ToupTek is getting closer to breaking the monopoly (StellaVita 2.0))
SonnyEEric GagnéTiffsAndAstroAli AlobaidlyTony Gondola
54 replies1.8k views
Ali Alobaidly avatar
Hello AB!!
About a year ago, I had early hands-on time with what was then called Astro Station. I made a YouTube video and a few forum posts about it here and there…
At that point, it was obvious what they were trying to build: an open, brand-agnostic alternative to the ZWO ASIAIR, but it also wasn’t hard to see that it simply wasn’t ready. The concept was solid, the execution wasn’t. Since then, Astro Station has effectively been retired and reborn as Stellavita, and after hearing a lot of quiet chatter about recent updates, I decided it was worth revisiting properly and making an updated post and video. I will link to it at the end of this write-up. The main selling point of Stellavita isn’t that it’s “better” than ASIAIR in every category, it isn’t, but that it doesn’t care what brand you use. During my testing, I ran mixed equipment without friction, and that alone will matter a lot to a certain segment of imagers. This is the full setup I used:
ZWO AM5N
ToupTek ATR2600M
ToupTek 7×2" filter wheel
GPM462M guide camera
Compared to my first experience a year ago, the app is almost unrecognizable. At power up, you are greeted with a screen very reminiscent of the ASIAIR UI:
1.pngIf you click on the connection tab at the top right of the screen, it will prompt you to choose your equipment. In my case, it detected all my connected devices. When it didn’t, it was due to the DC outputs not yet being turned on. You can simply click Connect All, and it will connect to your devices seamlessly.
3.pngOn the left side of the screen, Stellavita displays real-time imaging overlays. These include the guide graph, the histogram, and a crosshair, all of which can be individually toggled on or off to keep the screen as clean or as data rich as you prefer. There is also an option to detect stars in the image.
4.pngOn the right, you’ll find the camera capture controls, including gain, exposure time, and the capture button for taking single frames or starting sequences. From here, you can also swipe left to access quick settings and controls for all your gear. If you want to access the full settings for your equipment, you can click the gear icon in the bottom right corner instead.
5.pngThe bottom left corner is dedicated to equipment control modules. From here, you can open panels for the mount and focuser functions.
Foucuser.pngThis is also where you select between Single Capture, Record Mode, and Plan Mode, depending on whether you’re testing, capturing manually, or running an automated session. You can also access the Sky Atlas by clicking on the constellation icon.
Here you can also open the full guider module:
Guider.pngWithin the Sky Atlas, you can search for targets, manually point at one, slew and center, toggle the horizon line, enable or disable equatorial coordinates, access the compass, and use the framing and rotation tools to match a desired camera angle. I tested all of these functions successfully with very few issues.
7.pngI was able to autofocus with default settings, polar align, configure a plan to capture two separate targets consecutively, and guide without much of an issue. Here are some screenshots:
Autofocus
V-Curve.pngPolar Alignment
PA.png Capture Plan
Capture-plan.pngPlan Progress
Plan-progress.pngFunctions like guide on start, autofocus at a given time interval or on filter change, and slew and center between targets all worked seamlessly.
Here is where I did encounter issues, however. There is still no automated flat exposure calculation, no automatic flat-panel support, and no rotator support. ToupTek has informed me that they are actively working on adding these features, as well as continuing optimizations across the rest of the app.
There are also still issues with the connection. The WiFi signal is very weak, even when very close to the device. I experienced one instance where the signal dropped when the telescope slewed and the device moved out of direct line of sight. On my video, ToupTek commented with a suggestion to use a stronger WiFi dongle, such as the AC1300. I believe I have one somewhere and will be testing that, but it will still take up one precious USB port. The new app is also not yet available for iOS, but hopefully that will change soon.
I am happy to answer any questions, and I hope you found this useful. You can watch my video here if you’d like.
https://youtu.be/kvuNpBUgBeQ?si=Rq6OlRGig5Gd4apT
Clear skies,
Ali (AstraPharma)
V avatar
This is good to see. With ToupTek’s pricing, I fully expect that they will outperform ZWO if they continue to put on this kind of pressure where ZWO dominates currently.
Well written
Eric Gagné avatar
I haven’t seen the new version yet, the iOS version still has not been released but I hope they closed some of the gaps with the Asiair as far as functionality goes. The current 1.xx version leaves a lot to be desired.
  • No temperature settings in plan mode.
  • No auto flats
  • Plate solving not showing any information (object and star names)
  • Very very limited objects database in the planetarium
  • Not possible to create personal categories in the favorites
  • No import/export of targets in plan
  • No guiding log (that’s pretty bad)
  • Still some bugs with certain hardware..though this could be the manufacturer driver, not the SV.
