Redcat51 Loose Focus Help
3 replies106 views
Trey Wood avatar
Hey All,
Just got a redcat51 (first edition) from CN classifieds and everything is fine up until i tried shooting last night. The focus ring locks but it doesn’t hold in place very well. Any pressure or adding/removing my bahtinov mask slides the focus back to neutral.
Have you guys had this issue and if so, any idea on how to fix it. Everything i look up is people having theirs focus ring stuck, which is not my case.
I know a EAF will resolve this issue, however, I would rather that not be the factor in being able to use the scope or not.
If this is the one you have this page from the manual might be helpful:
Trey Wood avatar
Tony Gondola · Feb 13, 2026, 11:12 PM
It wasnt but thanks for checking anyway.
Just posting this here for future if anyone has this issue.
I added a thick rubber band to cover the focuser wheel and the frame (indicated by the green band).
Causes the focuser to be really stiff but actually has helped a lot.
It stays very still and making small adjustments is actually easier.
Definitely will be getting an EAF soon though.
OtarokoOno avatar
The rubber band sounds like a good interim solution until you receive your EAF equipment. Could try taping it after getting into focus, which is how most folks with regular telephoto lenses hold their focus. EAF will certainly help as the temperature fluctuates throughout the night.
Well Written Helpful Respectful Concise Engaging Supportive
Esprit 120 Slippage / Sesto Senso 2
Hey Guys, some time ago I was quite astonished to hear that there are tak toa users that support their focusers with rubber bands to get rid of slippage. First time hearing that people support their premium scopes with rubber bands I thought, that ca...
Discusses focuser slippage issues similar to your focus ring not holding position.
Jan 19, 2026
EdgeHD 8 Focus Point Moving
Hello! Curious if anyone can assist here. I have an EdgeHD 8 using a ZWO EAF. Been using it fine for well over 2 years now and everything has been fine until recently. It can’t seem to find focus anymore using Nina/Hocus Focus. What happens is the fo...
Documents focus point movement problem; may contain relevant troubleshooting solutions.
22 days ago
