Strange gradient with Askar D2 filter causing red center and green edges
7 replies96 views
Giuseppe Renna avatar
Hello everyone,
what could be causing this strange gradient (red circular area in the center and green image edges)?
The shot was taken with a Samyang 135mm @ f/4 + Toupteck IMX571 + Askar D2 filter.
This is the master light obtained after 14 hours of integration, calibrated with darks and flats.
The same target captured with a D1 filter does not show the same gradient.
I have the same problem with other target
Thanks in advance for your replies.
wsg avatar
Not strange, remove the gradient and carry on.
bigCatAstro avatar
Giuseppe Renna · Jan 3, 2026 at 10:29 PM
Hello everyone,
Are you sure that your calibration frames were taken with the correct parameters, e.g. temperature and duration?
Brian Puhl avatar
Reshoot your calibration frames. If this does not fix the issue, then you need to look for light leaks.
Well Written Concise
bigCatAstro avatar
Brian Puhl · Jan 4, 2026 at 12:12 AM
I agree and I also think there may be a light leak as well.
wsg avatar
Normal Gradient removalScreenshot 2026-01-03 at 5.06.59 PM.jpgNothing else
The gradient is oddly large so calibration frames might be suspect
bigCatAstro avatar
wsg · Jan 4, 2026 at 01:10 AM
Nice work getting most of it out, however; it looks like the right upper and right lower corners may have some sort of light intrusion. To my eye, they seem brighter than the left side corners.
Well Written Insightful Respectful Concise Supportive
Arnie avatar
How did you obtain your flats? I had the same problem with my Samyang 135 and ASI6200. When I used a flat device that sat on top of the lens the calibrated lights came out looking just like yours. If I took sky flats, everything calibrated properly. I suspect there was some type of reflection inside the flat device that caused the problem.
Arnie
Well Written Helpful Insightful Respectful Concise Engaging Supportive Perfect post
Adding Dual-Narrowband data to an OSC image
Hello everyone. After 2 months of cloudy nights I finally caught a night when I can take my telescope outside. For my next target I decided to image M 33. I bought a UV/IR cut filter and have been using that for the first night of collecting data. I ...
Discusses filter-related imaging issues with narrowband data processing techniques.
Sep 19, 2025
ZWO ASI 2600MC producing doughnut artifact in center of images
Hello everyone, I have had a ZWO ASI 2600MC for about a year now, and I have noticed that all the images I have taken with it since then have a strange artifact in them. Basically, it looks like a doughnut in the center of the image. This is particul...
Addresses unexplained artifacts in camera images requiring troubleshooting investigation.
Nov 27, 2025
Gradient in dark frames
Hi everyone! I recently bought the Player One Poseidon C Pro camera and after a very long period of cloudy nights it finally cleared and I got to try it. When taking the lights everything was normal. When the sun rose again the pictures got very satu...
Directly relevant—discusses gradient problems in calibration frames and camera issues.
Mar 5, 2026