I like the SV but like I said, still leaves a lot to be desired.
TiffsAndAstro avatar
I can't see the appeal over a mini pc and svbony241
It's £300 on Ali express which seems optimistic
SonnyE avatar
TiffsAndAstro · Feb 10, 2026, 11:44 AM
I’m with you. I’ve been using a Powered USB hub since my beginning, long before the ASI Air was a twinkle in its Daddies eye.
And I’ve used laptops, so I have a fully functioning computer at my mount and linked to my indoor computer.
I tried the minicomputer route for a while, but I about wore a path between my indoor computer and the mount because I had no visual out there.
So I went back to something with a screen (display) at my mount. A touch pad, then back to a laptop. Besides, sometimes I like to stay out at my mount and play in the dark (usually in the Summer).
SonnyE · Feb 10, 2026, 04:44 PM
Nothing beats a miniPC. I have three Mele Quieters on three rigs atm and can't see myself switching. But I do understand the appeal of these devices, I've used the ASIair regularly before and that thing is a beast, for most people it's the best choice there is honestly, I just hate being locked into one ecosystem.
Also, I can never live without NINA's advanced sequencer …
SonnyE avatar
Ali Alobaidly · Feb 10, 2026, 05:06 PM
But… you cannot see anything going on with the Mele’s. You have to find a screen somewhere else. With my laptop, I have a full computer at hand at the mount.
That is why I parked my mini computer. Too much of a PITA. 😉
I tend to agree. I can see the appeal to a beginner who just wants to keep things as simple as possible but other then that, a mini pc or laptop makes a lot more sense.
I got a £50 brand new mini pc to replace my 10 year old MacBook (bootcamp) and then a sv241.
Mini pc lives in a blue freezer bag on my tripod shelf.
Only one power and one usb cable goes to the sv241 on payload.
Only thing I'm missing is dew heater control. They stay on
Might have a struggle for usb sockets if I get a eaf or filter wheel.
Ali Alobaidly:
Those who travel and/or run off battery power will have more appeal.
Setting my windows 11 mini pc to either connect to my home router or if not in range create its own hot spot does not look like fun.
Not to mention chrome remote desktop requires interwebs.
Mini pc would use up battery pack much faster than Stella vita class device too.
SonnyE avatar
Tony Gondola · Feb 10, 2026, 06:36 PM
My original Laptop died. And the Mini computers were just gaining steam. So I tried it. Majorly disappointing for me. It dropped the Wi-Fi signal a lot. I did a lot of acrobatics to try and make it work, network extenders, antennas, stuff like that.
But the biggest problem was no visual at my mount. Some may not care. But doing Polar Alignments and anything calling for seeing where the scope is aimed sent me trapsing back and forth.
My laptop just works better all the way around. And it never has a problem with dropping my Wi-Fi. And it stores my images directly to my SSD, which makes the files portable.
Me being me, I only have two wires needed, 12VDC power, and my USB from the powered hub. (Except I have added heaters in the last year (finally) but routed those differently.)
Anyhow, for me my laptop / fully functioning computer has worked best.
I can see my mini pc when I'm queueing at the local garage for emergency beer.
Put chrome remote desktop on the mini pc and any device will connect to it. Internet on both ends is required though
I now use my laptop when polar aligning, standing at the mount, but go indoors to do the rest.
Sometimes I use my phone, but it's a little clunky.
SonnyE · Feb 10, 2026, 07:09 PM
Best of both worlds: one laptop, multiple miniPCs lol
Ali Alobaidly · Feb 10, 2026, 07:16 PM
Where are you, it looks like Mars!
SonnyE avatar
Tony Gondola · Feb 10, 2026, 07:24 PM
Not inside the house…. 😉
Eric Gagné avatar
I have 38+ years of experience as a programmer, I know my way around computers and I’m pretty sure I can learn nina in a few hours………but that doesn’t mean I want to.
Why is it that every discussion about the Asiair or Stellavita or anything of the type, anywhere on the internet turns into a discussion about nina.
People…..live your life the way you want and let us live ours the way we do.
SonnyE avatar
TiffsAndAstro · Feb 10, 2026, 07:11 PM
I had a beer emergency last night. 😆 I was out of beer, the wife was staying at the Son’s house to run the Grandkids to school today, and I made a code 3 run to the store. They were having a sale on my brand, so I bought double. 🙄
I shan’t have any emergency for a good long while now. 😵‍💫 One a day keeps the Doctor away…. I brought home 2 - 30 packs. 🤫 I’m a naughty boy.
Al-Salmi desert in Kuwait, you do feel like a Martian there most times so close enough lol ..
