D2 filter taking twice as long for flats - less efficient than L-eXtreme?
5 replies100 views
Benjamin DeHaven avatar
I’m currently taking (as in as I write) flats with a cheap LED tracking pad. I just for the first time used my new EWF with an L-eXtreme and an Askar D2 Oiii Sii filter installed. When taking automated flats with my Air camera and wheel for the first time, it occurred to me that at the same, untouched luminosity level, the D2 took nearly twice as long for the auto exposure to hit proper illumination of the flat as the L-eXtreme. Does this mean it’s letting in half the light, as in much less efficient? Or is something else at play here? Would I find better transmission with the L-synergy filter in place of my D2? Thanks!
Benjamin
The D2 has narrower band passes so you’d expect to see a difference when shooting flats, I am surprised it’s that much though as it’s just 6nm verses 7nm band passes. I wouldn’t see that as less efficient though. It’s just more efficient at blocking unwanted wavelengths.
I guess I forgot to say, the L-eXtreme was 8.59s and the D2 was 14.34s.
The effective passband (also) depends on the focal ratio. If you were using a fast lens/scope then you efficiency might as well drop more than the ratio of nominal passbands. D1/D2 shouldn't be used on anything faster than f/4 and at f/4 they loose more in the OIII than in the longer wavelengths. This is also compounded with the relative size of the secondary, if using a reflector (bar schiefspieglers and such). Given the numbers my best guess you are losing around 30% of the incoming light due to bandpass shift.
Helpful Insightful Respectful
andrea tasselli · Jan 18, 2026, 09:05 AM
I’m using a Petzval type refractor, an Apertura 75Q. The focal ratio is 5.4…
Then probably your flat panel doesn't emit in the deep red as much as in the Ha band, besides issues of lower QE at the SII wavelength. At f/5.4 your bandpass shift should be minor (but not zero).
Optolong L-Synergy first light
I had the opportunity to try out the new Optolong L-Synergy duo filter. Here I share the pictures and my experiences: https://fenyeslorand.hu/l-synergy/
Compares filter efficiency; L-eXtreme is directly relevant to L-Synergy duo review.
Sep 24, 2025
Focusing with the Sii Filter
i'm imaging M78 in SHO during the moonlight. I am noticing that occasionally the Sesto Senso 2 focuser fails to focus when using this filter. I've also noticed that when my automated flats are taken, the Astronomik Sii filter requires a 9 sec...
Filter efficiency differences explain longer exposure times for certain narrowband filters.
Dec 18, 2024
NGC 2264 - a dark rendition
I have about 10 hours of dual narrowband exposure on the Cone Nebula using L Ultimate and Askar D2 filters with an ASI6200MC - still need some filter less exposures for the stars which I’ll collect this week. Instead of the tr📷 IMG_8322.jpegaditional...
Addresses D2 filter efficiency and flat-taking with Askar equipment poster is using.
Mar 15, 2026
Looking for Advice on SII & OIII Filters - Halo Issues with Askar D2
Hi everyone! I need some advice on narrowband filters. I currently own the Askar D1 and D2 filters. The D1 is fantastic great colors and truly halo-free. However, while the D2 produces nice images, I’ve been struggling with halos, which is quite frus...
Discusses Askar D2 filter efficiency; directly addresses author's D2 filter concerns.
Jan 29, 2025
Flats
GDay all I have a creek running behind my place and hence lots of trees. I image between them and on my deck. Some nights I can only get ten subs if Im lucky and anything quite high no dramas getting a decent amount. Many times Im lucky for ten. In t...
Discusses flat fielding techniques relevant to author's flat-taking workflow.
Nov 15, 2025
