Celestron C8 EdgeHD focus jam with ZWO EAF - seeking expert advice
8 replies234 views
akshay87kumar avatar
Hi everyone,
I’m looking for expert advice on a Celestron C8 EdgeHD focus jam before proceeding any further. I’d really appreciate input from those experienced with SCT internals.
Setup
  • OTA: Celestron C8 EdgeHD
  • Focuser: Stock SCT focuser with ZWO EAF attached
What happened:
I had swapped the ASI294 with a ASI676MC for lunar closeups, and I was attempting a focus. After several attempts of focusing, I suddenly observed that the focuser knob was always rotating counter-clockwise, whether I would press the left or right button in NINA (or even the hand-controller). I tried turning the ZWO EAF on and off a couple times, but the situation did not change.
Based on prior experience using ASIAIR, I tried to reach the zero position (where the focus knob stops rotating - ensuring I observe whenever it stopped rotating to avoid excess rotation) and then start moving back. My focus position with the previous camera was about 190,000, and it had reached about 70,000 when I realized that it was always rotating counter clock-wise whether or not I tried to press the left or right button. I would have made another 2000 positions moved towards zero (i.e. about 68000 position).
At this position, the EAF is jammed - it does not rotate either left or right. Keeps beeing immediately when I try to rotate. I can visibly see the spring try to rotate but stops immediately. Evidently, something is jammed at this point.
I am almost certain that when i had set up the C8 Edge for first time and attempted focus, I had reset the zero position correctly. So, I dont think I would have really crossed the expected end-of-travel, but I could be wrong too. Unfortunately, the focuser is ultimately stalled completely and is now immobile in either direction.
Current state
  • EAF focuser does not move in either direction
  • EAF immediately stalls and beeps in both directions (either using NINA or hand controller) - I can see its coiled spring attempt to rotate left or right, visible that there is torque. I havent disassembled it yet to confirm.
  • Mirror locks are disengaged, and were always disengaged when attempting to focus.
  • All attempts have been stopped at this point
Reason for posting
I do not have access to a local SCT service technician. Before attempting anything, I wanted to understand what could have gone wrong? Once it is day time tomorrow, I will disassemble the ZWO EAF to see if the EAF is working correctly. Assuming it is, the next thing to fix would be the focus mechanism of the C8 Edge - which makes me nervous!
I’ve stopped all further mechanical attempts and want to proceed cautiously and correctly.
Thanks in advance — I value the depth of experience in this community.
You stated that the manual focuser won’t move in any direction, is that with the EAF detached because if that’s the case, the problem is on the SCT side, not the EAF side. Does the EAF function when not coupled to the SCT focuser?
Insightful
Tony Gondola · Jan 11, 2026, 07:17 PM
At this time, I have not disassembled the EAF from the focus mechanism. I will attempt it tomorrow to see if the problem is in EAF or the SCT side.
I do see that the EAF does attempt to twist both side visibly, but stops within half a second - as if it has hit some hard limit.
PS: I just edited my post to say "The EAF does not move in any direction” to avoid any confusion.
Disassembled the rig today - much relieved to see that the C8 focusser is perfectly operational. It is the ZWO EAF that has conked off. Much relieved to see the optics system fine, but it is indeed surprising for EAF to become dysfunctional. This was a pretty new unit - had just arrived a month ago along with other equipment and was used probably the second night only.
SonnyE avatar
My experience with my EAF was such as to make me swear off ZWO ASI equipment.
Finding my EAF had NO repeat accuracy I sought ZWO services help. Sent it in with detailed descriptions. They returned it with a “No Problem Found”.
I immediately tested it on my desk, and the same problem was still there, it could function out but would arbitrarily stop when sent inward. The stop required a reinitiation manually to get it to move inward again. It could not focus.
They ask if I could make a short video of what it was doing. So I did. But…. they have no means of accepting the file. 🤨 So I posted it on my You Tube channel and sent a link. Once I had taught them how to troubleshoot the problem and sent them the defective EAF for the second time they finally relented and replaced it. Why does a customer have to go to such great lengths to prove a piece of their product is defective?
They did not reimburse me for the EAF hand controller ($40) I was forced to buy to show the defect. It was a long denial on their part that my EAF was defective.
The replacement now lives on my old 80mm Triplet the Grandkids have set up at the Son’s home and they love it. The electronic focuser lets them adjust the focus without touching the telescope.
