How to combine LRGB with HaO3 data for NGC 7662 processing
9 replies205 views
Michael J. Mangieri avatar
I am in the process of processing my Blue Snowball (NGC 7662) data with PixInsight. I have L,R,G,B, Ha and O3 subs. Since the object is fairly bright, I was going to do some HDRMT treatment of the HaO3 data to bring out the details. I generally have quite a bit experience in post processing most combinations of filter data, but this one has me a little stumped.
My question is this (sorry if I’m not fully explaining myself, but here goes):
How do I end up with an LRGBHaO3 final image? I made a reasonable LRGB image and a starless HaO3 (with subsequent HDRMT applied) image. But how should I combine the two? I usually do LRGBHa and there is a script for that.
Well written Engaging
Armin Lukas avatar
Have you tried the CombineRGBAndNarrowband script? (Pixinsight: Script/Toolbox)
Well written Respectful
James avatar
I’ll be interested to see how others tackle this but my latest image is exactly this scenario. Planetary nebula data (NGC 1360 in my case) with broad band stuff, like a galaxy in the frame.
I processed the narrowband and broadband data separately. Then used photoshop to blend the HOO image with the LRGB image (I believe I used the screen method). I processed the HOO background data to be very dark (but not clipped) since I find the background in the LRGB image more pleasing. I suspect the image blend script in Pixinsight may be able to perform a similar process.
Stephen Jones avatar
Im no guru. Why not create a Hoo pallet with your Ha and Oiii using pixmath
0.6*Ha + 0.4*Oiii and change the amounts making sure they =10. Then combine using imageblend
You could use Bills scriplets as well. Or continuum extraction from Ha and add to Oiii.
I started with the HOO and LRGB with image blend but the core of the PN is blown out. I’m struggling with getting the detail to show (that is there) using some hdr processing but results haven’t been good yet. Still experimenting. Thanks for the suggestions.
Tobiasz avatar
Armin Lukas · Jan 1, 2026, 11:17 PM
Exactly this. It works very well.
Thanks much for the tip. CombineRGBAndNarrowband works very well.
Rick Krejci avatar
When screening in narrowband into broadband, I do a continuum subtraction first to minimize the narrowband influence on bright broadband areas. Should help tame the core.
Can you explain that process (in PixInsight terms if possible).
Rick Krejci avatar
Michael J. Mangieri · Jan 25, 2026, 09:16 PM
There are a few ways to do it. Basically, using Ha as an example, the idea is to try to isolate only the Ha signal from the bright broadband signal (from a red filter image) that is present in the Ha exposure. Best use case is capturing the Ha areas in a galaxy without turning the bright core pink.
There are several methods to do it, including manually with pixel math and many steps. But there are now a few scripts that automate this. I’ve recently used the SetiAstro plugin script and you can find how to use it here https://www.youtube.com/watch?v=hyijPH72S8o
There’s another Continuum subtraction plugin tool described briefly here (https://pixinsight.com/forum/index.php?threads/new-scripts-pixinsight-toolbox.19401/ ).
I’ve not used the later one much, but best to try both and see how it goes!
Once you have the HA-only signal, then you can screen it back into red knowing that you are (mostly) just enhancing Ha
Combining OSC 2600mc with 2600mm Mono Data
Hello, I have the following camera systems that cover 3 scopes and 2 mounts. ———————— Camera 1 system: 2600mc Pro ZWO EFW Antlia ALP-T 3nm HaO3 Filter Antlia ALP-T 3nm S2O3 Filter L-Quad ———— Camera 2 System 2600mm Pro ZWO EFW Antlia LRGB + 3nm SHO F...
Combining multiple filter types (OSC, Ha, O3) similar to author's LRGBHaO3 goal.
Dec 27, 2025
Adding "L" Data To RGB Data in Pixinsight
I have been struggling with my first LRGB dataset of M33 for several months now. I have been an OSC shooter for many years and have enjoyed OSC processing. I added a Minicam8 mono to my kit awhile back and have had tons of fun with mono processing, b...
Directly addresses combining L data with RGB in PixInsight, core technique needed.
Jan 4, 2026
Astro pixel Processor - How to combine a OSC broadband image and Extracted Ha and OIII from a dualband filter?
Hello All, I have a 2600MC-pro and have been using APP for a couple of years. I normally am only using 1 filter so no issues stacking. APP has been great. Now I would now like to take broadband subs and add the Extracted Ha and OIII from my antlia AL...
Combines broadband and narrowband (Ha, OIII) data, relevant workflow question.
Sep 5, 2025
