Telescope Build for Deep Space photography
20 replies550 views
Ricky avatar
i’m looking for advice on the best deep space Astro photography telescope build with a $4K budget.
John Stone avatar
How small are the things you want to image?
Go make an account at https://telescopius.com/ and create a some Target Lists with different FOVs.
Come back with a FOV and we can recommend some scopes that can get you there.
John’s advice is a good starting point. You’re asking a very deep question so if you could elucidate your goals a bit, that would help.
Well written
David Biggs avatar
$1K Scope (main and guide)
$1K Mount
$1K Cameras (main and guide)
$1K Filters, Focuser, software, other misc
TiffsAndAstro avatar
David Biggs:
$1K Mount
I would suggest more on mount less on everything else.
David Biggs avatar
I also suggest starting with a small refractor around 80mm aperture, as it makes everything simpler to being with. No fiddling with collimation. There are lots of large deep space targets to start with.
I also forgot the tripod. Look for second hand items that aren’t the electronics.
Nicolas Molina avatar
What do you currently have? Do you have a DSLR camera? The mount is by far the more important item. Search the used market, and you will save a few bucks, but use half or more of your budget on it.
SonnyE avatar
Ricky · Jan 30, 2026, 04:13 AM
Do you have anything in particular you’d like it image? My thing has always been Nebula.
But there are many targets out in deep space. Galaxies, Clusters, Nebulae, Etc.
When I was starting out I spent 5 months building wish lists as I studied how to get out there.
I began with an 80mm triplet Refractor. It kept me fascinated for over 9 years, then the update bug bit me.
It’s a tough nut to crack when you are starting out. This is an expensive sport to start out in.
It’s been said, and it is true, the mount is the most important for Astrophotography. It is the foundation for whatever telescope you choose to start with. And it needs to be one designed with AP in mind. You would find poor success with the wrong mount. I made that rookie mistake.
My ED80T CF telescope was good for what it was. And now it lives with 3 of the grandkids and they enjoy the heck out of it. So as long as it is bringing joy, I’d say it was worth the $1000 it cost back then. They just use it for visual. A triplet refractor can do both easily, other telescopes not so much. it depends on which style they are.
Then comes the camera. best to invest in a true Astro Imaging camera. they are built to do the specialized work of AP.
You could probably stretch your money pretty far buying pre-enjoyed equipment. It has its risks though. There is something to be said about having a warranty in case the part turns to crap on you.
In spite of a very rough and rocky start for me, I’ve persevered and kept going. I didn’t get so frustrated that I gave up. Oh, I had lots of nights I quit. But I came back out the next night and kept trying. After a while I began winning. I took thousands of picturds. Then I’d get a picture here and there.
Have you considered something like a SeeStar or equivalent? You could enter with one of those types and then down the road get more expensive items. Or not, just work with a SeeStar type and learn how to coax the best out of it. I’ve seen some impressive images from them lately. They basically have a cell phone camera in them, and electronics to make them practically self running.
Los of ways to skin a cat, without breaking the bank.
Supportive
BlueRidge85 avatar
One thing I may suggest is look into any astronomy clubs in your area. That’s what I did and was able to snag a great system at a great price. You may not be able to “custom” build exactly what you want, for me though the value was worth it. They may not have a full system. I bet through members you could find a lot of prepherials at a reasonable price
Concise Supportive
David Foust avatar
I would recommend a short or mid-focal length triplet or petzval refractor (200-600mm) (with flattener/reducer if not a flat field scope), an Eq6r-Pro or equivalent mount, a 585 or 533mc pro for main camera, ASI 120mm mini or 220mm mini for guiding, a small 40-50mm guidescope, EAF, and AsiAir controller. You can find these items used to save money and you'd probably be well under 4k, with enough saved to buy a filter drawer and a couple filters (maybe a UV/IR cut and duo-band filter, or perhaps a LP filter if needed).
SonnyE avatar
BlueRidge85 · Feb 1, 2026, 01:09 AM
I did that. My local club was so peppered with rules, I changed my mind.
I can’t enjoy myself in a bunch of “Karens”.
Aloke Palsikar avatar
USD 4K is a decent budget to get started with Deep Space Astrophotography. But may need some tweaking if you want to have a decent gear
  1. The most crucial aspect is the Mount. No compromise here. Recommend a Harmonic Mount either a ZWO AM5N - USD 2200-2500 ( approx) or at least a ZWO AM3N - USD 1500 if you want a smaller payload. Preference would be for AM5N as once you go for bigger and heavier scopes later , then no need to change the Mount.