I replaced my EAF focuser with a Pegasus Astro Focus Cube2 which I chose for its separate 12-volt motor power input. Not loading up my USB network. It has worked flawlessly and is amazingly precise in focusing my 130mm Rack & Pinion telescope.
So, I have lost all faith it ZWO ASI products. Love my 3 ASI cameras but will be looking elsewhere as they fail. Getting away from the China business model. They can KMA!
Sorry to hear you are going through the throes of ZWO. My relief has been Pegasus Astro. Focuser, Rotator, and Flatmaster 150.
Helpful Concise Engaging
SonnyE · Jan 15, 2026, 04:11 PM
Thanks for sharing your experience. I have been a long time user of ZWO equipment - partly due to very limited availability of astrophotography vendors at my location.
This experience with a brand new EAF used only for 1 night is very irksome. I did have a growing list of equipment - ASIAIR, 2 EAFs, 2 EFWs so far. I have moved to NINA, and slowly growing comfortable with it, so I may evaluate the options definitely.
SonnyE avatar
akshay87kumar · Jan 15, 2026, 05:27 PM
Ahh, NINA!
NINA, the best avenue I can suggest is Cuiv the Lazy Geeks visual tutorials for NINA. While he is a bit of a goofy geek I found a great deal of substance in his video steps. I decided to knuckle down and get NINA working for me.
I find I really like using videos because I can pause, back-up, refer, and check if something comes up. A great learning tool.
A couple of years ago now I started getting serious after ~9.5 years with my first “real” telescope, an Orion ED80T CF, a triplet refractor with a carbon fiber tube. It worked very well for me during that time, wore out several cameras, taught me a great deal. Even destroyed my first mount, which was a POS. It lives at the last Grandkids’ Dad’s house where they and friends use it for fun visual use.
I eventually went to upgrading my endeavors with my Astrophotography. In doing so I quickly realized NINA does have a list of equipment it works best with. I let that help guide me as I explored my options. I found I wanted things that were open sourced as far as their software is concerned, or at the very least, ASCOM compliant.
ZWO ASI writes or steals software to make their equipment work. Once one begins down their equipment path it practically demands you continue to invest in their brand. Not just me saying that, but many others in our astronomy community. I listened and wondered. I have 3 of their cameras which I have enjoyed using. As long as you download the specific software (not unique to ZWO, others also have software packages specific to their products.)
But for me, to engage NINA fully and become enabled to do full remote operation (which in my case amounts to ~75 feet, as the crow flies.) And get away from one corporate entity, I paid attention to NINA’s drop-down lists as far as brands were concerned.
My bad experience with ZWO service in New Jersey cost them my consideration to get an ASI Air and watching them inadeptly float their rotator offering affirmed my decision to steer clear of them. I was enjoying my Pegasus rotator for about a year while they kept ping-ponging ASI fans over their version of a rotator.
Hope you can find useful help in Cuiv’s stuff.
Windy Tree Astro avatar
Do you live in a cold climate? EAF doesn't do well with cold. I've had to wrap mine with a dew heater.
RobeGuy · Jan 16, 2026, 10:10 PM
I would not say it is a cold place. It is winter, and temperatures get down as much as 3-4 deg C. This is for a max of 1-2 months. Most of which is foggy weather and unusable anyways. I had opened it last week when it was about 6-8 deg C outside.
Summers get hot upto 45 -46deg C.
Mount axes swapped?
Hi, I am trying to get started with this mount and I am getting more and more the impression that my axes are swapped, meaning that DEC changes actually cause RA changes and vice versa. This happens during three point alignment, where the RA axis sho...
Mount axes issue unrelated; focuses on mount problems not focuser mechanics.
Aug 28, 2025
What do you do when PHD2 sees ghosts?
I have been chasing a problem in my guiding for several hours yesterday night and tonight. I use an OAG with a SCT (C8); PHD2 (managed by NINA) is the brain. The experienced problem was that, for a specific target, guiding would work well “in most ca...
Uses C8 SCT with similar setup; guiding issues may relate to focus problems.
28 days ago
External focuser on an SCT; What about temperature change induced focal shift and back-focus?
It seems like every serious astro-photographer is putting external focusers on the back of the EdgeHD telescopes and locking the mirrors. I picked up a nice little EdgeHD 8" and a Primaluce Lab Esatto 2" LP focuser and gave it a try myself....
Directly addresses SCT external focuser and focus-related thermal issues relevant.
Mar 25, 2026
