YingtianZZZ avatar
Hi guys,
I’m in a big problem for two months and couldn’t find a solution. In my remote setup of Skywatcher-250 Quattro, I’m consisting getting dust donuts in low height areas, maybe light polluted sky area.
I know that easiest way is clean the filter, and that’s what I did first.. Even after the filters are cleaned, I’m still getting the donuts. Also, in my minds the donuts are from movement of dust. However, I have 2 sets of flats, on Feb.06 and Feb.14, and image was on Feb.07. If the donut keep moving, I’ll get different donut sizes, as in Feb.06/Feb.07/Feb.14, donuts are all in different places, and donut appear in 2 places: 06/07 error and 07/14 error. In fact, I used two sets separately calibrate and integrate, final image look identical. That’s after cleaning the filter.
Integration with Feb.06 Sky FlatsAutosave.jpgIntegration with Feb.14 Sky FlatsAutosave002.jpgThese 2 pictures are after DBE and standard HistogramTransform, but I just want to illustrate if you download them and switch, the donuts sizes are identical. Also, I find it’s not a standard circle, looks like with a smaller circle inside. Is it some kind of reflection?
I’m adding the files here: https://drive.google.com/drive/folders/1g3xWZgNg5Ql8UdD8Ptmv3ejSig81N3hF?usp=sharing
Thanks in adavence,
Yingtian
YingtianZZZ avatar
📷 image.pngimage.pngThis is the CCD inspector result of distance of dust, it’s a Skywatcher-250 Quattro, with QHY268M, so with 24mm distance, it should be on the filter. Only Red filter has this issue but LGB are not having the problem.
IMO this looks like dust that moved slightly between the flat exposure and lights exposures, thus the light and dark donut pattern. The only real cure is to take your flats as close in time to the imaging session as possible. Ideally, right before or right after. Between filter wheel movement and scope orientation changes, dust can move. The best cure is to take it all apart and clean to a very high standard and don’t try to depend on flat libraries. Like donuts, they are best when fresh.
YingtianZZZ avatar
Tony Gondola · Feb 17, 2026, 12:24 AM
I’ll do a test of 02/06 integration, but as 02/06 and 02/14 flat clibration result look identical, if it’s a dust, it come back and forth from same place on 02/06 to another same place on 02/07, then back to same place on 02/14, for me this sounds very unlikely to happen. The dual circle pattern make me think of the secondary mirror, but I don’t know if it’s really some internal reflection
Brian Puhl avatar
Filter wheel may not be centering up properly. I had this issue recently with my QHY wheel, updated the firmware and fixed it. If you have a QHY, they publish the tool on their website, basically gets rid of unidirectional.
Concise Supportive
YingtianZZZ avatar
Brian Puhl · Feb 17, 2026, 01:05 AM
This sounds very likely to be a problem. Yes it’s paried with a 2’’x7 QHY filter wheel, and everytime I’m imaging flat frame with order LRGB as the filter number increasing, but in imaging sets I’m doing L-B-R-G, which means there is a B-R rotate and that may be a problem. I’ll first figure out this point.
Brian Puhl avatar
Same exact wheel i’m running as well. Mine worked for probably 2 years before this issue popped up. I had seen it and fixed it before on another system so it was a fairly easy diagnosis.
Brian Diaz avatar
HI,everyone
There are two types of artifacts, the flat donuts and the ones that look 3D, which is the one in your image.
Looks like misaligned flats (or dust motes moving between lights and flats).
Have you moved/rotated camera after you took flats?
The size of the shadow of dust motes depends on the focus position, and if you take the flats at a slightly different focus position than the lights, you can get ring artifacts like this. The problem tends to be worse on fast f-ratio imaging systems than on slower systems.
that would be easily proven by comparing the diameter measured from the outside center of the light ring to the outside center of the dark ring, and comparing it with the diameter measured from the points of contact of light and dark (which should be perpendicular to the previous measurement. The first will be longer than the second, since the misalignment will make the overall artifact slightly elliptical.
The last time that same pattern happened to me, one of the screws connecting the focus to the EAF was almost loose and the focus axis was slipping.
A test for RASA + OSC in severe light pollution areas
As I recently published in this picture: https://app.astrobin.com/i/mpt4sg I’ve been working on making my RASA11 + 2400MC Pro setup working for a while. However, I was getting very strange artifects even with skylight flats, night sky flats, or flat ...
Flat calibration issues directly relate to author's artifact problems with flats.
Apr 29, 2026
