ASA DDM 60 for 3000 usd?
10 replies147 views
Jan Hlavačka avatar
I currently have a chance to get the ddm 60 for about 2800 usd, and I’m wondering if it’s worth it. It has apparently been used only a few times and it’s in “like new” condition. I currently run a EQ6R pro and a 1000mm f4 newt, so I am wondering what kind of improvements would I be able to see. I am not sure how old the mount is but from what I checked it looks great. Thank you for taking your time to read this!!
Respectful
Pirate Mike avatar
I do believe that going from your current mount to the ASA will prove to be like living in another universe. The ASA is a completely different monster and would need to be treated as such. It is a mount that is strictly designed as an observatory mount, it is not a mobile mount. The motor on the mount is designed to make only one rotation in a 24hr period. No belts, no gears, no reduction at all.
But to say that they are probably the best mounts out there would not be a difficult statement to defend.
I think this particular ASA mount size has been discontinued, so repair may be difficult and probably very costly.
Do your research. Go to the ASA website. Learn what you will be getting yourself into before you take the jump.
I personally would buy it in a heartbeat, and build an observatory around it, that is if it still works properly.
Pirate
Jan Hlavačka avatar
Pirate Mike · Jan 28, 2026 at 10:41 AM
Pirate
Thank you for this information, I am definitely going to do some erase arch, but from what I know even if it broke down ASA has great customer support and they would be willing to help. A thing I’m genuinely worried about is the software.. heard the mount is extremely nieche and supports only ASA software.. but I guess I can make it work if it has encoders that you can apparently pull about twenty minutes of exposure at 1000mm fl without guiding.
David Zimák avatar
Ahoj, dle jména myslím, že si budeme rozumět i česky. Takže pro info . Jak už psal uživatel Mike..srovnání tyto dvě montáže moc nemají a to ani v ceně 😃 Je třeba mít na paměti to co už bylo řečeno výše tj. je to spíš montáž na permanentní setup do malé observatoře (nebo alespoň na pevný sloupek). Jinak v žádném případě nevyužiješ přesnosti, kterou ta montáž nabízí. Je třeba pro tento účel vždy udělat tzv. model oblohy , aby jsi mohl využít/použít nepointované expozice. To samozřejmě zabere určitý čas a myslím, že nechceš každý večer vytahovat montáž např. na zahradu a dělat ten model znovu. EQ6 toto nepotřebuje, neumožňuje, protože samozřejmě potřebuje pointační dalekohled/software atp. Jedná se o třecí montáž, úplně jiná kategorie/systém než mám EQ6 a pro správnou funkci je také třeba ji celkem dokonale vyvážit . Na to má ASA ve svém softwaru 100% funkci. A ano bez softwaru od nich se asi nehneš tj. integrace s dalším PC softwarem bude vždy trochu výzva (není to určitě nemožné např. s NINA softwarem) . Cena je to dobrá, ale montáž to není pro každého z výše uvedených důvodů. Servis samozřejmě jen do do, protože se již dávno neprodává. Doporučil bych v ČR kontaktovat Martina Myslivce z Bělče nad Orlicí..tento typ montáže určitě viděl / zkoušel a řekl by Ti k tomu ještě více. Sám montáže na tomto principu myslím i staví (jen pro větší komerční observatoře) a je v tomto duchu vynikající odborník.
David
Jan Hlavačka avatar
David Zimák · Jan 28, 2026 at 11:25 AM
David
Děkuji ti za všechny tyto informace Davide, uplne nerozumím té mapě. Stává se mapa automaticky neplatná po novem polar alignmentu? Urcite bych byl montáži ochotny postavit observatoř, aspoň se střechou která se dá odsunout, plánuji to uz velmi dlouho. Spis nevim jestli je cenovka cca 70 000 CZK dobra za tuto montáž i kdyz se uz nevyrábí. Také ti děkuji za odkázáni na Pana Myslivce. Je nějaký specifický web kde bych ho mohl kontaktovat? Díky,
Jan.
