I am asking for help in purchasing an eyepiece for my telescope
7 replies93 views
BigLizardAstro avatar
Hello, my name is Adam. I'd like to ask for help in purchasing an eyepiece for my SkyWatcher BK 909 AZ3 90/900 telescope. I'd like to see, for example, Jupiter's belts and Saturn's rings. I was considering buying a 5mm eyepiece, but I'm not sure if it's a good idea.
As for now, I have two eyepieces: a 25mm and a 10mm, which came with my telescope.
5mm
Why not try a 2X Barlow? That will give you two the same thing as a 12.5mm and 5mm ocular. You’ll also get greater eye relief so it will be easier to use.
Tony Gondola · Jan 24, 2026, 02:20 AM
That's a very good idea. I've read about the Barlow lens, and it makes sense. Instead of spending $75 on a 5mm eyepiece, I can just spend $20 on a Barlow lens. Besides, it's better because it zooms in on the image depending on the eyepiece and the Barlow lens it's mounted on.
Thank you for your help.
Paul Larkin avatar
Hi, Adam.
When I started this hobby a few years ago I had the same questions.
Albeit not a ‘prime’ eyepiece, I decided to try a zoom to see what works and consider primes later on. i.e. get something I knew would cover all bases and be of fairly high quality.
I got the Baader Hyperion 8-24mm Mk IV. It fits 2” and 1.25” holes and has been such a delight to use.
I’ve only bought one other prime since because the Baader does most of what I want visually on my Celestron EdgeHD 8 (2030mm) and Esprit 120ED (840mm, close to your 900mm). I mostly to photography these days, but whenever I want to do visual (or show others things), I pull out the Baader zoom. On my first scope (William Optics Zenithstar 81, 559mm) I had not troubly picking out Saturn’s rings.
Perhaps something to consider.
Cheers.
Paul
BigLizardAstro · Jan 24, 2026, 07:21 AM
I wouldn’t get one that cheap! Get one that’s roughly the same cost as that 5mm you were thinking about.
Steven Fanutti avatar
Bear in mind that higher magnification does not necessarily mean a better and clearer image. For example, if you are magnifying an image by say 200 times, you are also magnifying the atmospheric effects by that much as well as the effects of Earth’s rotation. You will find yourself constantly adjusting the aim of your telescope on an untracked AZ mount to see an unstable view at too high of a power using too short of a focal length eyepiece. I have a SkyWatcher 102mm on an AZ mount (500 mm focal length) and I get great views of Saturn using a 2x Barlow and a TeleVue 11mm Plossl. A fringe killer or contrast booster also helps on achromatic refractor telescopes like mine. I have to adjust the aim of the telescope quite a lot on my AZ mount, but it's manageable.
Steven Fanutti · Jan 24, 2026, 05:03 PM
thank you very much for your tips
Tips for improving photo of Jupiter and his moons
Hello, my name is Adam, I would like some advice on how to improve this photo of Jupiter and its moons. I would like to hear in the comments, for example, 15+ brightness, 5- contrast, etc. https://app.astrobin.com/i/h5hcxq I took the photo with a Sky...
Same telescope model; eyepiece selection affects image quality and magnification.
Jan 7, 2026
How to remove blue glow around the moon in photos
Hello, my name is Adam. I'd like to know what to do to remove this blue glow around the moon. Please help. https://app.astrobin.com/i/vl7kul I took the photo with the Sky-Watcher BK 909 AZ3 90/900 telescope using the Xiaomi Redmi Note 9 Pro phone. I ...
Discusses same telescope model; may address optical issues affecting image quality.
Jan 8, 2026
what is the best smart telescope under $700
Hello, my name is Adam, I would like to know what is the best Smart telescope under $700 for viewing nebulas and galaxies.This is not my first telescope, my first telescope is the Sky-Watcher 90/900
Author owns Sky-Watcher 90/900; eyepiece advice relevant to telescope upgrade path.
Jan 2, 2026
Is it worth buying the Seestar S50 for deep sky observation?
Hello, my name is Adam, and I'd like to know if the Seestar S50 is worth buying for deep sky or star cluster observing. I'd appreciate any opinion from people who own it or don't. I currently own a SkyWatcher 90/900 telescope
Eyepiece purchasing help relevant to author's existing SkyWatcher 90/900 telescope.
Feb 11, 2026
The best setup for 3000 USD
Hello! After buying and testing the Seestar, I would like to start my adventure with astrophotography seriously. Can I ask you for advice on what can be put together for about $3,000 so that the money spent makes sense? What I want to include: Camera...
Eyepiece selection discussed, though source focuses on camera/mount setup.
Oct 2, 2024