  2. Recommend going in for a good Refractor scope for Astrophotography. Can range anywhere between USD 600-1000. William Optics, Askar, Takahashi are good brands to choose from. A lot of pre owned good scopes are available at lower costs around USD 500-700/- Also look for Clearance Sale options from various stores in your area.
  3. Main Camera. Would recommend ZWO ASI 533 or 585 MC which is one shot color camera (OSC) to start with. Prices range from USD 600-800. Higher end cameras are between USD 1500-2000 Range
  4. Guide scope (50-60 mm)and guide camera (ASI 120 MM) - Approx budget USD 250-300
  5. May need a Controller like ASI Air Pro . Cost would be around USD 250. Alternatively if you are a Windows user you can work with N.I.N.A which is open source and is free
  6. If budget permits you can go for at least one of the basic filters like Optolong L-Quad /L -eNhance an be another USD 150-200
  7. For Image processing a lot of Open Source Software is available like Siril, Graxpert, GIMP etc. No need for licensed ones like PixInsight to start with.
    So most of the above gear should come within USD 4000-4500 range
Hope this helps
Rick Therrien avatar
I wouldn’t argue with any of the suggestions - of course the mount and tripod being most critical.
The new harmonic drives like the AM5 paired with a solid tripod would serve you well.
A small Apo would be the most trouble free scope, but I have been very happy with my 150mm F4 newt (once you get it dialed in)
Fast data acquisition, good star quality, lightweight scope (easy to guide accurately) and
Cheap! (comparatively speaking)
Rick
Rick Therrien · Feb 6, 2026, 12:29 AM
Rick
Much cheaper, not to mention more aperture than most refractors and no concerns about color correction. I’m surprised that newts in the 6” class aren’t more popular.
John Tucker avatar
SonnyE · Feb 1, 2026, 02:44 AM
SonnyE avatar
Tony Gondola · Feb 6, 2026, 01:32 AM
Rick
My final two “Wish Lists” were an Astrograph Newtonian, and a carbon fiber Refractor. My final choice was based on reflectors being finicky and fiddly. (once you get it dialed in) The CF refractor is still in use by two of our Grand Daughters for visual. Something an imaging Newt cannot do. More Here.
So, lots of choices. I’m not yet enthused with the harmonic drive mounts either. But hopeful they improve the tracking and guiding figures. They are still relatively new to the field, so I really expect improvements. But there are many more and better choices than when I was beginning.
Choose what can “Future Proof” you. When I got my mount my ED80T CF looked ridiculous on it. But it was rock solid and my stars in my images immediately shrank to tiny dots, and my focus improved. My 17 pound payload was quite short of its 50-pound Photographic Instrument rating. That’s why I call it my forever mount. It will be inherited after I’m gone but still function rock solid. But my equipment today was impossibly out of reach when beginning. I wasn’t even sure I would be able to use the equipment. So a huge investment just wasn’t in the cards then.
John Stone avatar
Aloke Palsikar:
Also, look into the SAL-33 harmonic mount.  The same payload as the AM5 for 1/2 the cost.
SonnyE avatar
John Stone · Feb 6, 2026, 07:55 AM
SAL-33
Looks like it has some real potential. Breaks away from the ZWO sphere of software. Seems good for those of us who prefer to use independent equipment.
Same 44 pound upper capacity. I wonder when they will get a higher capacity in these harmonics? Or is there a threshold these harmonic mounts can’t cross? (I prefer to stay well under the max.)
Cuiv reviews.
Thank You John for the lead!
Respectful Supportive
SonnyE · Feb 6, 2026, 04:25 PM
SAL-33
Cuiv reviews.
Depends on how much torque the stepper/H drive reduction can deliver/handle. The biggest I know about put out a bit over 120 foot pounds continuous and over 500 foot/lbs at peak.
SonnyE avatar
Tony Gondola · Feb 6, 2026, 05:15 PM
SAL-33
Cuiv reviews.
Sounds huge!
Yep, gearing is everything. As long as it doesn’t get down to hour-hand slow…. 🤔
I had fun with building my first electronic focuser, manual control only. But it made a world of difference in my focusing over my clumsy hand attempts.
I finally joined the EAF ranks briefly, then got a real Auto focuser.
But those stepper motors can grow into real monsters with their gear reductions.
Ricky avatar
Nicolas Molina · Jan 30, 2026 at 07:28 PM
So I currently have two smart telescopes from Unistellar EVSCOPE 2 and Odyssey pro. I bought these before I actually educated myself on Astro photography. they very nice telescopes but they limit you to the ability of picture quality and how far we can see have out.