David Zimák avatar
Ahoj,
pokud vím, tak samozřejmě model oblohy (je to systém, kdy Tě software naviguje na konkrétní hvězdy a ty mu potvrzuješ/asi i případně mírně upravuješ pozici …bývá to klidně i 60 hvězd) bys dělat pokaždé nemusel v případě, že bude montáž stát vždy na přesně stejném místě (permanentně a 100% správně ustavená na Polárku). Pokud ovšem třeba jako já ustavuješ svou EQ6 každý večer znovu tak s tímto systémem u ASA nepořídíš….respektive možná ano, ale opět bys musel pointovat 😉 tj. žádné nepointované expozice. A jak už jsem psal, ano za tuto montáž je ta cena myslím velmi dobrá.
Martina zkus kontaktovat , určitě poradí a že ho pozdravuji. Je dost zaměstnaný člověk tak měj trochu trpělivost:
https://hvbo.cz/index.php?id=o-webu-a-autorovi
David
David Zimák avatar
Jo a mimochodem , já jsem o té montáži také kdysi přemýšlel, ale ztroskotal jsem přesně na tom jakým způsobem fotím tj. stavím doma na zahradě pokaždé tu svou EQ6-r znovu pro případné focení. Dokud se někdy neodhodlám k té pevné observatoři (až třeba někdy obměkčím manželku, že to bude vypadat na naší mini zahrádce bombově 🤣) tak nemá toto pro mne smysl. Ale i s malým a levným ,,kašpárkem,, jako je ta EQ6 se dá dělat pěkné divadlo..můžeš mrknout na můj profil zde. Mnoho z těch snímků jsem nafotil/zpracoval sám a část je tam spolupráce s kolegou z Krumlova co má právě permanentní dálkově řízenou observatoř + pořádnou montáž a takový ten dražší japonský Newton 🙃 Všechny ty snímky jsem zpracoval pouze já, protože můj kamarád v tom není tak kovaný a raději jen fotí ..tak máme dělbu práce.
P.S. tvoje výsledky co vidím zde na AB (pokud jsi zpracovával sám) se mi líbí.
David
Jan Hlavačka avatar
David Zimák · Jan 28, 2026 at 11:52 AM
Ahoj,
David
Rozumím, takže pokud správně chápu, stacilo by vybetonovat stožár na montáž a ustavit montáž na polárku co nejblíž co to půjde, (pár uhlových sekund jinak by nemělo vadit) a následně udělat mapu a dokud budu dostatečně blízko prvni pozici kdy jsem mapu delal, a i po následném sundání montáže ze stožáru by neměl být problém. Diky,
Jan.
David Zimák avatar
Ahoj….ano, myslím že takto by to mohlo fungovat (na permanentním pilíři). Ale pozor, tu montáž bys musel na tom pilíří nechávat takto ustavenou a např. přikrytou….sundávat určitě ne. To bys byl zase tam kde předtím tj. vytvářet nový model oblohy. Více info opravdu např. u toho Martina M.
David
Jan Hlavačka avatar
David Zimák · Jan 28, 2026 at 12:14 PM
David
To se bojím ze v tomhle případě to bez té observatoře nejde, nevim, jak bych mohl montáž nechat na venkovním pilíři přes venkovní počasí, asi bych se to bál nechávat i píď tou plachtou. Zeptám se toho Davida, děkuji,
Jan
Pirate Mike avatar
Jan Hlavačka · Jan 28, 2026, 10:57 AM
Pirate
I had researched these mounts many years ago, and almost purchased one, but the price at the time (I was just in my first year of doing astro-photograph) made me think twice.
I think you are correct that the software is not compatible with the “normal” software available today, but I do believe that they have all the bases covered. Anyways, learning new things is half the fun.
Pirate ☠️
