 AM
True as well, I have found that the marketing claims sometimes do not match the performance and leaks in both red and blue out of band blockers occur.
Well Written Helpful Concise Engaging
Rick Krejci avatar
They look like the typical filter reflection halos to me, often worse in the blue end of the spectrum than the other end
Mike Bagley avatar
Thanks to everyone participating in this thread- it sounds like I should do some experimentation with the filter. Next time I get a clear night, I’ll try shooting the same target with the same set up, completely without a filter and also with just a UV/IR block filter, to see if that mitigates the issue. I’m really hoping that it’s not the result of a nearby streetlight in the general direction that I’m shooting, as there’s very little I can do about that when taking images at home due to the orientation of my small yard and the surrounding trees.
All of my photos (minus an image of Jupiter) are indeed taken with an IMX571 APS-C sensor (a Player One Poseidon-C Pro).
Rick Krejci avatar
Mike Bagley · Feb 18, 2026, 08:05 PM
Shouldn’t be the streetlight. That would cause broader reflections or contrast loss not associated with stars.
The cause and the elimination of halos around stars with some duo-narrowband filters
I had this problem with two of my dual narrowband filters: huge halos around some stars, although I noticed that the affected stars are not always the visually brightest in the image. I also noticed in the last series of photographs that it seems to ...
Halos around bright stars similar to author's problem with dual narrowband filters.
Sep 22, 2024
2026: best dual-narrowband filters for RASA 11?
There's been a lot of new development in filter tech over the last 2-3 years. I'm looking to buy a RASA11 with a IMX571 camera and am looking for dual-narrowband filters. I'm looking for the tightest bandpass, most transmission, and least...
Addresses halo problems, directly relevant to author's least halo requirement.
Jan 28, 2026
Review of the SVBony SV220 Dual-band 7nm SII-OIII Filter for OSCs
Happy Holidays, everyone! I want to share my initial experiences with the SVBony SV220 dual-band 7nm SII-OIII filter for narrowband imaging with colour cameras. If you are currently only using the SV220 7nm/3nm Ha-OIII filter or any other HO dual-ban...
Author uses SV220 filter; review may explain halo behavior with this specific filter.
Dec 24, 2025
