Sony camera saving as FITS instead of ARW format in NINA
6 replies92 views
Noah Lausen avatar
Hi all,
I use a sony camera paired with NINA, myfiles are saving as FITS to the computers disk however I thought NINA would ignore this and save ARW (sony’s native raw format). I have had trouble with the images being saved as mono aswell… as i can see DSS isn’t reading the CFA/metadata of the files, probably because its not there.
Thanks.
Are you using a native driver? Because otherwise NINA will save images in the pre-set format, FITS. You can choose to save them as 16-bit tiff however.
Well written Helpful Concise
Noah Lausen avatar
I have the ASCOM sony mirrorless driver by Douglas henderson installed, is that the right one?
Check whether the ASCOM plug-in allows a choice of saving format if not then you're stuck. Best way around is use the NINA native driver here:
GitHub - dougforpres/NINASonyCameraPlugin: A plugin for NINA providing direct access to the camera without requiring ASCOM
Noah Lausen avatar
Thank you Andrea, Ill give it a shot. clear skies😊
Respectful Supportive
Noah Lausen avatar
for anyone else seeing this with a sony mirrorless camera:
Once you have installed the sony mirrorless camera plugin in nina, and the driver that the instructions direct you to,
select sony mirrorless camera (ascom) under equipment - camera in NINA
hit the settings button next to the dropdown, and an ascom page should appear (should connect camera and turn on beforehand)
selelect your camera in the dropdown and make sure the setting target aplication in the other tab is nina.
hit ok when your done, disconnect camera and next time you connect the camera it should be listed there.
now the files saved to disk should be ARW, contain metadata.
Posuda Ponsa avatar
Noah Lausen · Feb 13, 2026, 07:08 AM
Hi all, slope 2
Thanks.
Have you checked whether NINA is set to capture in RAW mode within the camera settings? It might be forcing FITS output instead of preserving the original ARW format. Also, could the mono issue be related to a debayer setting being disabled somewhere in the workflow?
Well written Helpful Respectful Concise Engaging
FITS File Analysis Tool Python
fits-analyser.py astronomical_analysis_description.pdf Hello fellow astrophotographers! I've developed a Python script to help me quickly analyze my FITS files and track my progress across different targets and filters. The main goal was to get a cle...
Analyzes FITS files; could help diagnose metadata/CFA issues with saved images.
Oct 10, 2025