SonnyE avatar
Eric Gagne · Feb 10, 2026, 07:46 PM
I think because NINA is a natural step towards automation. I ran by hand basically for over 9 years before I finally got serious about automating.
How about we all just enjoy things the way we want to, including you. I like many others, needed help automating. So I incorporated Cuiv for the humps I couldn’t get over by myself. But if you like doing hand held with your Sam Yang, please enjoy.
SonnyE avatar
Ali Alobaidly · Feb 10, 2026, 07:56 PM
Wow! Probably no light pollution there, Huh?
I bet you get great night skies!
ToupTek Astro avatar
Thank you for sharing your feedback and experience!
John Tucker avatar
Why does anyone use ASIAIR?
I’ll tell you exactly why: Because somewhere in the course of 90-120 minutes of
  1. Loading and installing ASCOM
  2. Loading and installing drivers for mount, camera, autofocuser, etc
  3. Loading and installing a program that sits on top ASCOM which I will eventually have to learn to use (remember when Sharpcap was a simple program that could be used on inspection?)
  4. Adding in plate solving programs and databases and trying to do so in a way that aforementioned master program interacts with them
  5. And loading PhD2 and telling Master Program how to find it on my hard disk
I get “Exception Error Ju##78639876349d/xXT! Permission denied!”
And no one seems to be able to tell me what Exception Error Ju##78639876349d/xXT is and how it differs from Exception Error Ju##786391763139d/xXT.
Or once everything is loaded, the master program repeatedly insists that it cannot find the camera driver which I’ve installed 3 times
Or finally having found some computer literate person who modifies my registry and gets it all working, Windows updates, and the whole thing falls apart while I’m out at a dark site I’d planned to spend a week at. Or more optimistically, it just starts installing an update that takes 20 minutes and requires me to reboot my laptop 4 times just as I’m trying to get a session started.
Or I’m out at a dark site 40 minutes from the nearest WiFi signal with my gear all set up, and when I start my laptop, my acquisition software tells me my license has expired, and that I need to enter credit card info at their website before I can proceed.
ASIAIR makes me crazy in a variety of ways. But on the other hand, as I type this, I have a laptop next to me that I cannot use to drive my sessions, because after some 5 hours of installation and troubleshooting, I still can’t get PhD2 to detect my guide camera.
My response when I learned someone was going to sell a mini computer with all that stuff preloaded and actually functioning? WHOOOOOOO HOOOOO!.
If you use an iPad instead of your phone, the visibility isn’t that bad.
John Stone avatar
Ali Alobaidly:
Tell me please, how did you get the ZWO pier extension attached to the Skywatcher EQ6-R tripod?
Or is that the EQ5 tripod?
They look exactly like my EQ6-R tripod in the picture.
John Stone · Feb 11, 2026, 07:59 AM
Ali Alobaidly:
This is an EQ5 Tripod, but you can use your EQ6-r tripod too with something like this:
https://ar.aliexpress.com/item/1005010469403417.html?spm=a2g0o.productlist.main.1.5ed735c5zMKmnv&algo_pvid=93fe6ebe-f802-49f0-b1fe-179abc0c8939&algo_exp_id=93fe6ebe-f802-49f0-b1fe-179abc0c8939-0&pdp_ext_f=%7B%22order%22%3A%221%22%2C%22eval%22%3A%221%22%2C%22fromPage%22%3A%22search%22%7D&pdp_npi=6%40dis%21KWD%2110.039%2110.039%21%21%21218.24%21218.24%21%402101246417707995080662613eb652%2112000052516624351%21sea%21KW%214524304355%21X%211%210%21n_tag%3A-29919%3Bd%3Ab736bc60%3Bm03_new_user%3A-29895&curPageLogUid=digp0hppqeb8&utparam-url=scene%3Asearch%7Cquery_from%3A%7Cx_object_id%3A1005010469403417%7C_p_origin_prod%3A
Make sure you choose the EQ6 version out of the available one!
Is Touptek coming up with a mount?
I just watched a 30 seconds video on Touptek YouTube channel about a T-Forty carbon fiber tripod. If they come up with a tripod they must have plans to have something to put on it.
ToupTek developing new astronomy equipment aligns with author's speculation about upcoming products.
29 days ago
Only able to Connect to Stellavita V2.0.6/2.0.15 with iPad
I just purchased a Stellavita and have one session under my belt. I just downloaded the latest App version 2.0.6 and firmware version 2.0.15. These introduce the Live Stacking feature. I use an iPad to connect to the Stellavita. I have a M3 MacBook P...
Author just purchased Stellavita 2.0; post discusses ToupTek competition and features.
25 days ago
