Astro Friends,
I have been imaging for about 5 years and have been successful using refractors and mono imaging. I have branched out this year and now have an SCT and mono setup. I am seeking help with my flats which seem to add themselves to my images in pixinsight rather than subtract using WBPP. This problem has me stumped and I am sure it is something simple. Below is more information that could help in solving my problem.
My setup:
C9.25 - Standard Celestron
Starizona SCT 0.63 Corrector
ZWO EFW and EAF
Chroma 1.25” LRGB
ZWO 533MM Camera
Below is a raw luminance image:
Here is my master flat for L:
Here are the statistics from my flat:
K
count (%) 100.00000
count (px) 9048064
mean 2.512512e-01
median 2.625194e-01
avgDev 4.611702e-02
MAD 4.279369e-02
minimum 4.761905e-02
maximum 3.344004e-01
Here is my calibrated L file:
I use an LED panel on its dimmest setting diffused with a t-shirt and white paper to take my flats. This process has always worked for me with my refractors. This particular flat was 3 seconds long with an ADU of around 27k. I used WBPP to process, but as you can see it seems to add the flat rather than subtract it.
In WBPP I loaded my master darks for my frames, the raw flats (35 each channel), and my lights. I did not use dark flats and did not check optimize darks or flats. I used the standard settings in WBPP.
My thoughts are:
Could it be my LED panel or the way the flat is taken?
User error in WBPP?
Any thoughts or have you encountered this issue before?
Thank you in advance,
Scott.
