Etaloning effect with 2600MC and dual band filters
11 replies239 views
Dylan avatar
Hello all,
I’ve been trying to work out the cause of what seems to be an issue with an etaloning effect in my images recently. I’ve only been imaging for a little over a month now but this is the first time I’ve seen this. Doing some research, I’ve read that this is more common with with the 294 and similar cameras but haven’t seen others having this issue with the 2600. I’m currently working on a mosaic of Orion and don’t have this issue in earlier frames taken. The only difference I can think of is the moon has gotten closer since I started the project and is somehow contributing to this effect.
Any thoughts or advice would be greatly appreciated.
Here are two examples from two different days with two separate filters.
https://app.astrobin.com/i/hjv2m5
https://app.astrobin.com/i/ujoddp
imaging train used:
WO Redcat 91
ZWO OAG
Antlia 3nm duoband filters, HaO3 and S2O3 in a ZWO filter wheel
2600mc pro
bigCatAstro avatar
How close to the Moon were you when taking those tests? It does appear that you’re getting Moon glow interference and/or light leakage.
Well Written Concise
Dylan avatar
The Moon would have be right above or right below Pleiades on the two nights for my linked photos
bigCatAstro avatar
Dylan · Jan 5, 2026 at 12:30 AM
I see, alright. So, would you say that the area in the sky you were test shooting in was in that same region—either above or below the Pleiades?
Dylan avatar
Oh sorry, I wasn’t clear in the original post. These images are of M78 and the other one is just adjacent to it
bigCatAstro avatar
Dylan · Jan 5, 2026 at 02:16 AM
Got it, were you testing during the full Moon on 01/03 and, if so, at what time? I took a look at Stellarium during the 01/03 time frame and the Moon, though not too close, it’s still close enough to cause a problem throughout the night. That’s even with narrowband filters, at least in my experience. I try to shoot targets that are on the complete opposite side of the sky of the Moon if I’m going to try to image.
Dylan avatar
Close too it, These two stacks were taken on 12/30 and 1/1 both between 8pm and 3am. I expected to get some extra glow from the moon, but the Etaloning took me by surprise and I just wasn’t sure what to blame it on.
bigCatAstro avatar
Dylan · Jan 5, 2026 at 02:27 AM
Based on my review in Stellarium, my educated guess would be that the Moon is the likely culprit. Your other photos were taken with the same set-up, right?
Dylan avatar
Yeah, all my equipment is identical in my all my photos other than the galaxies being shot without a filter. But, that was the answer I was hoping to hear.
When I get a chance I kinda want to pick two targets in a night, one close to the moon and one far, and shoot them for an hour or two each and see if its more prominent with the object closer to the moon.
I really appreciate your input!
bigCatAstro avatar
Dylan · Jan 5, 2026 at 03:21 AM
Yeah, that’s a good idea to test and experiment with.
I go by the old advice and also avoid imaging when the Moon is at 50% or greater in illumination. It creates all sorts of weird gradients, it can expose all the imperfections with your imaging train, and really washout narrowband DSOs.
Helpful Respectful Concise Engaging Supportive
Well, well, well. I reckon the old advice is to shoot no closer than 3 hours from the Moon, regardless of filters.
bigCatAstro avatar
andrea tasselli · Jan 5, 2026 at 09:56 AM
😆 Yes, you’re right!
Weird Banding - ASI 2600MC Pro
I've recently started using a 2600MC Pro, and find that I get coloured banding around the edges of my images.. in some it is much more noticeable than in others. Any ideas what would be causing this artifact? You can see it pretty clearly along t...
Relevant camera model; discusses banding/etaloning effects with 2600MC.
Nov 10, 2024
Best filters with the 2600MC Pro
Since my 2600MC Pro is new to me, I have been researching filters - watching a lot of Cuiv and reading all the technical data - but I'm curious which filters the average users of this camera prefers. I have the Optolong L-Ultimate and L-Quad Extr...
Directly addresses etaloning issues specific to 2600MC and dual band filters.
Jul 24, 2024
Mono camera advice: 2600mm vs 6200mm for bortle 8+ astrophotography
I currently have a 2600mc that Ive been using for a little over 3 years and need some camera advice for a possible mono setup. I live in bortle 8+ and only get to dark sky once a month or so. I’m more into clusters and galaxies than nebula, but I end...
Etaloning effect with 2600MC and dual band filters — Author uses 2600mc with dual-band filters; addresses potential issues.
Dec 7, 2025
Dark bands at top and bottom of Minicam8M
EDIT: QHY support responded with the following statement: “We can basically confirm that this phenomenon stems from the light-gathering limitations of the Minicam8M sensor structure at extremely fast focal ratios (F4), rather than from mechanical obs...
Etaloning at fast focal ratios (F4) directly relates to author's sensor light-gathering issue.
Nov 8, 2025
M31 test critique
M31 Critique please This is a test image with only 5 hrs of data. I will be adding more this week as well as Ha. This was imaged with my wide field setup SQA55 2600MC Pro. I tried to be more careful with the stars considering that the image is unders...
Author uses 2600MC camera; etaloning could affect image quality.
Oct 24, 2025
