Advice for rig upgrade
11 replies151 views
Davide Maino avatar
I would like to upgrade my rig both in terms of diameter and in focal length. I actually have a SW 150 Quattro telescope with ZWO ASI 294MM Pro with Antlia LRGB and 4.5 nm filters. My mount is a SW EQ6R Pro. I leave in Gorgonzola (yes, right just like the cheese which was indeed invented here) nearby Milano with Bortle 7 sky and with clear view on N-E and SE part of the sky limited by my balcony with a typical observing time per object/night of about 2 hours (slightly dependent on the object declination). So I’m seeking for advice in this respect: I was thinking about another Newton (200 f5) or maybe an 8” RC. What do you think/suggest given my usual observing conditions?
Stick with it. Going slower isn't gonna help you. If you really want more focal length then your way up is with a 200 f/4 newton (but not a Quattro!).
Brian Puhl avatar
I think your better upgrade is getting rid of the 294 and moving to an IMX571.
Davide Maino avatar
andrea tasselli · Feb 5, 2026 at 08:57 AM
Thanks. Since you are italian which brand (that I can buy here in Italy)?
Davide Maino avatar
Brian Puhl · Feb 5, 2026 at 01:14 PM
This would have an impact on filter wheel as well on filter size. What’s wrong with the 294? But for the amp glow (that is perfectly cure with darks) it is a great camera with in bin 2 mode quite large pixels.
The limited integration time per night is your biggest limitation. Because of that and because your light pollution level isn’t that bad I would look for a faster system and a slightly larger aperture. If the budget can handle it, going with a C8 and Hyperstar or an 8” RASA, would give you the most benefit. Those low f-ratios will make the most of your limited imaging time.
Brian Puhl avatar
Davide Maino · Feb 5, 2026, 05:45 PM
superior, bigger sensor, more pixels, doesn’t have issues with calibration. You’ll have alot better field of view. Going to a longer focal length with smaller sensors is rarely an upgrade. Also, you asked ‘given your sky conditions’, but we don’t know your seeing conditions. That is a very important piece of the puzzle to factor in. It looks like you’re near the base of the mountains which will likely contribute to very poor seeing conditions. There’s a pretty good chance you’re already seeing limited.
Davide Maino:
Guarda su Tecnosky: Astrografo newton 200/800 Tecnosky CARBON Series
Altrimenti Teleskop Express
L' ASI294MM e' un ottima scelta checche' ne dicano gli altri.
Willem Jan Drijfhout avatar
Davide Maino:
I'm not Italian, but if I were looking for a scope in this category, I would have a close look at the Artec series of astrographs. And they are Italian made....
Davide Maino avatar
Thank you all. Now I have the following possibilities: 200/400 carbon (Tecnosky) around 1k€, an 8” tecnosky RC with 0.67 reducer, all possible spacers and 60mm guide scope at around 700€. But I was also thinking about staying on 6” but moving to a carbon tube with robust focuser. What do you think?
The carbon tube won’t really gain you much compared to what it costs although a better focuser is never a bad idea, assuming the stock unit isn’t up to the task.
Well Written Concise
Not worth it. Just replace the existing focuser on the Quattro if you feel isn't up to the task.
Which newton scope for observatory
This year I will do an upgrade from a newton 200 F5. I'm hesitating between a 250 F4 or a 300 F4 with a 3" 1.14 coma corrector. The mount can handle the weight and its inside an observatory. Thx for the feedback
Discusses rig upgrade with diameter and focal length considerations for imaging.
Jul 4, 2025
Seeking advice on next steps in my astrophotography journey
I’d really appreciate your views on the next steps on my Astrophotography journey. Having been doing this amazing and absorbing hobby now for just under two years, I know that my journey has progressed from bafflement with how to use the equipment an...
Author seeking upgrade advice; similar journey stage and equipment considerations.
Feb 5, 2026
I would appreciate some general gear advice from experienced people...
Hey all, firstly this community seems excellent. A lot of people and a lot of knowledge. So, I was hoping I could get some general advice here. I’ve been very interested in space since I was a kid. The subject of Astrophotography always seemed too ou...
Author explicitly wants gear upgrade advice from experienced astrophotographers.
Jan 26, 2026
Upgrading from Quattro 200CF to 300P: seeking owner experiences and advice
I’m seriously considering upgrading from a Quattro 200CF to the Quattro 300P and would love to hear peoples’ opinions on the scope. I plan to get a CEM70 to run it. My image train is the ZWO ASI2600MM, ZWO 7×36 EFW, ZWO OAG-L, ZWO EAF. I already own ...
Author has Quattro telescope; upgrading scope diameter/focal length directly relevant.
Aug 28, 2025
