I have an 8×31mm EFW and I am trying to decide on a filter to go in the currently empty 8th slot. I have clear, RGB, HSO in there now.
Do I go with an IR pass filter? Or block it off for darks? Or something else?
When I was doing mono shooting, I took an old filter and blacked it out so I could automate gathering darks with Position 8.
I programed Darks and Bias’ with hole 8, in NINA. Worked great.
andrea tasselli · Feb 8, 2026, 09:52 PM
Hbeta
Thanks i have used a H beta filter before and didn’t find it terribly useful.
John Stone · Feb 9, 2026, 11:30 AM
Nii (3nm) from Chroma.
For Darks and Bias you can use Sii with the end of your scope covered (like with a Deep Sky Dad flat panel)
Thanks, a bit rich for my wallet I’m afraid.
Since you have a Newtonian I would choose a clear filter. About 20% to 40% more signal for you luminance data depending on the sensor compared to a UV/IR cut.
Yes I am already using a clear filter for luminance (instead of a UV/IR cut filter). That’s why I’m not sure about the IR pass filter in the 8th slot as I’m already capturing that signal in my luminance subs.
I think I will get an old filter and paint it black to use for darks, seems the most useful way to use the slot.
Craig Towell · Feb 9, 2026, 01:12 PM
Hbeta
For Darks and Bias you can use Sii with the end of your scope covered (like with a Deep Sky Dad flat panel)Thanks, a bit rich for my wallet I’m afraid.
The Ir pass would only make sense if you have a lot of light pollution or if there are structures in the near Ir you want to bring out.
That is what I did Craig.
Mask off the threads well. I used flat black, spray paint. 2 coats.
No need to go out and cap the telescope for Darks and Bias frames. 😉
