Polar Alignment
6 replies168 views
prxcz00 avatar
hey guys, ive did a bit of research beforehand but is polar alignment needed for short lunar / planetary imaging sessions? I use a SWSA GTI
bigCatAstro avatar
prxcz00 · Jan 7, 2026 at 11:45 AM
I would polar align, but a rough polar alignment/daytime alignment should be okay. You can get away with not doing it, but you’ll be recentering the Moon a lot manually since it will be drifting.
prxcz00 avatar
bigCatAstro · Jan 7, 2026 at 01:00 PM
thank you so much!
alpheratz06 avatar
If you want to perform a night quick and dirty polar alignement, you can use a laser beam aligné with RA axis , eg by laying the laser pointer along the mount dovetail. Adjust az and alt to target polaris.
Et voilà !
prxcz00 avatar
alpheratz06 · Feb 5, 2026 at 07:03 PM
Et voilà ! M
Thank you!!!! I forgot to mention, im in the southern hemisphere haha
John Tucker avatar
prxcz00 · Feb 7, 2026, 01:26 PM
Et voilà ! M
You’ll need a more powerful laser!
But seriously, it depends a lot on how long your focal length is. I think at 2000mm, for example, you’re going to have a hard time keeping the subject in the frame without a pretty careful polar alignment.
prxcz00 avatar
John Tucker · Feb 7, 2026 at 01:46 PM
Et voilà ! M
Yeap, I’ll be using a skymax 102 so im worried if i could even get away without a precise pa. I’ll try it out soon and see how it’ll go though
Large aperture planetary setup heavily underperforming for an unknown reason
So this Jupiter image i took recently, its somewhat decent i would say, but as im exploring this site i notice people getting far better results with significantly smaller telescopes and less data, makes me wonder what am i missing / doing wrong. For...
Planetary imaging setup optimization relevant to your equipment performance goals.
Jan 20, 2026
