Alexey Korobeynikov avatar
A question for Touptek 462m guide camera owners: I'm interested in the camera settings in PHD2. I don't understand how to select the correct gain. The default value is 0, but at this value, stars are often lost. And at values ​​above 2-3, the stars start to become oversaturated. Should I use the low conversion gain mode, or is this a driver issue? I used the Touptek native driver, and PHD2 doesn't allow me to select HCG or LCG modes. But I think this is possible with the ASCOM driver. Can you share your experience?
ZigZagZebraz avatar
I do not own this camera, but have used two (Player One Uranus C and SVBony SV905C) for guiding.
Followed the guide for PHD2 set up from this page. Using the corresponding native drivers, 50 to 60% gain in PHD2 works well for me.
https://pegasusastro.com/nyx-101-guiding-recommendations/
Brian Puhl avatar
I would be willing to bet you’re in 8 bit mode, instead of 16 bit.
Prior to connecting the camera in PHD2, there will be a gear icon next to the connect button. Click that, enable 16 bit. This is with the native driver btw.
in 8 bit, you have 255 ADU before a star becomes saturated. In 16 bit, it goes up to 65k. You’ll also need to tweak the ADU threshold for saturated stars in PHD to something like 45-50k. It’s a big difference. Beyond that, you might need to tweak your star detection thresholds.
Brian Puhl:
Yes, you're absolutely right, I used 8-bit mode.
Brian Puhl:
Do you mean this parameter?
Brian Puhl:
These settings?
Thanks for the answer!
TiffsAndAstro avatar
Before you connect the camera in phd2 you can set it to 16 bit
My snr2 went from 25 to 150 on a zwo 120mm mini
TiffsAndAstro:
Yes, I'll try next time.
