Stacking issues with rotated field causing luminance lines in Seagull Nebula
8 replies104 views
Benjamin DeHaven avatar
Hello! I’m working on the Seagull Nebula, NGC 2335. I took my first batch of images with two dual narrowband filters before deciding I hated the composition and rotated the field for the third and ongoing nights. When I stacked all the data I was left with a very distinct set of lines. I figured it would be just noisier due to less signal but after removing the noise there was very clearly a background luminance difference. Shouldn’t something like local normalization (don’t know, judging by the name) fix this? Is this to be expected or did I have something in Pixinsight WBPP set up wrong… Thoughts? Thanks!
Benjamin
📷 integration2_ADBE_forum_question_about_lines.jpgintegration2_ADBE_forum_question_about_lines.jpgThis is the DBE, blurX, noiseX, starX, and statistical stretched image…
Quinn Groessl avatar
It can only do so much. You have the parts with the original framing getting 1/3 or less of the signal of the parts that were present all 3 nights.
It depends on the stacking options. I don't use WBPP. You also need to flatten the images before stacking, if they were separate stacks.
Quinn Groessl · Jan 27, 2026, 01:41 PM
So should I take more of the original framing to equalize the SNR? Think of it as a mosaic at this point?
andrea tasselli · Jan 27, 2026, 01:41 PM
Hmmm, I dumped all the .fit files into WBPP and told it to process them all. Do you think I would get a better result stacking each night with a different rotation and then DBE. Then integrate the individual nights together? I have no clue how to stack without WBPP… But this dog can learn new tricks…!
Benjamin DeHaven:
Yes, I would (and do) so. Furthermore, I'd replace the black pixels (value) with the average background level value, assuming this isn't zero...
But you always need to flatten the images before stacking.
Mikołaj Wadowski avatar
Local normalization should minimize these artifacts or get rid of them completely.
It’s possible that you’ll be left with slightly sharper gradients around where the edges were but it’s nothing a good background extraction won’t handle.
Well written Concise
I didn’t know there was a way to fix this problem. I’ll be curious if any of the above works for you.
Well written
Obviously it does.
