Are my stars elongated?
14 replies191 views
Astro Jeep avatar
I have dabbled in astrophotography off and on for about 10 years, and I would go years between sessions. Recently, I decided to take it seriously, and when I finally commit to something, I usually become a perfectionist.
So, despite the years I have dabbled, I am still a noob when it comes to astrophotography, so I ask the question whether my stars are elongated. I ask because, if they are elongated, they are only about two or three pixels elongated. I am questioning myself because when I made a star mask in Pixinsight, it shows round stars.
I also understand that some of the stars that I “think” are elongated could be double stars, or the stars could be distorted due to the nebulosity. Obviously, the larger stars are more uniformly round, which is why I continue to question myself.
The stars below are 30-second stars. My 10-second stars were distinctly elongated due to poor guiding, and my 120-second stars were more round, but I could not figure out how to tame them because they were more bloated and harder to reduce in post-processing.
I would sincerely appreciate any feedback or suggestions to help improve them.
Thank You!
Darryl
(Edited to remove TIFF files and to replace with JPEGs, and added a raw .xisf file)
The link to the full-size image, in case you need to see a more zoomed-in rendering:
https://app.astrobin.com/u/AstroJeep?i=vrbd6q
📷 IC434_HSS_30s_Stars_Final.jpgIC434_HSS_30s_Stars_Final.jpg📷 IC434_30s_RGB_OnlyStars.jpgIC434_30s_RGB_OnlyStars.jpg📷 IC434_30s_RGB_StarMask.jpgIC434_30s_RGB_StarMask.jpgThe link to the RAW PixInsight file:
masterLight_BIN-1_3856x2180_EXPOSURE-30.00s_FILTER-R_mono_drizzle_1x_autocrop.xisf
That's a very unusual rendering of IC432 and surroundings. Why bother with the RGB if you aim at basically a colorized version of a B&W image? But, regardless, you can't post tiff files on the forum, just jpg/png/bmp for straight rendering. Also, if you want a serious analysis you'd need to provide a raw file or its auto-stretched rendering (as an image file, see above) for all to see. ATM I can't see a damn thing.
Salvatore Iovene avatar
Astro Jeep · Feb 11, 2026, 05:53 AM
📷 IC434_HSS_RGB_30s_Stars.tifIC434_HSS_30s_Stars_Final.tif📷 IC434_30s_RGB_OnlyStars.tifIC434_30s_RGB_OnlyStars.tif📷 IC434_30s_Star Mask.tifIC434_30s_Star Mask.tif
Just a quick note: browsers do not render TIFF files natively, and AstroBin does not convert them in the forum. Upload JPEGs to make them visible, or attach as files instead of images.
Well Written Helpful Concise
Astro Jeep avatar
Salvatore Iovene · Feb 11, 2026 at 07:50 AM
Thank you, Salvatore. I didn’t know TIFF’s couldn’t be rendered natively. I will upload JPEGs soon.
Astro Jeep avatar
andrea tasselli · Feb 11, 2026 at 07:39 AM
I used RGB stars because I only shot in Ha and SII to make an HSS palette. I specifically wanted the nebulosity to appear white, as if it were a cloud. Because of that, I decided to shoot RGB stars, because I didn’t want to take OIII images to convert the SHO stars into RGB stars later. I am simply experimenting.
I took the TIFF files down. I didn’t realize that you wouldn’t be able to see the TIFFs, and I will post JPGs soon. Thank you.
Rick Krejci avatar
It’s hard to tell since your processed stars at very flat, without a gaussian fall-off. But, yes, they look kidney shaped, likely from guiding errors. Something like BlurXterminator would help, or better yet figure out the root cause and correct if possible.
Depending on what software you use, you can usually get a property of a raw called eccentricity. I usually aim for below .45 or so.
Astro Jeep:
Quote this post in your reply. If you select text, only the selection will be quoted.
From what I can see in the processed image it isn't simply an elongation but rather a bi-axial variation of the stars' shapes (triangular to linear) which might hint to a deeper seated issue with the optics. This is why providing access to a raw file would yield more insights than anything else.
