iOptron commander 9.20.1
2 replies52 views
Rainer Ehlert avatar
Hi iOptronerds,
Anybody else having or had this problem, not possible to slew “Counterweight Up Pointing” as Pointing state is greyed out, with commander 9.20.1 and how did you solve it. I have CEM 120EC2 mounts and before upgrading to 9.20.1 I had 9.13 and it was working. Downgrading to 9.13 again does not solve the problem.
I wrote two days ago to iOptron suppoert and no answer at all.
Thanks
Skynet Observatory avatar
Rainer Ehlert · Jan 29, 2026, 05:03 PM
Hi iOptronerds,
Thanks
I was trying to figure it out but I though I might ask ChatGPT… Here is the answer… It makes sense, perhaps you can try it? I have a CEM70 but never slew it from Commander, but either from Nina or Stellarium.
ChatGPT’s rationale:
The Counterweight Up Pointing option is grayed out because it is not applicable to the current slew mode / target type, so iOptron Commander disables it on purpose.
What’s really going on
That checkbox is not a global mount setting. In that dialog it is context-sensitive and only becomes editable when pier-side ambiguity exists.
In your screenshot:
  • Catalog Name: Solar System
  • Object: Mercury
  • Commander is computing:
    • RA/Dec
    • Alt/Az
    • Distance
    • Time-dependent ephemerides
For Solar System objects, the driver already knows:
  • The object’s current position
  • The only valid pointing solution that avoids illegal pier states
So Commander says, effectively:
“There is no alternate pier-side solution here. You don’t get a choice.”
Hence: option disabled.
When that option becomes enabled
You’ll see Counterweight Up Pointing become selectable when both of these are true:
  • You are slewing to a fixed RA/Dec target
    (Star Catalog or Custom Coordinates, not Solar System)
  • The target can be reached from either side of the mount without violating limits
In that case, the checkbox means:
“Force the non-default pier side.”
Yes, thank you but look here. I have set that it can slew up to 14° passed the meridian and then it should stop.
Even so at the moment Sadalbari is just 4 degrees before meridian and it is still greyed out…
You can see the time difference between mounts Local Sidereal time and RA time of Sadalbari. 20 minutes difference is 60/15 = 4° per minute and then 20 minutes are just 5° and the mount accepts software and hardware wise 14°.
