andrea tasselli · Jan 25, 2026, 08:19 AM
The atmospheric seeing and the locale seeing, these you can't measure unless you have very specialized instrumentation.
And i even if you could, as you suggest, what matters is what your rig is capable of. What I call my seeing is the fwhm of a 4s sub after running auto-focus, but when seeing is bad, that number can change from sub to sub by an arcsecond or more….. In addition to wide variances night to night, my seeing can change significantly through the night and even according to where I’m pointing. Winter is the worst, in part because of denser air, but probably more so because of increased thermal turbulence.
Where things get even mushier, is converting NINA’s HFR measurement (while imaging) to FWHM. There isn’t a direct conversion, but I’ve found, on average, HFD in arcsec is about 1.2x FWHM in arcsec.
For forecasting, MeteoBlue is the common goto. If you ignore the numbers, I find the forecasted trend is fairly acurate — unfortunately, in my case, for tonight:
Here’s a link to how they calculate seeing, and also a way to lend your own data to the effort, though via visual observation, not images. http://www.meteosurf.com/spastro/seeing/index.html
Scott