Well Written Respectful Concise Engaging
Astro Jeep avatar
Rick Krejci · Feb 11, 2026 at 02:23 PM
I tried BlurXterminator, and I would rather always fix the root cause. I have a set of 120-second RGB stars that had much better-shaped stars. I didn’t use them because I was having a difficult time reducing the bloat, but if I used those instead, I am sure I would get stars with a nice Gaussian fall-off. That point you made was worth making the post alone. Thank you, Sir.
Respectful Supportive
Astro Jeep avatar
andrea tasselli · Feb 11, 2026 at 02:33 PM
Astro Jeep:
After reading your reply, it occurred to me that I had not performed a sensor analysis to determine whether my sensor was flat. It is probably slightly off. I know it most likely isn’t a guiding issue because PHD2 showed near-perfect guiding that night. I also added the raw .xisf file from PixInsight as you requested. I really appreciate your insight, so thank you!
Post an unprocessed raw file of one of the colour channels, or Ha for that matter without anything done do it. The one you posted is the star mask of the composite, useless for any investigation.
John Hayes avatar
Astro Jeep · Feb 11, 2026 at 02:34 PM
If you have PI, just use the FWHMEccentricity tool to actually measure the ellipticity of your stars. As you are learning, there are a lot of factors that can cause elongated stars and guiding is only one factor. You also need to make sure that your optics are good, that they are well aligned and that the sensor is not tilted with respect to the image plane. Mechanical vibration due to wind or other factors can also cause elongation.
The very first thing to do is to learn how to measure the elongation yourself and if you have PI, you already have a number of tools to do that. Then start working through your system to identify problems. FWHMEccentricity can be used to evaluate sensor tilt simply by analyzing a dense star field and looking at the eccentricity contour plots over the whole field. It’s best to start with short exposures to reduce the effects of guiding and vibration. If the field is not symmetric, you might have a problem. Then go to longer exposures to see if things get worse and if they do, then figure out why. Imaging systems are very sensitive to small errors so a huge component to being successful at astro-imaging is learning how to solve problems and to do that you have to learn to be very methodical. You’ve taken the first step—namely asking if your star images are round. The next step is to figure out how to determine that yourself. After that, you have to work to identify potential causes and then tests to confirm or eliminate them. It’s a slow and sometimes frustrating process but it is immensely satisfying when you get things figure out.
Good luck with it!
Well Written Helpful Respectful Engaging
Astro Jeep avatar
John Hayes · Feb 11, 2026 at 04:22 PM
Good luck with it!
John,
I appreciate the detailed explanation. Fortunately, I have a technical mindset, so I enjoy (to an extent) these challenges. I do have PI, so I will do as you suggest and use FWHMEccentricity to figure out my issue. Thank you!
Darryl
SonnyE avatar
Based on what you’ve presented my opinion is they are not elongated.
I would say soft (out of crisp focus). Maybe overexposed which can make them soft in my experience.
I’d suggest you work with your exposure times by shortening them and increasing the count. And pay attention to your guiding specs. Tighter guiding leads to sharper stars and better details overall.
I use PHD2 for guiding and NINA as my overall control program. My guiding runs 0.2 to 0.3 RMS averages. Well below the coveted 0.5 averages. I believe that is because also I don’t move my mount from day to day. So it retains its Polar Alignment month after month. (Much like having a pier, and not dismounting the telescope.)
You will be able to gage by the tiny stars getting tinier and more numerous. And the larger stars shrinking. Just a matter of fine tuning.
Well Written Helpful Engaging Supportive
Astro Jeep avatar
andrea tasselli · Feb 11, 2026 at 04:19 PM
I just posted the masterlight for the red channel. I could not get it under the 20MB file limit without selecting the 16-bit unsigned integer format. I hope that isn’t an issue. My masterfile has ScreenTransferFunction and HistogramTransformation applied. Lesson learned. From now on, I will copy my masterlight files BEFORE starting any preprocessing work, so I always have an untouched version. Again, I appreciate your help.
There is clear elongation (about 25% on average) in the image file shared worsening from the upper right corner toward the bottom left but nearly equally bad in the whole lower left quadrant that got be a bit stumped… Given it's only a 30s integration I doubt that there would be much periodic errors. Shoot the NP (SP) with tracking off for a set of 5s shots, something like 50 of 60 would do. Calibrate and stack and that would definitely clear the source of the issue which I think is more toward tilt than anything else. But that is an easy test to make and essentially fail-proof.
