PixInsight Processing Question – Adding Ha to a RGB Image
PixInsight Addicts 6 replies482 views
Jim Waters avatar
I have been looking through YT off and on for 2 days and haven’t come across a good video on how to add Ha to a RGB image. Many of the processes available within PixInsight use a Blend or Add function. IMO this has a tendency to destroy fine details or produce odd Ha colors. Many of the video’s use Continuum Subtraction which is focused at galaxies based on my understanding. How can I add Ha to an existing RGB target like the California Nebula or other targets that include large Ha regions? Right now I am trying to process an image of the M38 area that has a lot of background Ha. Any help would be appreciated.
Jim
Phoenix, AZ
Well written Respectful
Reggie Jones avatar
I use a script called HaRGB Combo written by Jürgen Terpe - it works really well. I’ve attached a couple of images that describe it in more detail.
Screenshot 2026-02-11 at 8.30.34 PM.pngScreenshot 2026-02-11 at 8.33.58 PM.png
Normalize and add to R is the simplest way to do it. It works on either linear or stretched images, with or without stars.
Peter Hannah avatar
Continuum subtraction is required for any type of target, not just galaxies. It’s required because the broadband red channel includes H-a so it’s designed to avoid ‘double-counting’ the Ha. As mentioned above, the ContinuumSubtraction script is one way to achieve this.
For adding H-a to RGB I find the ImageBlend script by Mike Cranfield works very well (it also works well for adding Lum to RGB).
Well written Helpful Concise Engaging
Joseph Biscoe IV avatar
Jim Waters · Feb 12, 2026, 04:21 AM
Jim
Phoenix, AZ
Here are two tutorials that will explain the process. Vicent’s tutorial is gold you can find it here: https://pixinsight.com/examples/M31-Ha/index.html
And another one that is slightly different but works well is @Charles Hagen tutorial which you can find on his site here: https://www.nightphotons.com/guides/advanced-narrowband-combination/ The nice thing about Charles’ site is he has an icon pack to use for the tutorial. Whereas with Vicent’s you will need to manually create the icons.
Best of luck.
JB
Doug Crowe avatar
Jim
Phoenix, AZ
This is similar to what I wanted to do on Ngc2264. I imaged about 8 hours of IR/UV, but it didn’t have the Ha of the nebula that I wanted. So I imaged about 8 more hours with a L-Extreme. I processed each seperately to get the best “I” could out of each, and removed the stars in both. Then used the imageblend script to combine and add back in the ir/uv stars.
📷 Ngc2264_The Christmas Tree Cluster & The Fox Fur NebulaNgc2264_The Christmas Tree Cluster & The Fox Fur Nebula
https://app.astrobin.com/i/vrzzwp/
Doug
Jim Waters avatar
I processed my RGB + Ha data on the M38 area. I used some of the merge images tools within PI. See the notes and comments for each of the 3 posted images.
  • M38 RGB plus Ha
  • M38 RGB
  • Ha in the M38 area.
Thanks
https://app.astrobin.com/u/jimw85044?i=9h668e
Incorporating Ha into RGB Images
I am still pretty new to mono imaging and it’s techniques, and processing overall. I’ve seen many different ways to incorporate H-alpha into RGB images. I’ve followed an old PixInsight guide of combining H-alpha with the red channel using pixelmath, ...
Directly addresses incorporating Ha into RGB images, matching author's core question.
Nov 6, 2025
"Emissionless" Processing - Advanced Technique for Isolating Emission and Continuum Components
Hello everyone! Not too long ago I compiled a step-by-step guide for subtracting emission from broadband images. Some of you might be familiar with continuum subtraction - this is similar in principle, just instead of subtracting the continuum, you s...
Covers continuum subtraction technique author mentioned; explains emission/continuum separation.
Aug 22, 2025
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Discusses combining broadband OSC with extracted Ha and OIII data in processing.
Sep 5, 2025
M31 Andromeda Galaxy looking for critiques
I finally settled on this version of M31 reprocessing M31 a few times. I have seen different version of M31. I add the Ha using Continuum Subtraction and adding Ha to RGB scripts in Pixisinsight. I finally fixed my star issue by not using a CC templa...
Demonstrates Ha addition via continuum subtraction method author referenced.
Nov 6, 2025
