Hi Robin,
thank you for your information.
Meanwhile I know, what was wron with my setup.
I was at Kiripotib last summer and I had the skywatcher mount with me. Power cabling was as followa: 15A 12V Power supply and two power cords; one for the telescope rig (camera and cooling, filter wheel, focuser as well as the mini PC on the rig. The other power cord wa for the mount. This was ok.
Back at home I thought, why two power cords. Let us use one with thicker lines. And i Have a 50A power supply, what should go worng? In order to minimize the USB cables I installed also an USB Hub. The mini PC was removed, as its power was too low. The power distribution was manged by a pegasus mini part. This was a mistake. First the USB Hub consumes alone about 2A, 12V and on the other hand - the power supply has a big trouble: when using more than 2A power the voltage drops down. At least to less than 10.5V and this has broken the circuits in the Skywatcher 150i.
Now it is still under repair and I hope that they will send it back to me as soon as possible (I am waiting already nearly about for four months.
Best regards
Gerhard
