WBPP interactive frame selection: tracking included frames for Astrobin uploads
10 replies205 views
Niels_L avatar
I used the new interactive mode for frame selection in WBPP and it works great. It is easy to see what should be rejected in your light frames and what to include. It saves the hassle of getting into SubFrameSelector and making a copy of the selected frames (to delete them after stacking again).
The only thing is that when I want to upload my final image to Astrobin, I am now missing the data of which frames were included in the stack… For example, in my interactive frame selection step during WBPP, I have rejected about half the light frames into the final stack - I just don’t know which days/files I rejected. Does anyone have this solved in their pre-processing workflow?
Well written Engaging
Brian Puhl avatar
WBPP creates subfolders for calibrated, cosmeticized, and registered.
All the files that end up in the final image will be in the registered folder.
Well written Concise
Niels_L avatar
Brian Puhl · Feb 1, 2026 at 03:42 PM
That’s right, how did I not think of that… 🤣
Quinn Groessl avatar
It’d be nice if this was its own process and you could move files like blink. I haven’t used it yet, but watched Adam Block’s video on it and the interface looks pretty good.
Niels_L avatar
Quinn Groessl · Feb 1, 2026 at 05:55 PM
Frame selector in WBPP works well. It is kinda the same as SFS. So I always blink first and then either SFS or Frame Selector in WBPP.
Niels_L · Feb 1, 2026 at 06:45 PM
It looks like it does, but it’ll make my file structure a bit harder to manage once I start using it.
Niels_L avatar
Quinn Groessl · Feb 1, 2026 at 06:46 PM
I had the same, that’s why I was confused on what lights end up in the final image. But the Frame Selector in WBPP saves some extra files that I normally copy from SFS. Now, I just have to check the WBPP registered folder and divide the number of files by 3… Lol
Same same, but different 😂
Steven Zuhoski avatar
I have used it on 3 or 4 images now and it works well but I need a way to remove outliers other than visual (±3 sigma or something).
Doug Crowe avatar
Steven Zuhoski · Feb 2, 2026, 01:56 AM
I am using it, but I prefer the graph that is on the original SFS. On a small monitor, it is hard to see the graphs. I would like to see a toggle button on each graph that would let you see a single graph with a larger view.
Niels_L avatar
Let’s hope they will still improve on the options ;-)
AstroDarks avatar
Check your logs folder. The log file will tell you how many lights were stacked.
Well written
How do I set WBPP to reject files with background issues
Is there a setting to reject the worst subs in WBPP?
Covers interactive frame selection and rejection in WBPP process.
Oct 31, 2025
How to identify which images WBPP rejected during stacking?
I ran Pixinsight WBPP and during the integration step a number of the images are rejected. Not an issue with that but how can one trace back afterwards which images have been rejected? In this instance, I was stacking data from 2024 and 2025 and abou...
Traces which frames WBPP rejected; directly addresses author's missing frame selection data.
Aug 17, 2025
Another question about streaks in images
Hello. I see a lot of posts asking "What causes this?" but none seem to be exactly what I am experiencing. The following image is a simple stretch on my master light stack before any post-processing. This was stacked in PI using WBPP script...
WBPP frame selection and processing workflow directly relevant to your setup.
Feb 3, 2025
"BETTER WBPP SPEED"
Hi, I have a question for computer experts: what should be the main hardware priority of a computer to improve processing speed in the WBPP? Thanks in advance. Ferran
WBPP frame selection features may relate to processing optimization.
Aug 8, 2025
Best way to share PixInsight master stack to Astrobin communiuty
Hi Folks, As the subject line states, what would be the best way to share master stacked image from PixInsight to the Astrobin community?? I wasn't sure if just attaching the masters to a discussion topic would be suitable, or to setup a shared g...
Discusses frame selection and Astrobin uploads, directly relevant to sharing processed images.
Sep 18, 2024
