ISS capture failed with Celestron NexStar 4SE and ZWO ASI662MC , exposure and gain advice
8 replies100 views
Astropartament avatar
Hello! Last evening, I tried to capture the ISS with my Celestron NexStar 4SE telescope and ZWO ASI662MC camera. I carefully positioned my telescope along the predicted path of the station, but I couldn’t see anything in the recorded video. I think that the exposure and gain settings might have been wrong. I set the exposure to about 0.18 ms and the gain to 420 in SharpCap. What do you think? Could you recommend the correct settings for this setup to capture the shape of the station without overexposing it or making it too dark? I am under Bortle 5/6 skies. Thank you!
You know you need to track it, right?
andrea tasselli · Jan 21, 2026 at 02:39 PM
Exactly! I tried manual tracking using the NexStar hand controller, but nothing was visible, and the red dot finder was properly aligned and clearly pointed at the moving station. I also pointed the telescope at the position where the ISS was predicted to pass, and according to Stellarium, it passed through my field of view.
Astropartament · Jan 21, 2026 at 03:04 PM
Maybe my methods are not correct, and they are simply not effective or don’t work at all. Thanks for every reply!
There’s basically two ways to do this, easy and hard. The hard way is to use a Dobsonian. Start your camera running and manually track the station while looking through a finder scope. The easy way would be to use a program like SkyTrack that will drive your mount to follow the satellite of choice. I know which one I would pick!
Well Written Concise
Tony Gondola · Jan 21, 2026 at 03:15 PM
Thank you! Do you think it would be possible to try the first method with my 4-inch Maksutov-Cassegrain? Of course, the second method is much easier, but I’d like to try capturing something with the first one first, just to see what I can get with this type of telescope. 🙂
You could try but it will be difficult. because of the way dobs work there’s always a certain amount of friction and if you let go, it just stays there. You can freely move on any direction you want except at the zenith. That would be hard to replicate with your mount. The best you could do would be to put enough drag on the locks to emulate that behavior. That said, give it a try. Even a single fleeting glimpse would be progress and you’d appreciate more the difficulty involved.
Tony Gondola · Jan 21, 2026 at 04:33 PM
You’re right, it’s going to be difficult, but I’ll give it a try! It’ll be interesting to see what can I get. 😉
SonnyE avatar
When one of (maybe the last) Planetary alignments took place, I setup my DSLR and big telephoto lens to shoot where the planets were supposed to align. Turned out the Planetary imaging was a complete bust, but something bright flew through the FOV.
At first, I was disgusted. Thought is was a plane or something. Then I looked it up in Stellarium. It was the ISS flying over.
So instead of dropping them in the delete file, I studied them and put them together as a You Tube slide show. I had tried and tried to catch the ISS in a fly over, but then this night I caught it quite accidentally. January 22 2016
Satellites never have any marker lights going winky-blinky. Stellarium proved it out.
ASI662MC Settings
Dear Astrobinners, I will be using asi662mc for planetary imaging with a 6" f15 refractor. The area is very light polluted. I have 3 questions; 1. What exposure and gain should I use? 2. Should I use IR cut filter or IR pass (850nm+) 3. Should I...
Same camera model; discusses exposure and gain settings for ASI662MC imaging.
Mar 8, 2025
HyperStar - Advice on Camera Settings
I just bought and received a Starizona HyperStar for my Celestron Evolution 6. I'm using a ZWO ASI585MC Pro, shooting from a Bortle 6 area. With the current weather conditions, I could only test it once, during a two-hour session interrupted by c...
Addresses exposure and gain advice for ZWO ASI camera, applicable to your setup optimization.
Oct 8, 2024
"GAIN" setting on ASI585 MC PRO
Hello, I just bought a ZWO ASI 585 MC PRO camera which replaces my CANON EOS250D camera. I took my first photos yesterday evening with this camera, the sky was pretty good, the Moon not yet up… I set the GAIN to 252, as recommended by the ZWO i...
Directly addresses ZWO ASI camera gain and exposure settings advice.
Aug 23, 2024
ZWO 2600 MC 2025 Version Troubleshooting - Missing frames and exposure failures
Hello to everybody, I need help to solve a strange problem with my new Zwo ASI 2600 MC Pro. I bought the 2025 camera and when I first tested it I noticed this problem: sometimes it did not save the sub in the memory but the asi air kept saying that i...
ZWO camera troubleshooting; exposure and gain settings issues directly relevant to your setup.
Dec 1, 2025
