Canon 5D Mark IV advice?
2 replies290 views
Rod Van Meter avatar
Quick query, I'm leaving in a couple of hours for my first serious DSO shoot using a Canon EOS 5D Mark IV. (Not yet astromodded, but if I decide to make this my main camera, I probably will.) (Glass is Vixen 800mm refractor.) For those who use this camera, what should I know?
Raw+JPEG, check…
ISO 1600 okay?
Anything I need to do about white balance, since I'll be processing raw?
I assume I keep the "dual pixel" whatchamajig *off*?
Since this thing has a mechanical mirror, what do you do to reduce mirror slap?
Shoot with Live View on or off?
How do you handle focusing? I have a Bahtinov mask, but I haven't figured out yet how to get a live view in zoomed mode and with enough brightness to work with the mask. AFAICT, I'm just going to have to shoot longish exposures for focus setup, which also means tracking has to be good when I'm messing with this.
Any gotchas or specific advice on this camera?
Arun H avatar
Raw+JPEG, check…: Just RAW should be fine. You'll process RAW most likely and can always convert to JPG later if needed.
ISO 1600: Should be fine. I've shot at Iso 800 and even 400
WB: If shooting RAW, does not matter
Dual Pixel: Yes, off. It is a useless feature
Mirror Slop: When I was using Backyard EOS, I believe there was a settle time option
Live View and Focusing: This was one of the nice features of this camera. I found that you could just point the camera to a bright star, use the Live View AF to focus on it and then turn the lens to MF. It gave me very accurate focus.
Scott Badger avatar
From my Canon 5D Mk IV use….
As stated above, no need to take jpegs.
I had a significant banding issue at ISO's below 1600.
As above, in RAW WB doesn't matter, you'll set it during processing.
Didn't even know about the dual pixel thing…..
So long as Live View is on, mirror slop isn't an issue. I'm using an astro camera now, but I remember there being a specific sequence to have it on while BYEOS is running…..
With the camera in Bulb mode and LV on, I never had a problem zooming in while using a bahtinov mask. Never tried AF on a star.
Scott
Does Bahtinov Mask work with Mirror Lens/Scope?
Canon camera setup for astrophotography focusing; may need Bahtinov mask guidance.
Mar 17, 2020
DSLR Exposure Question
Hello! I'm a new member and excited to be here! I've been viewing for several years and just recently got into astro imaging. I'm very familiar with standard photography and pretty proficient with a DSLR when it comes to day shots, studio...
Canon DSLR deep sky shooting advice; exposure settings applicable to similar cameras.
May 18, 2020
Andromeda in a bortle 6, should I use a light pollution filter ?
Hello forum, I am planning on shooting Andromeda next week. It will be my first attempt at a galaxy. I recently bought a Optolong L-Pro but haven't had a chance to try it yet so I really have no idea how it will affect my subs. I am wonderingR...
Light pollution filters relevant to DSO shooting with unmodded Canon camera.
Dec 1, 2023
Ideas for handling different setups - how do you deal with your equipment
Hi all of you, over the last three or four years, since I began to do astro photography. I developed a method of handling my equipment. This works for me. But before I write some lines about it, I want to explain the reason for this thread. Astro pho...
Equipment handling methods applicable to Canon camera setup management.
Aug 27, 2023
