New star removal tool
Tony GondolaWillem Jan DrijfhoutAloke Palsikarpatrick cartou
26 replies922 views
There’s finally a new star removal tool out there that’s worth looking at. It’s called Zenith-V1 by Syqon. It’s available as a script for both Siril and SetiAstroSuite, not sure about PI but I can’t imagine it won’t make its way there at some point.
The first time I tried it on some M-51 Ir data, I thought it wasn’t working well. My resulting starless image had a lot of small dots left behind. My first thought was “fail” but when I looked closer I realized that those dots were all very small field galaxies that are normally mistaken for stars and removed by Starnet++ so that impressed me. I tried it on a few other images and I have to say it worked very well. The biggest overall difference is that it leaves a very clean starless image behind. Almost no clumps or ghosts of the brighter stars in the field. If you’ve spent time with blemish blaster or a clone stamp cleaning your starless images up, you’ll know what I mean. The only thing to keep in mind is that it is used post stretch, not pre. It doesn’t need to be the final stretch but it needs at least a light statistical stretch to work properly.
John Stone avatar
Just bought it and tried it out.
It does work better than StarXTerminator in the sense that it doesn't remove nebula around the star
StarLess v1
StarXterminaor
That’s what I’ve found to be it’s greatest strength. That and making a very clean starless image, at least when compared to Starnet++
John Stone avatar
Have you found a way for the tool to produce a stars-only image?
The image above I had to create with PixelMath expression subtracting the normal image from the starless image produced by the tool to create the stars-only image.
This isn't as nice as StarXTerminator since the background does not end up pure-black (0 ADU count)
Well written Insightful Respectful Concise
The version I use in Siril has an check box option to create a star mask. The commercial version must have something similar.
Willem Jan Drijfhout avatar
Wouldn't the need for a stretch before star removal make it a bit pointless? The whole reason to eliminate the stars is to stretch the non-star areas without having to worry about the stars (clipping etc).
Well written Insightful Respectful Engaging
SonnyE avatar
I’m curious if anybody has published a starless image on Astrobin to see if it can plate solve the image.
I’d try it myself, but I don’t drastically alter my images.
Salvatore Iovene avatar
SonnyE · Feb 10, 2026, 06:21 PM
AstroBin cannot plate-solve starless images. Plate-solving works by detecting stars and triangulating positions against reference databases.
Well written Concise
Hence the name: plate-solving.
SonnyE avatar
Salvatore Iovene · Feb 10, 2026, 06:23 PM
As I suspected, Salvtore. Thank you for clarifying that.
Willem Jan Drijfhout · Feb 10, 2026, 05:52 PM
Not a full stretch or you’d be largely correct. That said, I’m finding that it also works fine pre-stretch as well.
Mark Fox avatar
This appears to be great stuff, from what I am reading on the SyQon website. I’ve always been a bit disappointed with the blotchiness of starless output.
As of today 10Feb, it appears that the software has been rebranded to SyQon Starless. To get this in Siril, look for the Python script SyQon_starless.py. I didn’t see any mention of the “Zenith” name.
Cyril Richard avatar
Tony Gondola · Feb 5, 2026, 12:18 AM
Hello.
Zenith is a model developed exclusively for Siril from scratch :). We now have version 1.3 of the model available. Therefore, neither SetAstro nor PI will be able to use it because SyQon has drafted a very specific license regarding this matter.
Well written Helpful Concise
Victor Van Puyenbroeck avatar
I would need to ask the author, but I believe Starnet++ was trained on non-linear data.
I always assumed that, if the ‘linear data’ checkbox is ticked in PixInsight, Starnet will apply a stretch before the star removal step. Once complete, an inverse stretch is used to transform the starless image back to a linear state.
Victor Van Puyenbroeck:
Ah, yes, that makes sense. Thank you.
The website of the developer of this tool (Syqon) also shows some other products. NovaStudio, one of them, claims to be a complete processing suite. There is very little information in the community on this software, let alone a full review. The few comments I did come across were unanimously negative, to the level of 'does not work as advertised'. Also the company does not offer a trial period.
Does anyone have experience with this tool? And if so, what do you think of it?
Well written Engaging
They offer a free model in Siril. So better than a trial.
You can try it right now.
Aloke Palsikar avatar
I tried the new SyQon Star Removal tool in Siril and the result is very good. Does a bit of denoising and also the artefacts of Star Removal which one sees in StarNet are either not there or very minimal
I use a Intel Macbook and still the performance was decent. All the relevant scripts required for installation are given in the Comments and work beautifully
Good tool from Zenith for Siril
Cyril Richard · Feb 11, 2026 at 11:20 AM
I was referring to Novastudio. Is that also available within Siril?
Well written Respectful
patrick cartou avatar
Hi all
I’m just coming to test SyQon Star Removal tool and obtained this result:
15:00:08: Début du script /home/cartou/.var/app/org.siril.Siril/data/siril-scripts/processing/SyQon-Starless.py
15:00:08: Installing scipy. This may take a few seconds...
15:00:09: Collecting scipy
15:00:10: Downloading scipy-1.17.0-cp313-cp313-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl.metadata (62 kB)
15:00:10: Requirement already satisfied: numpy<2.7,>=1.26.4 in /home/cartou/.var/app/org.siril.Siril/data/siril/venv/lib/python3.13/site-packages (from scipy) (2.3.5)
15:00:10: Downloading scipy-1.17.0-cp313-cp313-manylinux_2_27_x86_64.manylinux_2_28_x86_64.whl (35.0 MB)
15:01:26: ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 35.0/35.0 MB 493.5 kB/s eta 0:00:00
15:01:26: Installing collected packages: scipy
15:01:31: Successfully installed scipy-1.17.0
15:01:31: Traceback (most recent call last):
15:01:31: File "/home/cartou/.var/app/org.siril.Siril/data/siril-scripts/processing/SyQon-Starless.py", line 95, in <module>
15:01:31: th = s.TorchHelper()
15:01:31: ^^^^^^^^^^^^^
15:01:31: AttributeError: module 'sirilpy' has no attribute 'TorchHelper'
15:01:31: Le processus Python (PID : 3066) s'est arrêté avec le statut 1
What does it mean ?
Thanks by advance.
Best regards.
Patrick
Check the comment text in the script. You will need to install Torch through the 5 lines of script given in the text comments. Run it within Siril itself. This should work
Thanks a lot Aloke !
I don’t know really how and where exactly insert these 5 lines of script, so I’ll wait for the Version 1.4.2 of Siril…
Patrick
Respectful
Watch this You Tube Video by Deep Space Astro and all your doubts will be clarified. A complete step by step process has been explained
https://www.youtube.com/watch?v=8cioH5lctvU
Hope this helps
ZigZagZebraz avatar
The earlier model did not work well for me. But, the Zenith works very well.
Almost no residue in Oiii of bright star compared to Starnet++. Easily manageable with stretch than resorting to Blemish Blaster.
Thanks Tony for the heads up, the Siril team and Syqon for a great tool.
Aloke Palsikar · Feb 11, 2026, 02:58 PM
Hope this helps
Thanks again, Aloke !
Patrick
